Headlight adjustment - LotusTalk - The Lotus Cars Community
post #1 of 6 (permalink) Old 02-19-2012, 06:28 PM Thread Starter
The Lotus site will not allow me in to purchase manuals and such. I just had my headlights changed and they a pointed so low I cannot drive safely. I searched but cannot find any info on how to adjust. Certainly I should take the inner wheel liner out but what can I expect when I get there?
Any help appreciated.
2011 Porsche Boxster Spyder
2012 Shelby GT500 (for sale)
1967 Chevrolet Nova SS L-79
1955 Porsche 550 rep
The Truck
USGPRU27 is offline
post #2 of 6 (permalink) Old 02-19-2012, 07:00 PM
for what it's worth...
...from page 38 in the Service manual:
Headlamp Beam Alignment
1. Using beam setting equipment compatible with local regulations, position the machine between 300 and 700mm in front of the LH headlamp, and parallel with the two headlamp units using the sight bar or similar device dependent on the machine design, to ensure cross car match. Use the guides provided on the machine to ensure the correct height and lateral setting.
2. Switch on the headlamp dip beams and check the lateral beam alignment. The ‘knee point’ of the beam cut off line must lie within a tolerance of 2% to the passenger side, and 0%. Check the vertical alignment of the dip beam which must lie within a tolerance of -0.5% and -2%.
3. If adjustment is required, turn the steering to full lock to facilitate removal of the four screws retaining the access cover in the wheelarch liner.
4. Each headlamp assembly features two adjustment screws, one for vertical, and one for horizontal aim (USA cars - vertical only). To adjust the beam laterally, turn the inboard adjuster screw. Turn clockwise to adjust the beam to the right. Optimum setting is 0%. To adjust the beam vertically, turn the outboard adjuster screw. Turn clockwise to raise the beam. Optimum setting is -1.2%. Re-check lateral alignment.
5. Repeat for the opposite lamp.
6. Re-fit the access cover in the wheelarch liner.
I too need to adjust mine "up".
Steve
St. Louis
'06 Exige Solar Yellow
'11 Evora 2+0 Ardent Red
mccasksl is offline
post #3 of 6 (permalink) Old 02-19-2012, 07:20 PM Thread Starter
Fantastic... Thanks.. I will just raise a little and recheck at night...
The Truck
USGPRU27 is offline
post #4 of 6 (permalink) Old 02-19-2012, 07:27 PM
chazzer's Avatar
Thanks
When I drove mine at night I also saw that they pointed way low on Low Beams. I need to adjust also. Keep us posted if the directions are easy and I'll do mine also as they point at night on the white garage door as it is down. The lights are really bright and reach far on High Beams though. Love um.
2011 Evora Starlight Black/Gold.
2005 Elise Saffron Yellow- (sold)
2014 Ford Escape
2008 Nissan Xterra
chazzer is offline
post #5 of 6 (permalink) Old 02-19-2012, 09:03 PM
ANUBIS's Avatar
Fix them jsut a bit higher than noticed; and the light is perfect without flashing others.
ANUBIS is offline
post #6 of 6 (permalink) Old 02-27-2012, 01:19 PM
brgelise's Avatar
Super easy to adjust folks. My replaced light s were also low but atre excellent after adjust
16 Range Rover Sport HSE, Montalcino Red w/Ivory Leather-->stunning
12 Maxda MX-5 Miata GT PRHT True Red/Black leather (LUCY)
11 BMW Xdrive35d, Vermillion Red w/Cinnamon Brown Leather
08 Isuzu Ascender Lux Flint Grey, Grey leather
brgelise is online now
Human Verification
