How do you access the battery when it's dead? - LotusTalk - The Lotus Cars Community
User Tag List
Old 02-04-2013, 01:21 PM   #1 (permalink)
sprint-speciale's Avatar
Quoted: 0 Post(s)
My OEM 2010 Evora battery just died. How do I open the trunk to get to it?
This is yet another reason there should be a cable release inside the car.
Thanks.
sprint-speciale is offline   Reply With Quote
Old 02-04-2013, 01:25 PM   #2 (permalink)
Julian73's Avatar
Quoted: 71 Post(s)
There is a cable release, on passenger side lift up back seat cushion (assuming 2+2) and pull "rip cord".
That’s the easy part, peeling of the carpet Velcro without un-sticking the tape, removing net mounts to gain access to the battery cover is the more time consuming part. Mid 12MY production, they changed the battery access to be outside of the carpet, I asked my dealer to install but they found they could not because the mounting holes were changed to studs in different positions … they gave up, maybe I will look at other ways to mod later.
'12 Evora S GP Edition #1 of 14
KomoTec EV390+ BOE = +++ (KT Stage 1S Headers, Cat, BOE prototype CAI, BOE Custom Tune & Larini Sport),
LMS Alloy Oil Sump, a few 3K CF bits, Custom Engine Cover
Lotus Driving Academy Level 3 School 1:1 w/ Ed Morris @ Hethel
New to piston power, my track toys have Rotaries
Julian73 is offline   Reply With Quote
Old 02-04-2013, 01:28 PM   #3 (permalink)
Quoted: 0 Post(s)
That's great, thank you. Don't recall seeing that in the manual.
Old 02-04-2013, 01:31 PM   #4 (permalink)
Julian73's Avatar
Quoted: 71 Post(s)
dont have it handy, not sure what page.
Old 02-04-2013, 01:45 PM   #5 (permalink)
Quoted: 9 Post(s)
You should doublecheck to make sure you are pulling the manual release in the correct direction. I believe people have reported the cable snapping if you don't pull it in precisely the correct direction (i believe it's supposed to be straight towards the driver's side of the car, ie perpendicular to where the cable comes out of the passenger's side). Supposedly the fix for if the cable snaps is a MASSIVE pain in the ass involving drilling a hole into the trunk in order to get access to the release mechanism.
texevora is offline   Reply With Quote
Old 02-04-2013, 01:48 PM   #6 (permalink)
Quoted: 9 Post(s)
Be careful when using the manual trunk release
You should probably doublecheck with your dealer before attempting this. I'm a little confused by his description of which direction to pull in.
Old 02-04-2013, 06:36 PM   #7 (permalink)
Quoted: 0 Post(s)
The cable release worked fine, but you need to be sure to manually push it back in. Otherwise the trunk latch won't function.
Now that I've accessed my battery and have it on a charger, any ideas how to stop the alarm from cycling through a low, but audible siren sound? It began as soon as the trunk lid was opened.
Old 02-05-2013, 05:16 AM   #8 (permalink)
invictusmaneo's Avatar
Quoted: 12 Post(s)
either use your remote, or if that doesn't work do the pin code. If you don't have it your dealer can look it up for you
'10 Chrome Orange Evora
3020 lbs wet, 285 whp, grins for miles
Build Thread:
http://www.lotustalk.com/forums/f417...e-once-254705/
invictusmaneo is offline   Reply With Quote
Old 02-05-2013, 06:28 AM   #9 (permalink)
Lckitty's Avatar
Images: 25
Quoted: 14 Post(s)
I just went through this same scenario last weekend. Pull hard on the handle toward the drivers side but at about a 45 degree angle fwd. Don't pull too hard as you will pull out the little attach point guide (Like I did). Yes, you have to push the cable back. Remove the pos lead for charging so the alarm won't mess with you. Use the remote to reset when you reattach the battery lead after fully charged.
2012 Lotus Evora - IPS, Nightfall Blue
2007 Jeep Grand Cherokee - Overland, Hemi (The Anti-Lotus)
2004 Saab 9-3 Convertible (tuned to 265HP) - The DD
Totalled: 2011 Lotus Evora 2+2 - Canyon Red Metallic
Sold: MGB, Miata, Merc 560SEL, F-150, Civic, Saab 9-5SE, '05 Ford-GT, '69 Cad Sedan DeVille, Triumph Daytona 955i
Lckitty is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
