#21 (permalink) | |
| Sponsored Links | |||
Advertisement | |||
#22 (permalink) | |
The PSi/Ohlins setup has adjustable spring perches which can raise/lower the car. More importantly (in my opinion) they allow for precise corner balancing -- clearly geared for track use. Just eyeballing the numbers, you should be able to go up in springrate a fair amount (10-20 %) without producing a punishing or harsh ride. The key is getting a shock that's sufficiently digressive to not be harsh. Isn't the 'S' 10% stiffer all around with a larger rear bar? donour |
#23 (permalink) | |
#24 (permalink) |
Chris
You can set your rebound/damping on coilovers to be very compliant on the street, especially if you choose a mild spring rate. Coilovers are the best option to give you the best of both worlds really.
2005 Magnetic Blue Lotus Exige Drivetrain: Honda K20A Type R | Innovative Mounts | Arqray Ti | Innovative Exhaust | Custom Intake | Hondata KPro | proRAD | Setrab Cooler | Innovative Shifter | KTuned | V2 Fuel Tank | Radium Coolant Tank | Aero: Exige Clams | Reverie | TWRD | Craftsquare | Denag | IMRP | BSK Hatch Suspension: Nitron SA | V2arms | RTDbrace | Volk CE28N | Toyo R888 | DBA4000 | Pagid RS14 Interior: Recaro SPG | Willans | WorksBell | Sparco Wheel | aspec Ti knob |
#25 (permalink) | |
yep i agree, i've only used coilovers in every car i've owned. i guess we just have to wait to see what other coilover options will come out for the evora. |
#28 (permalink) | |
I wonder what the springrates are... I still contend that the stock setup has almost everything you want. Somebody could just make new mounting brackets to add ride height adjustment (EDIT: and keep full travel). donour Last edited by donour; 11-27-2012 at 08:49 AM. |
#30 (permalink) | |
'12 Evora S GP Special Edition #1 of 15 - and what put Special in "Special Edition": ~ 400 Hp, Komo-Tec Evo-Ra 390 Kit, BOE/Kold-Fire Tune, BOE Intake, Larini S Silencer, Lotus Racing Oil Sump, Chimera CBS Lithium Battery, & other bits. Lotus Driving Academy Level 3 School 1:1 w/ Ed Morris @ Hethel ... new to Pistons, my 3 track toys have Rotaries |
#31 (permalink) |
Lowering it an inch would make it almost impossible to deal with driveways and slanted surfaces... Kinda like driving a Koenigsegg CCR around the city and parking lots / driveways /etc--I can tell you from experience that it ain't fun, lol!
#34 (permalink) | |
Lotus Race Prep
![]() Join Date: May 2012
If you are looking for a more cost effective option, the factory dampers are ride height adjustable via the upper spring perch. There are 3 machined grooves with a circlip that supports the perch. I believe you can get -5mm if memory serves. Toe and camber adjustments are recommended when changing ride height.
Lotus Race Prep and Street Service in Los Angeles. 14819 Aetna St Van Nuys, CA 91411 818-666-0731 Stephan@Vsamotorsports.com www.VSAMotorsports.com |
#35 (permalink) | |
offtopic: The rules for Stock in SCCA Solo get a a little messy with adjustments like this. Some cars (c5 vette come to mind) allow small ride height changes and it is completely within the rules because GM endorses it. On the other hand, the 996 GT3 has a camber settings that are not legal because porsche lists them as "off-road only". 0.2" is better than nothing. :-p donour Last edited by donour; 11-27-2012 at 08:48 AM. Reason: grammar |
#36 (permalink) | |
wait what?
#37 (permalink) | |
![]() Generally speaking, camber and toe change dynamically as the wheel moves away from static ride height -- either in extension or compression. If you lower the car, each wheel moves in the compression direction. In our case, camber will be a little higher and the rear will toe in slightly. The factory adjustment bolts should be _plenty_ to get back to factory alignment settings with a small ride height change. If you want some exotic alignment values, then you might need some exotic hardware. You almost certainly don't. cheers! donour EDIT: As a rule when designing racing suspensions, you are very careful when controlling dynamic camber. You want very little change around static ride height and you want the value at full compression to be close to the roll angle of the car. That way the tire experiences a pretty constant angle with the ground. Most cars suck as this (I'm looking at you rally cars). I actually bought an Evora because the designers thought about this when building the car. Last edited by donour; 11-27-2012 at 09:16 AM. |
#38 (permalink) | |
wait what?
![]() Thank you. |
#39 (permalink) | |
Regarding the EDIT on dynamic camber, your analysis is Very well stated ! |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
