| Sponsored Links | |||
Advertisement | |||
I'm not sure how to just remove the filler door.
But, if worse comes to worst, this is for overall Fuel filler bowl removal: -- Open fuel filler flap. -- Remove right hand rear wheelarch liner. -- Disconnect harness connector from solenoid. -- Unclip drain tube from retain clips pressed into chassis. -- Remove fuel filler cap. -- Pull down fuel filler neck grommet from the base of the bowl assembly. -- Press in the 3 moulded retaining lugs that located the bowl assembly to the rear clamshell. -- Carefully rotate the bowl assembly and tilt to withdraw from clamshell. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
