| View Poll Results: Can Front-wheel Drive cars be sportscars? | |||
| Yes |
156 | 44.70% |
| No |
72 | 20.63% |
| H#ll no! |
121 | 34.67% |
| Voters: 349. You may not vote on this poll | |||
#301 (permalink) | |
Practical is boring.
The advantage of AWD doesn't just come into play on dirt roads and wet weather. On any road it has the advantage when powering out of a corner or accelerating from a stop. Does that offset the weight penalty? Depends. The only reason you don't see AWD in F1 and Indy-type racing today is the rules ban it. ![]()
06 Laser Blue Elise: Touring, Sport, Rear brace, SS brake lines, seamless clam, stupid DRLs disabled. 04 Blue Subaru STi The plural of Lotus is Lotus, not Loti. ![]()
#302 (permalink) | |
Bubble Boy
Taxcheat, that Lotus AWD F1 car is interesting. Never knew about that!
#303 (permalink) | |
It led the race (I seem to remember it was a least a lap up on the second place car), when just a couple of laps before the end of the race, it broke a minor part (something like a $5 U-joint) that caused it to drop out of the race. By the next race, "they" had placed so many restrictions on the turbine cars, that they could not be competitive - they were "ruled" out of competition.
#305 (permalink) | |
Registered Abuser
Traction is the ability for the tire to keep the contact patch as large as possible and in contact with the road surface (I'm paraphrasing - probably not well either). "Traction", therefore, has far more to do with the tire itself than the drivetrain. If a FWD car, RWD car and even AWD car drive over the same gravel dump the tires on each will lose the same amount of traction. The contact patch will shrink by the same amount and traction will be reduced. The bigger the contact patch, the more traction you have. Better tires give you a bigger CP and allow you to maintain the size of the CP longer under different conditons. Now, "wheel slippage" is a completely different thing. A RWD car may experience more wheel slippage but that's not the case in straight line driving like above if we hit that gravel patch on a highway. The car has to be in a corner, under hard acceleration, etc. in order for the CP to break traction. Tires, again have a lot to do with this. Yes, FWD (and AWD) can have less slippage than RWD and part of that is due to more weight on the front tires in FWD cars. But, I can stick a couple of cases of beer in the trunk of a RWD car and reduce slippage can't I? More appropriately, I can redistribute the weight or add some techno gizmos like most cars have now to a RWD car to reeuce slippage. Even better, I can make a RWD car with a mid or rear mounted engine to get more weight over the wheels thereby reducing slippage to the point where its likely exactly like a FWD car. Again, noe of this has anything to do with the drivtrain layout - only what you do with it. I know this is niggling details on traction but I thought it could be important. |
#306 (permalink) | |
Bubble Boy
#307 (permalink) | ||
Registered Abuser
Colin Chapman would have designed an AWD, 4 wheel steering, flying, submersible sportscar that would also make your expresso for you. He was brilliant. |
#308 (permalink) | |
Registered Abuser
Here's another question. If you leap of the line with spinning tires do you have more or less traction than if you speed away at just the point before the wheels spin? Answer: It depends. A spinning tire also has a contact patch. And, it can be the same size as one where the tires isn't spinning. A car spinning its wheels is still moving forward which means traction to the road. Normally, the CP gets smaller when you spin the wheels because the tire actually baloons a bit reducing the CP's size. So, imagine if you will, a tire that never ballooned when spinning. Would you have the same traction as if the tires weren't quite spinning? Possibly. Now, tire compounds and 10,000 other things are at play here that i don't understand but I hope you can see the point I'm getting at. |
#309 (permalink) | |
Knows how to jack a car
I seem to recall Audi kicking BTCC ass thanks to quattro, and then AWD was promptly banned, causing Audi to leave BTCC.
1992 Mazda Miata (FINALLY, a sports car!) A couple of old Mk2 VW diesel parts cars |
#310 (permalink) | |
And the second, man you really keep amazing me with the arguments you'll throw out. So you are saying that there is a defined rule as to what exactly constitutes a sports car? That there's no leeway or interpretation (except of course for that pesky McLaren F1)? If not, would you have to consider the Ford Thunderbird, in 1st and/or last generation format, to be a sports car? It had sleek lines, it's a two seater, and it has a powerful engine up front that drives wheels out back. If you don't consider that it is, then what's the rule it breaks? |
#311 (permalink) | |
Bubble Boy
#312 (permalink) | |
Registered Abuser
Any weight in a car can be seen in lateral loads going around a corner. That's not a relevant point. Adding extra weight, in my simple example, or redistributing the weight so you can get that perfect 50-50 ratio will still get you lateral loads. That doesn't affect the contact patch. And road holding ability is ALL about the car's ability to maintain that patch. CP gets small and you lose the back end for example. Now, there's so much more to the CP than what i've talked about. I'm way oversimplifying here. More importantly, this really doesn't have much to do with the subject. FWD cars CAN be true sportscars. No doubt at all. Since RWD sportscars exist and it would be hard for someone to say AWD cars either aren't or can't be then its pretty clear that the drivetrain platform plays absolutely no role in what makes up a sportscar. Its all about what you do with it that matters. No? |
#313 (permalink) | |
#314 (permalink) | |
Registered Abuser
I was waiting for the expresso equipped verson though. Never came out with it so I bought a used '75 Honda Civic instead. It didn't have cup holders either although the holes in the floorboards woulda worked I guess. Lotus probably didn't do it because they would have had to make cup olders to go with it............... |
#315 (permalink) | ||
My Lotus hates my bike.
![]() No the 911s while popularly considered sportscars are technically GT's because they have back seats (I personally do think they are sportscars, but will concede that they're GTs because they have backseats). The dictionary entry that dapinky pointed out mentioned seating for 2. The first Thunderbirds were sportscars to me, but the newest retro one was FWD, and therefore not a sportscar to me (or many ).My definition of sportscar, which sounds like something you'd like finalized and expressed is as follows: Quote:
That's it ![]() |
#317 (permalink) | |
Additionally, in the US pro-Drifting series FormulaD AWD cars must be converted to RWD. |
#319 (permalink) | |
Bubble Boy
#320 (permalink) | |
Registered Abuser
We're no longer even talking about the original subject and are way off base. Did you have a comment about the remarks i made related to drivetrain platforms? Its more relevant I think.
Sorry, couldn't resist. Quote:
