#21 (permalink) |
Hi Ramtin
Re last 2 sentences. Did you mean 1) It's NOT only IPS. NA and S cars will have the exact same issues. or 2) It's only IPS. NA and S cars will NOT have the exact same issues. You have me worried now. If there are issues will a rolling road run with an emissions plot show it up? - Feel Free to PM me! Regards Spunagain |
| Sponsored Links | |||
Advertisement | |||
#22 (permalink) |
wolfman,
The Exhaust note will be quite a bit louder than stock with the KomoTec Kit. I really like it. ECU Programming: You can order the self-programming kit from KomoTec and do it yourself. It's however quite expensive. Komo-Tec OBD Flasher - KOMO-TEC Online
Evora S Chrome Orange, loaded - KomoTec Stage 1 - Pioneer HU Nissan GT-R 2012 (550HP) Black Edition - Flapped exhaust - Racing brakes - Spec-V Wheels Nissan 370Z Roadster Pack - Black Cherry - unmodified Mini Cooper S (Turbo) Convertible - Black - unmodified Sold: McLaren MP4-12C, Nissan GT-R 2011 |
#23 (permalink) | |
Just happy to be here
"A typical acre of Florida land produces an average revenue of three cents per year in falling cocaine bales." |
#24 (permalink) |
Plug Whisperer
I'm not really wanting to get into a big to-do about this, and perhaps it's been addressed in another thread already? I like the guys that make the part, I don't have, nor do I want to or intend to make a competing part. But the part is flawed and that flaw is a big issue to IPS cars and S cars particular, IMO (and Lotus’s).
The problem is that there was a general lack of understanding about MAF based systems when the part was designed. The strategy used broke a few fundamental rules that should be respected with a MAF based EMS. 1) The ID of the MAF tube was *changed* from OE specification. Any change in the ID of this portion of the intake (where the MAF is located) will have a significant impact on the calculated airflow. When the airflow is miscalculated, the calculated engine load becomes incorrect or different from what the ECU expects, and that can impact a whole host of things--- like the fuel and spark introduced to the motor.... and the shifting on an IPS car. We know that the ECU is miscalculating load in this particular application as a result to the intake. 2) There was no air straightener incorporated to the CAI intake system like there is on the stock system and the MAF sensor is in proximity to a curve. Without a straightener, airflow metering becomes unstable and will change erratically based on air speed in the tube. This lack of air straightener contributes to more of the problems as explained above. 3) The filter used is an offset design. We've seen firsthand in the data that the orientation of the filter will impact, greatly, the metered airflow which is certainly a problem working in concert with the lack of an air straightener. After looking at a lot of data from cars with the CAI intake system, the power it "makes" is not primarily due to airflow or availability of air to the motor. Rather it's due to manipulating the measured airflow the EMS "sees" that results in a significant leaning of the AFR and greater spark timing due to “tricking” the ECU into miscalculating the load. Consequently, the IPS cars will tend to not shift correctly and possibly fail. As for manual trannys, the issue isn’t the tranny, but rather one car may run differently than the next, and “differently” is outside of what the Lotus or otherwise engine tuner had in mind. IMO, the S cars should tread very lightly when considering changing the intake as well since they’re more susceptible to engine failure from ECU load manipulation. For those of us who have been around the lotus scene for a while, a similar learning curve took place on the 111 platform circa 2006ish… (Good-gawd, time flies, it's ~2013!! )
2005 GG Elige, Rev400, EFI, Race Car, 400+whp | 2005 GG Elise, Rev310, Street Car | 2006 CO Elise, Rev300, Steet Car www.boefab.com: Lotus Performance Engineering and Service Specialists BOE The Awesome ClamHinge | BOETVS SuperCharging, The Most Powerful Track-Worthy Forced Induction | EFI Engine Management | BOE The Essential Fuel Starve Solution | BOE Lotus Tow Package | BOE New-Tech Lotus Race Engines | Custom and off-the-shelf ECU Tuning![]() Engineering & Innovation by Lotus People For Lotus People Somethin ain't worth do'n, if it ain't worth do'n right
#25 (permalink) |
turbophil,
Interesting read. Your comments reminded me of a thread I stumbled upon on another forum related to a cold air intake that is being developed by Torque Developments International (TDI) to allegedly be better than and address certain shortcomings of the Radium cold air intake. It would appear that TDI came to a similar conclusion that the power gains are related to air flow metering. However, it would also appear that TDI came to the opposite conclusion regarding how the gains due to the air flow metering are achieved. That is, it is urged that the Radium cold air intake provides a more accurate metering than the stock setup and that providing an even more accurate metering would yield additional gains. The thread at the forum I’m referring to is: Cold Air Intake PLUS from TDI - Engine & Ancilliaries/Gearbox - The Lotus Forums In the above-linked thread it states that: "Work has revealed that the standard Evora air intake system is even more 'orrible than those of us (us amateurs, that is) that have looked at it, appreciated. It is now better understood why the Radium CAI gives such a boost, and slightly better fuel efficiency, and explains why my earliest reports observed "cleaner sound" and "more relaxed" running at idling and low power. (Words to that effect - I've not looked back.) At mid and high powers of course other more dramatic effects take over! (And the work answers those who refused to believe such a simple change could be so beneficial.) The airflow metering is carried out by sampling just a fraction of the flow at one side of the intake tube. (I've heard the figure of 5% stated.) The standard intake system disturbs the flow so that it is not evenly spread within the tube. Perfection would not be obtained by any system, but the CAI give less disruption and so the metering is more accurate - hence more efficient performance. More power, less fuel! That is in addition to the other benefits of less restriction, resonant length and colder air, of course." Last edited by Beophile; 11-21-2012 at 12:54 PM. |
#27 (permalink) |
Hi Turbophil
Thanks for an interesting and somewhat worrying post! Do you think there is a bolt on fix - perhaps a combination of a sleeve to correct the ID at the sensor and an additional air straightener (is that a collection of vanes before the sensor?) I think you are suggesting the orientation of the pipe is critical - could I diagnose the risk of running lean on a dyno while monitoring the emissions at the tail pipe? Cheers Spunagain |
#30 (permalink) | |
Likes to rent cars.
And adding to Beophile's obervation, BMW E46 M3 has a similar MAF setup. GruppeM offered their CAI system on the E46 M3 and what they did right was to reuse the OEM screen (straightener). Even then Ground Control released a different screen design called the GC Gizmo. Supposedly better. Wonder if that can integrated into the radium tube.
2011 Evora (New rental from Dollar Car Rental.) 2009 Exige S260 (Still with Hertz rental. GPS unit free every month.) 2005 Elise (Enterprise rental took it back cos I farted in it.) |
#31 (permalink) |
On a side note, has anyone found any hp gains with a Larini exhaust? I've searched threads which usually relates to how good it sounds. I've found Sector 111's post dyno which has 252 hp. Thanks.
2005 Lotus Elise- SOLD 6/9/07 2011 Lotus Evora - SOLD 4/18/13 2011 Lotus Evora S |
#35 (permalink) |
The Kold-Fire/Komo-tec tune is loaded into your existing ECU while in your car.
'12 Evora S GP Special Edition #1 of 15 - and what put Special in "Special Edition": ~ 400 Hp, Komo-Tec Evo-Ra 390 Kit, BOE/Kold-Fire Tune, BOE Intake, Larini S Silencer, Lotus Racing Oil Sump, Chimera CBS Lithium Battery, & other bits. Lotus Driving Academy Level 3 School 1:1 w/ Ed Morris @ Hethel ... new to Pistons, my 3 track toys have Rotaries |
#36 (permalink) |
Are you sure it was the CAI and not the fact that you turned a na car into a S? If you ran lean and blew up your car that is a tuning problem and not a part problem......these are the risks we take when we decide to modify our cars...... You could have had the problem with the hacked up Camry intake you put on your car and a factory sc kit if the tune was bad.
You can run rich all day long........ Only takes one lean spot in a tune to ruin your day though..... Sorry about your car. Last edited by creaturekris; 11-21-2012 at 09:10 PM. |
#40 (permalink) | |
Would you also expect that the apparent power advantage will be, after some time, eliminated by the long term fuel trim of the ECU?
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
