MY12 Evora S Shifting Issue - LotusTalk - The Lotus Cars Community
Old 01-21-2013, 06:42 AM   #1 (permalink)
Question MY12 Evora S Shifting Issue
Hi all,
Since purchasing my Evora I am halfway through the initial break-in period and have noticed an odd issue with shifting thus far that I was hoping for some suggestions on. Going into 2nd from 1st gives a bit of a grinding noise - it seems to catch and not latch on smoothly. Double clutching (or just waiting a long time for the revs to drop) seems to resolve the problem, or at least very much minimize it, but it is still a very sensitive shift. All of the other gears are flawless.
I had the dealer look at it, but they told me all seemed fine and it may just need to be broken in further. Interestingly enough, when I got it back last Friday I didn't have as much of an issue with it and figured they might be right. But, this morning I am back to the same noise as before. It was about 40 degrees colder outside this morning than when I drove it on Friday afternoon, but other than that I can't think of any difference or reason for the change.
Any thoughts or things I could have them check out would be appreciated. I am very puzzled by the issue only being present with the change into 2nd.
- Chris
2012 Lotus Evora S 2+0 ... Starlight Black // Ebony Leather w/ Red Piping
2011 Ford F-150 Lariat 4x4 ... Dark Blue Pearl // Black Leather
chobbs is offline   Reply With Quote
Old 01-21-2013, 06:55 AM   #2 (permalink)
Just happy to be here
lynnpreston's Avatar
My shifts into second have always been a little rough, especially when it's cold out. Once everything is really heated up (15 minutes of driving on a 60 degree day), it gets much better - but still not perfect. That second gear shift is my only real gripe with the car.
"A typical acre of Florida land produces an average revenue of three cents per year in falling cocaine bales."
lynnpreston is offline   Reply With Quote
Old 01-21-2013, 08:11 AM   #3 (permalink)
Chapman Disciple
Chhirowolf's Avatar
Me too. a bit frustrating on spirited driving. Dealer says
Chhirowolf is offline   Reply With Quote
Old 01-21-2013, 09:05 AM   #4 (permalink)
It makes me sad to say I pine for the shifter feel of my mkII or mkIII MR2's.
Old 01-21-2013, 10:50 AM   #5 (permalink)
invictusmaneo's Avatar
2nd is a very troublesome gear and it takes super slow, methodical, clutch-heating-up shifts to make a 1-2 shift smooth..usually once it is warmed up I can do it a bit better, and same with the downshift. It seems the synchros for 2nd are much happier at 2500+ than they are below that.
That being said 2-1 is never an easy shift, and I stick it out in 2nd most times
'10 Chrome Orange Evora
invictusmaneo is offline   Reply With Quote
Old 01-21-2013, 11:03 AM   #6 (permalink)
Be smooth
XHILR8N!'s Avatar
Images: 14
Agreed
2011 Evora S Racing Heritage Edition (#3 of 4)
2005 Elise LRG, Trim Shop interior, full cage, Cup wheels, BWR 'charger lives!
1974 Lotus Europa Special 3841R in JPS livery (home again!)
2007 Toyota Tundra (about 10 cup holders) 2008 Audi A4
1980 Rover SD1 (new home)
XHILR8N! is online now   Reply With Quote
Old 01-21-2013, 12:28 PM   #7 (permalink)
KCZ
+1
2011 Evora S 2+2 in Persian Blue with Oyster
2003 350Z, Track edition
2011 Xterra, for 6 months of winter
KCZ is offline   Reply With Quote
Old 01-21-2013, 12:59 PM   #8 (permalink)
Wow, at least it isn't just me. Taking her out at lunch gave much less trouble, but the car was sitting in the sun and it is a fairly warm day for January (temp was around 60 degrees). Seems like that temperature is a key factor. I found a bunch of references to the Toyota gearbox doing this for a variety of models: Toyota Nation
So, what is the recommended approach for dealing with this - do I shift from 1st to 3rd to avoid this problematic gear change or will it not wear problematically despite the noise?
- Chris
Old 01-21-2013, 01:25 PM   #9 (permalink)
S666TT's Avatar
Hi Chobbs,
They all do this to some degree or another. I thought I had bought a right lemon when I drove it away and kept hearing "that noise" from 1st to 2nd. However, my answer was to fit a custom exhaust and decat with a Radium CAI, now I cant hear the shift at all.
There is a bit about this common problem on this link from the South East Lotus Owners Club (SELOC).
Known Issues - Evora - TechWiki
You could try and get Lotus to change the gear linkage, that sometimes does it, or mask the sound with a loud exhaust and air intake.
I just learned to live with it.
S666TT is offline   Reply With Quote
Old 01-21-2013, 01:29 PM   #10 (permalink)
JLSELISE's Avatar
You might consider changing tranny oil to synthetic like Red Line Shock Proof Light Weight after break-in. I have it my car now and have no issues with shifting at 11K miles, although the action is still somewhat stiff when cold, as others note.
Joel
'67 S3 Elan dhc (owned since 1970)
'06 Audi A3 3.2
'10 Evora (Carbon Grey/Charcoal)
JLSELISE is offline   Reply With Quote
Old 01-21-2013, 01:34 PM   #11 (permalink)
Royal Purple Max Gear seems to have made my warm shifts better and cold shifts worse. Of course it could be my imagination. I don't hear a noise with mine. This is the first I have "heard" about that.
Sent from my iPhone using AutoGuide.com App
Old 01-21-2013, 07:44 PM   #12 (permalink)
SouL's Avatar
Hm. Shifting in my '12 S has been very good since I took delivery in July. ~5.5K miles now and no shifting issues/noises.
1 - 2 is probably the most hesitant. But if you gently and steadily put it into 2nd it will go in without much effort.
3 - 4 - 5 - 6 you can shift as fast as you want and the shifter will go into the gate easy.
SouL is offline   Reply With Quote
Old 01-22-2013, 12:09 AM   #13 (permalink)
Snoopy1969's Avatar
Same here (also My 12 S) - from 1 - 2 a little bit stiff for about 5 minutes when cold (but same issue in other cars I drive also) but no noise definetely- I think that with the "upgraded" My 12 the problems mentioned above by the other guys should not occur. Therefore I think your dealer should examine the issue again.
Snoopy1969 is offline   Reply With Quote
Old 01-22-2013, 03:06 AM   #14 (permalink)
I'd start with adjusting the shifter cables. That's something you can do at home, it's not very complicated and doesn't need very much time.
Read Thomas' Thread at TLF:
Gearchange Issues dissected - Engine & Ancilliaries/Gearbox - The Lotus Forums
Helped a lot for my gearchange (MY11 S).
Evora S Chrome Orange, loaded - KomoTec Stage 1 - Pioneer HU
Nissan GT-R 2012 (550HP) Black Edition - Flapped exhaust - Racing brakes - Spec-V Wheels
Nissan 370Z Roadster Pack - Black Cherry - unmodified
Mini Cooper S (Turbo) Convertible - Black - unmodified
Sold: McLaren MP4-12C, Nissan GT-R 2011
dmpriso is offline   Reply With Quote
Old 01-22-2013, 05:28 AM   #15 (permalink)
Thanks for the link - I'm going to try the #3 suggestion at lunch. It sounds like the poster had to loosen the left-right adjustment in his case. What direction and by how many turns did you adjust yours?
Old 01-22-2013, 06:01 AM   #16 (permalink)
Thanks for the thoughts and links everybody. I have sent the info along to the dealership and asked them to contact the Lotus rep to get an answer on this subject. Regardless I will definitely be revisiting the issue at the 1k service if it is still a problem.
- Chris
Old 01-22-2013, 06:18 AM   #17 (permalink)
I don't remember exact direction and number of turns. Actually I compared the lateral play of 1st, 3rd and 5th gear and noticed that first and second gear are very tight; on the "right" side it is limited by the gearbox (remote - through the cables), on the "left" side by the reverse gear block (if I remember correctly). So I just changed the length of the crossgate selector, there was no need to adjust the actual gear selector gate.
It's hard to explain, but if you have the thing open and play a bit it becomes easy and logical.
Old 01-22-2013, 07:33 AM   #18 (permalink)
Lotus Air - fly lighter
If I remember correctly you will have to lengthening the cable by one or two turns. You should be able to shift 1st/2nd back and forth easily when holding the lever against the reverse lockout.
Another tipp: I always had the feeling the gearshift lever was a bit too far forward, especially in 1st, 3rd and 5th gear. You can compensate this by turning the corresponding ball joint fully in. In fact we chose to cut about 4 milimetres off of the bolt to be able to tighten the ball joint up to the end. This moves the upper end of the lever back bout 15-20 milimetres, which I find much more comfortable.
And a third tipp: If you have the arm rest you probably find it just as useless as I did. I have meanwhile put a rubber bushing on the underside as spacer (in front of the two holding screws). The arm rest is now pretty well horizontal when down and can actually fulfill its purpose.
tbd_Evora is online now   Reply With Quote
Old 01-22-2013, 11:08 AM   #19 (permalink)
I adjusted my crossgate cable out (counter clockwise) two turns and my shift cable in (clockwise) one turn. Went for a 15 minute drive (from cold start). It seems to be a bit better.
Old 01-22-2013, 12:02 PM   #20 (permalink)
brgelise's Avatar
Images: 9
Excactly and don't "ride shifter against the "left" gate too much. That only makes the tight feeling more so. Glad to see you folks are getting this settled in. Except for the chatter in the clutch that took a few thousand miles to settle in I've been lucky. Must have gotten a sober highly caffeinated tech that built mine.
04 Skip Barber Race School, Competition certificate
04 Jaguar XJ Vandan Plas Radiance Red Ivory leather
08 Isuzu Ascender Lux Flint Grey, Grey leather
10 Lotus Evora Persian Blue, Charcoal w/Ivory header
11 BMW Xdrive35d, Vermillion Red w/Cinnamon Brown
2005 Elise gone but never forgotten as it taught me to drive quickly!
brgelise is offline   Reply With Quote
