Regurgitated User
Evora is a heavier than a BMW 3 series?
...so i got to thinking - wich is allways dangerous! reading the US specs for the Evora. what if you looked at weight per gross square inches of 'real estate foot print' ??
Evora: .2448 lbs per sq" 3,046 lbs 170.9 L x 72.8 W = 12,441.5 sq" footprint BMW 328 coupe: .2369 lbs per sq" 3,351 lbs 181.1 L x 78.1 W = 14,143.9 sq" footprint comparatively the BMW 328 is only 300lbs heavier overall... for a bigger car with more "content" stuffed into it, that suprised me. of course the evora will stomp all over the bmw performace #'s wise. and the 335 which would probably be a fairer 'performance' comparision is heavier... anyways - thought it was an interesting comparision ![]() i am still a big Evora fan boy though ![]()
Driving it around!
Denuo Volatilis
...i'm not sure if weight per unit area is a particularly useful metric, since area in and of itself doesn't tell us much about drag and downforce...
2005 Federal Elise | Touring | Storm Titanium ...73,000 miles and aging beautifully... 2000 New Beetle | Turbo | Reflex Silver ...107,000 miles of steadfast service... |
My car is really small
Run that calc for a liter sized motorcycle. Those things are heavy and slow.
05 Safron Yellow "bumbleBee" A terrible car, but a great toy 02 mazda protge 5 "shagginwagin" 84 930 turbo "no nickname yet" |
#4 (permalink) | |
Regurgitated User
was no real usefull point intended! - just triva and maybe another way of considering weights of cars. as i mentioned - not a performance metric. just "weight by the yard" size by size, the evora is heavier by that comparision - kinda wierd as its faster true, but less luxurious and less content. (power sunroof, folding rear seats, etc..) common sense would think the evora would be a little lighter - or the relatively traditionally constructed and not so expensive BMW would be a bit heavier. just think about these things will driving it around
Driving it around!
#5 (permalink) | |
www.lotuschallengeseries.com |
#6 (permalink) | |
Denuo Volatilis
#7 (permalink) | |
Regurgitated User
lotus should have introduced the supercharged car, the only down side would be "its kind of expensive" but then the n/a car would answer that....
Driving it around!
#8 (permalink) | |
Registered A-Hole
-Whit |
#9 (permalink) | |
I disagree with releasing the s/c first the purpose of this car is to attract a new buyer that would consider its versatitlity and looks to be worth the $. I have not ordered an evora but will certainly consider it after 2009.
#10 (permalink) | |
The weight comparison to the Cayman is even more profound. The Cayman weighs a little less than that Evora and again does so without a plastic body. For 2011 the Cayman and Boxster will be completely redesigned. In addition to getting more power and better handling, the 2011 Camyan/Boxster are expected to be lighter by at least 150 - 200 lbs. I honestly can not understand how the Evora can weigh as much as it does. I was convinced that the production numbers wold undercut the estimates. I just can't see how the Evora can weigh 3,000 lbs. It makes no sense.
'03 Z4 3.0 6-speed '08 BMW 335xi Coupe 6-speed '00 Outback 5-speed (bike hauler) '04 Honda CRF250X |
#11 (permalink) | |
#12 (permalink) | |
There is weight savings by using the plastic body... plastic weighs less than steel. Like you said, the whole point of the "plastic" body is to reduce weight. That means overall weight, not weigh/in^2. It does that. The weight of the Evora would be more if they used steel. Consequently, power/weight would go down and performance would suffer. I could make a vehicle out of little more than a jet engine and the lb/in^2 would be very high, but so would the power/weight, which is what is important. Conversely I could put a set of wheels on a pinwheel and achieve a very low lb/in^2. ...I'd rather have the 'heavier' jet engine.
05 AR Elise, Sport, Touring, HT, Starshield |
#13 (permalink) |
Live to Drive
3,046 lbs is an optioned out Evora. 3,351 lbs is a NO OPTIONS stripper 3 series. A typical 328 will be up in the 3450 lb range easily.
Supposedly the stripper weight of an Evora is 2,976 lbs.
Be an alpha male. Drive a Lotus. |
#14 (permalink) |
Denuo Volatilis
...seventy pounds is a lot of weight for options on a lotus - what are we talking about?..
#16 (permalink) |
re: N/A before S/C
I have been assuming that the same logic applies here as did with the Elise. Use an engine that's already legalised by Toyota and then Lotus-ifiy it later, as a legitimate development of the existing motor. If they brought in the S/C engine first I think they'd have to treat it as a brand new one.
#17 (permalink) |
A large cup of mercury is heavier than an Evora, that means as much as this comparison.
One is a supercar, the other a rep-mobile. One is one of the finest handling cars available in the world today, the other is a mundane anony-car driven by many people because their employers forces them too. I'm fortunate enough to have driven the Evora and give me 100 BMW's and I'll turn you down for 1 Evora. What a very odd comparison. |
#18 (permalink) |
Just curious, but since all the cars that everyone likes to compare to the Evora, (Porsche Cayman, and 911, know even BMW) have been around for quite a bit longer than the Evora, maybe we should wait to speculate what the Evora is going to be just a bit longer. Think about the fact they have a 2 seater version, SC version, and even a convertible version coming out in a couple of years don't you think that they could make quite a bit of changes by then?
#19 (permalink) |
Unattractive Nuisance
Isn't there another, more basic reason for plastic?: Molds for this must cost only a fraction of what tooling for stamping would run, especially spread over relatively few cars.
05 elise (PES chip, SSRs, shift tower mods, Multivex; HID low beams); 05 Corolla XRS; 72 Elan Sprint, 170 hp (Sold) "Political language is designed to make lies sound truthful and murder respectable." G. Orwell. 6. "A bore is a man who deprives you of solitude without providing you with company." - Gian Vincenzo Gravina |
#20 (permalink) | |
cheers. henry. |
