The Evora's rev limit is 7,200 sustained right? - LotusTalk - The Lotus Cars Community
post #1 of 27 (permalink) Old 01-26-2013, 05:07 PM Thread Starter
Allan Gibbs's Avatar
I remember the Elise had an over rev feature for about two seconds - but does that apply to the Evora?
Reason I ask is that I noticed I'm hitting the rev limiter at 6,500 rpm. I checked Lotus' site and max power is at 6,400 rpm:
Evora Specifications | Lotus Cars
Hope this isn't another issue with my Evora (pointing fingers at the Radium CAI). Oh, I had the dealer reset the ECU when they installed the sports exhaust yesterday.
2005 Lotus Elise- SOLD 6/9/07
2011 Lotus Evora - SOLD 4/18/13
2011 Lotus Evora S - SOLD - 10/7/14
2014 Lotus Evora S IPS - SOLD 2/13/16
2016 Something else in red
Allan Gibbs is offline
post #2 of 27 (permalink) Old 01-26-2013, 05:23 PM
lynnpreston's Avatar
You're hitting the rev limiter at 6,500 in sport mode?
Standing athwart the automotive zeitgeist.
"A typical acre of Florida land produces an average revenue of three cents per year in falling cocaine bales."
lynnpreston is offline
post #3 of 27 (permalink) Old 01-26-2013, 05:56 PM
anthonyseven's Avatar
From the 2010 Owner's Handbook (USA):
Sport Mode (if fitted)
ln order to cater for the preferences of some sport oriented drivers, a Sport Mode selector button is provided to deliver quicker throttle response, increased power induced wheel slippage thresholds, no throttle reduction on detection of understeer, and a maximum continuous engine speed raised from 6,600 to 7,000 rpm. Note that switching off the Lotus Traction Control in conjunction with selection of Sport Mode, will retain the Sport features, but without any power induced wheelslip intervention. ln all cases, anti-lock braking will be retained.
anthonyseven is offline
post #4 of 27 (permalink) Old 01-26-2013, 05:57 PM
ramtin1000's Avatar
Usually 6500RPM is the Rev Limit in regular ECU mode and 7000RPM is in sport mode. I remember back when I had the Radium installed for the first time, rev limiter would not allow revving over 6500. I reset the ECU and it fixed the issue. Try it it might work for you as well. I need to mention that every time that we've done a dyno we can clearly see that there is not really any power gain passing 6800 RPM.
ramtin1000 is offline
post #5 of 27 (permalink) Old 01-26-2013, 05:58 PM
Notorious L.R.G.'s Avatar
Was the car completely warmed up? My rev limiter is variable, based upon engine conditions. If I try to "show off" leaving the company parking lot, I get rev limited at 4000 rpm, I believe.
Notorious L.R.G. is offline
post #6 of 27 (permalink) Old 01-26-2013, 06:06 PM Thread Starter
Sorry. I forgot to mention, sport mode was on. Actually, it's the second thing I do after turning the ignition. The car was warmed up and just drove about 12 miles.
I've disconnected the battery and will see how it goes tomorrow.
post #7 of 27 (permalink) Old 01-26-2013, 06:49 PM
Julian73's Avatar
This is the idoit proofing limit until water temp is up to normal.
2012 Evora S GP Edition #1 of 14
BOE Headers & ceramic Cat --Stepped-long tube, Prototype BOE CAI, Larini Sport Exhaust, LMS/Swindon Alloy Sump, Prototype BOE Fastworks TQ EV420 tune.
1983 RX-7 Misty Blue
1985 Spec-7 Yellow / Black
1994 RX-7 R2 Vintage Red
2016 Miata Club Gray Mica
Julian73 is offline
post #8 of 27 (permalink) Old 01-26-2013, 10:58 PM
ramtin1000's Avatar
Allan, I have the Kold-Fire cable so resetting the ecu is just a matter of a click with that cable. Leaving the power disconnected does the same thing, just make sure to let the car idle for 10 minutes before driving it for the first time after a full battery unplug.
post #9 of 27 (permalink) Old 01-27-2013, 07:49 PM
Plackslayer's Avatar
I have no issues hitting 7200
Plackslayer is offline
post #10 of 27 (permalink) Old 01-27-2013, 07:58 PM
Ron Avery's Avatar
I am good with 7200 in sport as well.
Ron
Ron Avery
Winnetka Ca
2005 Lotus Elise
2011 Lotus Evora 2+0
Ron Avery is offline
post #11 of 27 (permalink) Old 01-28-2013, 04:43 AM
Already know that the rev counter is off? In sport mode I reach 7200RPM (and a bit above, sometimes 7300) OBD verified, but the rev counter only reachs about 6800.
Evora S Chrome Orange, loaded - KomoTec Stage 3s - Larini exhaust - Pioneer HU - custom interior
Nissan GT-R 2012 (550HP) Black Edition - Wrapped in red - Flapped exhaust - Racing brakes - Spec-V Wheels
Mini Cooper S (Turbo) Convertible - Black - unmodified
Range Rover Evoque Prestige Si4 - loaded
Sold: Nissan 370Z Roadster Pack - Black Cherry - unmodified
Sold: McLaren MP4-12C, Nissan GT-R 2011
dmpriso is offline
post #12 of 27 (permalink) Old 01-28-2013, 05:59 PM
Julian73's Avatar
Originally Posted by dmpriso View Post
Already know that the rev limiter is off? In sport mode I reach 7200RPM (and a bit above, sometimes 7300) OBD verified, but the rev limiter only reachs about 6800.
Como? You say that you are seeing 7200-7300 rpm cross referenced to OBD output, but Rev Limit is 6800 based on what ???
fyi my ECU peak was 7209, 4 other readings in the 70xx's; so believe Rev Limit (in Sport mode) cuts at 7000 with some over run.
Julian73 is offline
post #13 of 27 (permalink) Old 01-29-2013, 12:10 AM
Don't know what I was smoking, I have corrected my post: Rev counter, not rev limiter.
dmpriso is offline
post #14 of 27 (permalink) Old 01-29-2013, 01:51 AM
mkt
mkt's Avatar
Do you have N/A IPS? In that case only it's a different rev limit;
According to Lotus
"Please note that due to gearbox limitation, the max rev limit on Evora fitted with Lotus IPS is 6500rpm. The additional rev limit usually available by pressing the sport button is therefore cancelled in order to preserve the car."
mkt is offline
post #15 of 27 (permalink) Old 01-29-2013, 05:24 AM
Julian73's Avatar
fyi from last nights dyno results my stock peak power came at 6100 rpm torque at 4300
with headers and tune: 6600 and 5000 rpm. Really not much use above the standard 6600 redline
Julian73 is offline
post #16 of 27 (permalink) Old 01-29-2013, 06:55 AM
invictusmaneo's Avatar
*for a supercharged car.
anyone have a good NA graph to show?
'10 Chrome Orange Evora
3020 lbs wet, 285 whp, grins for miles
invictusmaneo is offline
post #17 of 27 (permalink) Old 01-29-2013, 09:04 AM Thread Starter
It would be nice to have a little time to shift even if peak hp is at 6,500.
On a side note, I'm going back to the stock air box. I also ordered a KoldFire 290 tune from British Racing Group:
ECU Tuning for your Lotus
post #18 of 27 (permalink) Old 01-31-2013, 11:13 PM Thread Starter
The stock air box is back in. Looks like the rev limiters coming in around 6,800 now. I should have the Kold Fire tune in a few days. Hope it get me to the 7,200 limit.
post #19 of 27 (permalink) Old 02-01-2013, 10:06 AM
Julian73's Avatar
From service manual:
Maximum continuous engine speed
- std 6,600 rpm
- Sport mode 7,000 rpm
Maximum transient engine speed
- std 6,800 rpm
- Sport mode 7,200 rpm
Normal warm idle speed
- a.c. off 640 rpm
- a.c. on 690 rpm
Julian73 is offline
post #20 of 27 (permalink) Old 02-01-2013, 10:09 AM
Julian73's Avatar
link to BobsyRacer's plot:
2bular NA Evora Exhaust System
Julian73 is offline
Human Verification
