So I've had an ongoing clutch position sensor issue, which i'm finally narrowing down.
I've got a P0807 fault code, which is a "clutch position circuit sensor low" error according to the Lotus Service Notes under Section EMR. According to the notes, this error is triggered by a sensor voltage of <0.098 volts (whereas the "clutch position circuit sensor high" P0808 error is triggered by a sensor voltage >4.79V).
I do know that my sensor is sending raw data correctly (ie, it's not a bad connection). I think i just need to adjust the range of the travel of the sensor. That said, does anyone know if the voltage goes from low to high when you go from resting pedal to depressed pedal, or vice versa? This will determine what direction I need to adjust the sensor.
