Jack stands?
I was trying to put the rear of the car on jack stands today, but found that other than the specified jack points at the back (there are two), there seems to be no other area where I could safely load the car onto actual jack stands once the wheels came off. Anyone try to put the car on stands and if so, how (with only one jack that is)?
| Sponsored Links | |||
Advertisement | |||
Little Bee
Hi. Start here. Lots of info. There are more jack points after you remove the undertray and diffuser.
Jacking the Elise and Placing on Jackstands Hope this helps. -Alex
2008 Elise SC - Solar Yellow |
I have not had to do this for my Evora yet, but I'm pretty sure this procedure that works well on other cars will also work for it.
You will need two floor jacks: First jack up a corner of the car using the recommended jacking point. Remove the wheel. Position the second floor jack at the lower ball joint of the suspension upright and jack up the suspension (making sure the jack is free to roll as the suspension compresses) until the car lifts off the first floor jack. Remove the first floor jack and replace it with a jack stand. Lower the suspension so that the jacking point rests on the jack stand. Removing the jack stand requires the reverse procedure.
Joel '67 S3 Elan dhc (owned since 1970) '06 Audi A3 3.2 '10 Evora (Carbon Grey/Charcoal) Last edited by JLSELISE; 11-05-2010 at 01:52 PM. |
#5 (permalink) | |
Yes, this is for an Evora. Thanks. |
That would be basically the area where the suspension upright (hub) attaches to the lower a-arms. Shown roughly by the tip of the yellow triangle in the pic below for the rear of an Evora. Note in this case the lower attachment point for the shock absorber is also in the same area. Best to use a hard rubber pad or some wood between the jack and the jacking point in this area to spread the load and accommodate irregularities between the parts.
Joel '67 S3 Elan dhc (owned since 1970) '06 Audi A3 3.2 '10 Evora (Carbon Grey/Charcoal) |
#7 (permalink) | |
#8 (permalink) |
In futhering this discussion, would we not be able to use the rear subframe crossmember as a jack stand location?
![]() ![]() To me, it looks like jack stand point D on the Elise/Exige: Pop off the diffuser, raise the car & place the stands as so. Is there any reason this shouldn't be done?
2010 Lotus Evora Starlight Black 6-speed manual |
#10 (permalink) |
G-200 Driver
If all else fails.............you could read the manual.
Elise #2292 / CO / Starshield / Nitron Sport SA / RTDbrace / Uprights machined / Down Low rails / DBA 4000 Wiper Slot Rotors/ V1 / SS lines w/Pagid Black / G-Pan / Odyssey PC680 with RLS Bracket / Difflow 5 Element diffuser / Stebel Nautilus horn "My daily driver does .85 Mach" " I started flying when Sex was safe and Hang Gliding was dangerous "
#12 (permalink) |
The manual doesnt describle how you can transfer from a jack to a jackstand as per manual only lift points are the same spot. manual does say DO NOT lift from suspension.
'12 Evora S GP Special Edition #1 of 15 - and what put Special in "Special Edition": ~ 400 Hp, Komo-Tec Evo-Ra 390 Kit, BOE/Kold-Fire Tune, BOE Intake, Larini S Silencer, Lotus Racing Oil Sump, Chimera CBS Lithium Battery, & other bits. Lotus Driving Academy Level 3 School 1:1 w/ Ed Morris @ Hethel ... new to Pistons, my 3 track toys have Rotaries |
#13 (permalink) |
It's been a while since I looked under my Evora, but are the lift pads large enough to accommodate both the jack and a jack stand, provided your jack doesn't interfere with the stand's base for position?
#14 (permalink) | |
BBeauty
no jack stands - ramps - my solution
Good price on Rhino ramp and jack stand - LotusTalk - The Lotus Cars Community
2012 IPS Evora 2+0 Starlight Black, 2012 Elantra, 2005 Astro Van [SOLD]2005 Elise Starlight Black, hardtop, touring pack, Larini Sport Style exhaust. |
#15 (permalink) |
wait what?
Problem with ramps is that you are still on the wheels - I need to get both wheels off = lift or jack stands... A lift I know how to use - but do not have... Jack stands I have but do not know how to get the Evora onto lol.
#19 (permalink) | |
Do it once. Do it right.
Do it once. Do it right. http://www.17of30.com YouTube: 170f30 S260 Final Edition RBH
#20 (permalink) | |
5 threaded anchors are inserted into to the slab, for each post. You draw up a bolt in each anchor to expand them into the 7/8 inch holes drilled in the slab, like a Rivnut. The lift posts are just bolted to the slab anchors, and the lift is rated for 6,000 pounds capacity. Most Commercial shop lifts are similarily just bolted to floor anchors. The bars you see on them across the floor or the top, are just for running cables or hydrolic lines. As shown on the Youtube, you can unbolt the posts and store the whole lift aside. I just leave it up, and keep the race car parked there, or up on it. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
