DIY Evora Oil Change with Pictures. - Page 3 - LotusTalk - The Lotus Cars Community
Old 12-01-2012, 03:39 PM   #41 (permalink)
TXBRIT's Avatar
Originally Posted by Plackslayer View Post
Almost a complete DIY - where are the pictures of the BEER?! The most important part?
I would think a good English beer would work best. Perhaps Bass Ale or Old Speckled Hen
TXBRIT is offline   Reply With Quote
Old 12-01-2012, 05:18 PM   #42 (permalink)
swag++
Bane's Avatar
Images: 4
Originally Posted by brgelise View Post
Thanks for the info on the "NIPPLE" usage. As it was first time I did the vehicle with this assembly, I wasn't sure about it. It did drain forever before I could remove the cartridge housing.
Was the engine up to temp first? My housing drains in a matter of seconds when the oil is hot. It also keeps you from getting burned by oil when you remove the next piece with the oil filter wrench.
Old 12-02-2012, 06:31 AM   #43 (permalink)
brgelise's Avatar
Images: 9
I opened casing slowly and yes it was hot as hell!
04 Skip Barber Race School, Competition certificate
04 Jaguar XJ Vandan Plas Radiance Red Ivory leather
08 Isuzu Ascender Lux Flint Grey, Grey leather
10 Lotus Evora Persian Blue, Charcoal w/Ivory header
11 BMW Xdrive35d, Vermillion Red w/Cinnamon Brown
2005 Elise gone but never forgotten as it taught me to drive quickly!
brgelise is offline   Reply With Quote
Old 12-06-2012, 10:35 PM   #44 (permalink)
Boddingtons or Smithwicks would be my choice.
Sent from my iPhone using AutoGuide.com App
trentor is offline   Reply With Quote
Old 04-04-2013, 08:29 PM   #45 (permalink)
Bobsy Racer's Avatar
[QUOTE=lynnpreston;1767232]
Lotus branded filter: $33 shipped
Toyota branded filter: $6 shipped
Has anyone done a side by side comparison of the Toyota oil filter 04152-YZZA1 and the Lotus A132E6399S ?
Are there any differences to justify the Lotus $ cost difference ?
I've seen 10 packs of Genuine Toyota 04152-YZZA1 filters for $35-$40.
Toyota RAV4 2007 2012 V6 Oil Filter 10 New | eBay
Bobsy Racer is offline   Reply With Quote
Old 04-05-2013, 04:38 AM   #46 (permalink)
Julian73's Avatar
Originally Posted by Bobsy Racer View Post
... Are there any differences to justify the Lotus $ cost difference ? ...
I would expect not, especially since Lotus has not changed that "side" of engine and has obligations to Toyota for the pass through warranty they probable use a rebranded standard Toyo filter. As to filters, my last install was a Toyota TRD brand, I don’t have the PN records with me at work, but it was easy to cross reference to the engine through a Toyo site. Filter cost a little more than standard Toyo issue but lots less than Lotus part. Lotus for sure is not using the premium TRD part as it has these differences, metal caps top and bottom rather than “paper” and filtering medium is 100% synthetic fiber similar to the Mobil 1 filters.
Blurb from Toyota Racing site:
"TRD oil filters use a 100% synthetic fiber filtration medium to provide the highest possible dirt removal efficiency with the lowest possible flow restriction. The construction of the outer steel container offers a burst strength exceeding six times the operating pressure and ten times the fatigue strength of standard filters. The internal backing plate is polished to remove manufacturing burrs and improve flow.
When it comes to oil filters, all you need to know is that TRD oil filters are designed to hold 45-percent more dirt than the leading national brand. And while the service life of TRD oil filters is the same as original equipment filters, TRD air filters offer a much longer service life because of their unique construction. A TRD air filter never needs to be replaced – only serviced periodically by washing and re-oiling. And to make that easy, TRD offers a service kit that includes a water-soluble cleaning solution along with the correct oil to re-saturate the filter medium after cleaning."
'12 Evora S GP Special Edition #1 of 15 - and what put Special in "Special Edition": ~ 400 Hp, Komo-Tec Evo-Ra 390 Kit, BOE/Kold-Fire Tune, BOE Intake, Larini S Silencer, Lotus Racing Oil Sump, Chimera CBS Lithium Battery, & other bits. Lotus Driving Academy Level 3 School 1:1 w/ Ed Morris @ Hethel ... new to Pistons, my 3 track toys have Rotaries
Julian73 is online now   Reply With Quote
Old 04-05-2013, 05:02 AM   #47 (permalink)
Just happy to be here
lynnpreston's Avatar
TRD part Julian mentioned:
Amazon Amazon
PN: TRD PTR43-00082
Sent from AutoGuide.com App
"A typical acre of Florida land produces an average revenue of three cents per year in falling cocaine bales."
lynnpreston is online now   Reply With Quote
Old 04-05-2013, 06:02 AM   #48 (permalink)
Originally Posted by Bane View Post
Just a couple of observations:
1. You said you skipped removing the smaller oil cap. I would highly recommend against skipping this step. Use a 3/8" drive ratchet with a 3" extension and remove it. No oil will come out. Then use the supplied plastic nipple (see pic below) with the oil filter and pop it into the housing to pre-drain the oil. This makes the job significantly less messy. I think this feature was an awesome update on Toyota's part.
2. Use a flexible funnel to fill the oil. You can find one at Walmart or nearly anywhere. I bought one to fill the transmission on my old Honda and end up using it all the time.
So are you saying I can just use a standard 3/8" ratchet in lieu of the TOY 640 filter cap tool? From the pictures on page 1 of this thread it appears that is the case. I am getting ready to do my break in oil change and need to know if I need to buy the special tool to remove the filter.
sajonf is offline   Reply With Quote
Old 04-05-2013, 06:36 AM   #49 (permalink)
anthonyseven's Avatar
Images: 2
No. The filter cap has a plug in it. The 3/8" socket is to open the plug while leaving the oil filter housing in place.
You can tighten them both with the 3/8. Don't do it!
BTW
I bought this end cap oil filter wrench on Amazon and it works fine. I bought this end cap oil filter wrench on Amazon and it works fine.
anthonyseven is online now   Reply With Quote
Old 04-05-2013, 07:40 AM   #50 (permalink)
BTW I bought this end cap oil filter wrench on Amazon and it works fine.
Gotcha. Thank you
Old 04-05-2013, 09:54 AM   #51 (permalink)
Geoman's Avatar
Wow. Just this morning I was pondering if it was possible to change the oil myself. I decided to check this site this afternoon and voila! Right in front of my face. Thanks Alp! Damn, I love this site....
Geoman is online now   Reply With Quote
Old 04-05-2013, 09:02 PM   #52 (permalink)
alp
Likes to rent cars.
alp's Avatar
I did one for exhaust installation too if you fancy doing that yourself.
2011 Evora (New rental from Dollar Car Rental.)
2009 Exige S260 (Still with Hertz rental. GPS unit free every month.)
2005 Elise (Enterprise rental took it back cos I farted in it.)
alp is offline   Reply With Quote
Old 04-07-2013, 04:48 AM   #53 (permalink)
Geoman's Avatar
Thanks Alp. I will definitely check it out.
