| Sponsored Links | |||
Advertisement | |||
#22 (permalink) | |
#23 (permalink) |
Interesting, I was wondering if they gave it a little bit a toe from the factory (THEY DO! 1.5 mm toe-in each side in the rear). Zeroing out the toe should help tire wear a LOT. You will lose a little bit of that quickness at initial turn in though, it won't feel as light.
Camber's effects on tire wear pretty much depends on how flat you get the tires in the corners (how hard you corner it). This much you can easily see/feel by looking/feeling at/the insides of the tires. If your toe is 0 all around and you're wearing evenly, your camber should be good. Looking at the stock specs I'm extremely happy Lotus engineers went with a healthy amount of positive caster, to run minimum negative camber angles. This is pretty much the exact same setup I went on my STi, another car that loves caster. Stolen from another thread (source is the manual): Code:
FRONT SUSPENSION Type Independent. Upper and lower lightweight forged alloy wishbones; co-axial coil spring/telescopic damper unit; tubular anti-roll bar Geometry Mid-laden ride height (2 x 75 kg occupants + full fuel tank) set car to this height before measuring geometry: - front 125 mm below front end of chassis siderail - rear 147 mm below rear end of chassis siderail Castor - optimum: + 5.2° - tolerance range: + 5.0° to + 5.5°; max. side/side 0.3° Camber - optimum: - 0.3° - tolerance range: - 0.5° to - 0.2°; max. side/side 0.2° Alignment - optimum: Zero - tolerance range: 0.5 mm toe-out, to 0.5mm toe-in overall Steering axis inclination: 9.4° nominal REAR SUSPENSION Type Independent. Upper and lower lightweight forged alloy wishbones; co-axial coil spring/telescopic damper unit; tubular anti-roll bar Geometry Mid-laden ride height (2 x 75 kg occupants + full fuel tank) set car to this height before measuring geometry: - front 125 mm below front end of chassis siderail - rear 147 mm below rear end of chassis siderail Camber - optimum: - 1.6° - tolerance range: - 1.8° to - 1.5°; max. side/side 0.2° Alignment - optimum: 1.5 mm toe-in each side - tolerance range: 1.4 to 1.8 mm toe-in each side; max. side/side 0.3 mm Thrust angle - optimum: Zero - tolerance: 0.05° |
#24 (permalink) |
Yes, so has anyone deviated from these manual specs? I'm about to go get an alignment and need to know what guidance to give the service guys. Looking for a nice balance of tire wear and performance/feel. I'm 100% street use. Thoughts?
2011 Lotus Evora 2+2 (demo car) - Canyon Red Metallic 2004 Saab 9-3 Convertable 2007 Jeep Grand Cherokee Overland 2005 Triumph Daytona 955i (0-60 = 2.9 secs) |
#25 (permalink) | |
Remember that the Lotus specs are with 330 lbs of ballast in the front seats. Essentially no public alignment shops do that when they make adjustments and it does affect the measurement. ![]() donour |
#26 (permalink) |
I will let my pyrometer guide me but I suspect (these are my guesstimations based on 8 yrs with the Elise) the track (street/track compromise) setting will be
Front toe: 0 camber: -1.25 to -1.5 Rear toe -1.0 or less camber -2.5 I'll bet the VSA guys, Sector 111 and BOE have some numbers for us. My Elise had -1.6 front camber and -2.5 camber and was damn near perfect for my needs! These numbers reduce the toe a bit for quicker turn in and reduced wear esp on the rears is the benefit. Unless you get out of hand with camber it has never affected street tire wear that much for me.
04 Skip Barber Race School, Competition certificate 04 Jaguar XJ Vandan Plas Radiance Red Ivory leather 08 Isuzu Ascender Lux Flint Grey, Grey leather 10 Lotus Evora Persian Blue, Charcoal w/Ivory header 11 BMW Xdrive35d, Vermillion Red w/Cinnamon Brown 2005 Elise gone but never forgotten as it taught me to drive quickly! |
#27 (permalink) |
Rears have a lot of camber which results in high tire wear for highway use. Infers wear out faster. Don't care, won't change anything which compromises the agility of this awesome car, I bought if for fun, not to optimise tire wear. Got 8,000 miles out of the Corsa rears, that good enough.
2011 Evora S 2+0 // carbon grey // diamond cut rims // charcoal leather // Schroth Rallye 3 ASM harness |
#28 (permalink) |
Now 100% Elise-free
My Michelin's look brand new, at the same mileage as the Pzeros were worn flat in the centers...6000 miles.
Anyone else had bad experience with the tire shop damaging the fragile Lotus rims? |
#29 (permalink) | |
Lotus Addict
You need to ask first and ensure they have the proper equipment to do your wheels without scratching them. Not all tire machines have nylon edge guards on the pry arms, especially older machines.
They all do that, sir. |
#31 (permalink) |
Lotus Addict
One time at a tire shop I required them to hand-torque my bolts when reinstalling my wheels. I spent 10 minutes watching the tech go from station to station asking everyone if they had one to use, and sure enough no one did. Idiots. Ulitimately, I walked into the garage and handed them my own torque wrench from my trunk.. Unbelievable.
#33 (permalink) |
Camber of rear wheels is a rather aggressive -2.8 degrees as from the Factory, contributing to high tyre wear on the inside. If you do not need high grip when exiting corners on track every week, my dealer in Ostend, Belgium recommends reducing the camber to -1.5 degrees, which leads to far less inner wear on the tyres without any loss in feel. Hope this helps! BW Bart
Sent from AutoGuide.com App |
#34 (permalink) | |
Pirellis are not an LTS spec. They are MO spec on our NA Evoras. Written right on the tires no discussion needed here. Available at Tire Rack. I'm at 6500 miles on rears and have 3/32nds left with a track day thrown in. 8K seems to be the magic number.
#36 (permalink) | |
My 2010 NA Evora came with MO1 spec Pirellis on the rear, not MO. I believe these are what folks are referring to when they say it is a Lotus-specific tire. When it came time to replace them, I bought the MO spec tires because they were easy to find. I have noticed no difference so far, but I don't track my Evora.
Tony Indianapolis '10 Evora '66 S2 Super Seven 1500 Cosworth '99 Birkin sold
#37 (permalink) |
It doesn't matter if the wheels are stock or not, the spec is for the bolt
, and in the manual it says about 77 ftlbs.
Joel '67 S3 Elan dhc (owned since 1970) '06 Audi A3 3.2 '10 Evora (Carbon Grey/Charcoal) |
#38 (permalink) |
#39 (permalink) | |
Optimum is -1.6 per side with a .2 diff. Seeing very even tire wear, no remote excess inside wear and only 1 track day. I agree you need less if you're highway driving.
#40 (permalink) |
My rear P-zeros were nearly bald at 5,000 miles so I replaced them with Michelin super sports which now have about 2,000 miles and hardly any indication of wear. I'm curious about the camber comments because my wear seemed uniform across the tire which implies no camber whatsoever. Is that possible?
Keeping the original P-zeros in the front since they have a lot of tread left and previous comments here suggested mismatching front and rear tires would not be a fatal flaw. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
