Service Bulletins - LotusTalk - The Lotus Cars Community
Old 10-06-2011, 05:56 AM   #1 (permalink)
U.S. Cobra Distributer
SirLotus's Avatar
Service Bulletins
SirLotus is online now   Reply With Quote
Old 03-01-2012, 05:33 AM   #2 (permalink)
Lotus Air - fly lighter
EVORA S Clutch pedal failure
Saw the original SB, don't have a copy. I had this one done yesterday:
Applicability: Evora S
Issue: Clutch pedal falls to the floor, resp. loss of clutch action
Cause: Boiling hydraulic fluid due to overheating in the engine bay
Correction: There is an additional piece of thermal insulation, that should be mounted on the hydraulic line close to the clutch cylinder. The hydraulic line then has to be vented and refilled.
My clutch pedal fellt through when I started the car on Monday. After pulling it all the way back up I was able to return home (300 KM), but with a very soft pedal. Afterwards I recollected, that the pedal had become softer over time, I've done a lot of high speed driving, so the engine bay gets very hot in that area.
The dealer didn't have the riginal thermal covering, but he improvised. Draining the system was acutally the much bigger chore. Its really tight under that engine and the cluth only refills at the very top end of the pedal (which meant holding it up until all the air was out.
tbd_Evora is online now   Reply With Quote
Old 03-01-2012, 09:41 AM   #3 (permalink)
Lotus Addict
squidward's Avatar
Images: 19
Recall on Door Latch Mechanism
Service advisor informed me they performed a recall on both of my door latches when I was getting other work done.
It would be nice if someone had a copy of this recall notice.
squidward is online now   Reply With Quote
Old 03-01-2012, 10:03 AM   #4 (permalink)
brgelise's Avatar
Images: 9
Will be interesting to see if half the clutch issues on the 2010's were caused by the same thing??? Once the throwout becomes inconsistent, it opens the doors for all other kinds of unintentional abuse like missed shifts, grinding, effectively "dropping the clutch" etc.
04 Skip Barber Race School, Competition certificate
04 Jaguar XJ Vandan Plas Radiance Red Ivory leather
08 Isuzu Ascender Lux Flint Grey, Grey leather
10 Lotus Evora Persian Blue, Charcoal w/Ivory header
11 BMW Xdrive35d, Vermillion Red w/Cinnamon Brown
2005 Elise gone but never forgotten as it taught me to drive quickly!
brgelise is online now   Reply With Quote
Old 03-01-2012, 10:51 AM   #5 (permalink)
the esprit also suffered from clutch line problems, often referred to as "red hose problems" because the line was red. it was plastic/rubber and would expand when hot.
the solution was and is, to install a braided stainless steel line, available from the usual suspects.
tomas
87 esprit
tomas87lot is offline   Reply With Quote
Old 06-16-2012, 12:07 AM   #6 (permalink)
Here the original SB
File Type: pdf sb_2011_29_Evora_Clutch_Pipe_Insulation.pdf (323.8 KB, 296 views)
Old 09-13-2012, 08:09 AM   #7 (permalink)
Can anyone tell me what service bulletin 2010/14 was for exactly?
Thanks
Simon
2010 Evora Carbon Grey Click this link for LOTS of pictures.
2004 Lingenfelter Corvette
2005 Yellow Elise (Sold)
My Tour of the Lotus Factory
manike is offline   Reply With Quote
Old 09-15-2012, 01:00 PM   #8 (permalink)
Omm
I was wondering if this clutch problem is indigenous to all evoras or are there just a few with this problem? I am looking to buy a 2011 evora and I am holding back after reading all the messages about the clutch.
Omm is offline   Reply With Quote
Old 09-17-2012, 10:17 AM   #9 (permalink)
brgelise's Avatar
Images: 9
Handful of cars. Mine has seen track duty with NO issues (NA)
Skip barber has a few for their driving school and none have had the issue either. They don't get much hotter than that. Anyone with fluids more than a year old should bleed their lines to get the coke colored fluids out! That's the real problem I bet.
Old 11-21-2012, 12:55 PM   #10 (permalink)
The clutch problem is with all cars and it is hard to bleed pedal needs to be at the top to do it.
When the car is used worked hard in hot temperatures summer heat soak causes fluid to boil air stays in the system eventually causing pedal loss. the solution is to bleed replacing fluid with AP racing 600 fluid has higher boiling temp no problem after that even with heat shield it boils on original fluid when worked hard.
trevleg is offline   Reply With Quote
Old 11-21-2012, 01:11 PM   #11 (permalink)
wait what?
Plackslayer's Avatar
My master cylinder had to be replaced - and post that Motul 600 was used. No issues after that - including a good track day. No fade or spongy brakes at any point all day.
Plackslayer is offline   Reply With Quote
Old 03-06-2013, 06:54 AM   #12 (permalink)
ravencliff's Avatar
How about having the dealer prophyllactically place a thermal barrier on the line before problems arise??
ravencliff is online now   Reply With Quote
Old 03-06-2013, 08:31 AM   #13 (permalink)
Julian73's Avatar
That is what the service bulletin calls for.
'12 Evora S GP Special Edition #1 of 15 - and what put Special in "Special Edition": ~ 400 Hp, Komo-Tec Evo-Ra 390 Kit, BOE/Kold-Fire Tune, BOE Intake, Larini S Silencer, Lotus Racing Oil Sump, Chimera CBS Lithium Battery, & other bits. Lotus Driving Academy Level 3 School 1:1 w/ Ed Morris @ Hethel ... new to Pistons, my 3 track toys have Rotaries
Julian73 is offline   Reply With Quote
Old 03-17-2013, 03:43 PM   #14 (permalink)
ravencliff's Avatar
The service manager at Galpin was uncertain as to whether or not using Motul 600 would be a warranty issue with Lotus. I know it exceeds what Lotus recommends, but that isn't a bad thing in this instance.
Any first-hand knowledge regarding this?
Old 03-17-2013, 07:44 PM   #15 (permalink)
Julian73's Avatar
Motul RBF 600 is a DOT 4 fluid (as specd in owner manual) so Lotus can not hold it against warranty.
Old 03-17-2013, 09:07 PM   #16 (permalink)
ravencliff's Avatar
Thank you.
Old 03-19-2013, 12:27 AM   #17 (permalink)
Lotus Addict
squidward's Avatar
Images: 19
Re: Service Bulletins
How would they know anyway? Just like how would an owner know if the correct oil was used in an oil change by a service facility? Seems a rather pointless concern (unless of course the fluid color was obviously different, but I don't believe that's the case).
They all do that, sir.
