Wrench light and sensors - LotusTalk - The Lotus Cars Community
 1Likes
post #1 of 26 (permalink) Old 07-09-2012, 01:08 PM Thread Starter
HI,
I am wondering if any you have had similiar problems. My car is 3 months old. I have been getting the "wrench" light on the dash and the Airbag warning light repeatedly.
1. for the wrench light . the dealer said it had a bad clutch sensor. It has now been in twice for the same thing. (the entire part was replaced once already)
2. the airbag thing.. they said there was corrosion on the wiring harness. They cleaned it and it went away.
In all instances, two days after I get home from the dealership, I get the airbag warning and the wrench light again. I have had the vehicle in 3 times for this same problem. !!!!! I am about ready to take the car back, hand them the keys and move on.
any thoughts?
Pete.lotus is offline
post #2 of 26 (permalink) Old 07-09-2012, 03:02 PM
Same problem with my 2012 S IPS. I haven't seen my dealer yet... Will keep you advised if they find a solution.
Is a Porsche Cayman S quicker and faster? Yeah, probably, a little, if you judge things so parlously as to measure your life in tenths of a second. The Evora is a connoisseurís car, a driverís shibboleth and secret code, a prime number of a machine that is indivisible by anything other than itself.
Captain is offline
post #3 of 26 (permalink) Old 07-09-2012, 03:25 PM
hifiandmtb's Avatar
My wrench light was related to a faulty brake light switch (the one that sits on the brake pedal). All good now.
ex- 2010 Lotus Evora Starlight Black 6-speed manual
hifiandmtb is offline
post #4 of 26 (permalink) Old 07-10-2012, 04:57 PM
just curious - today twice my wrench light came on when i first started the car and stayed on until i drove about 50 feet, and then it went out. anyone experience anything similiar?
Asulil is offline
post #5 of 26 (permalink) Old 07-10-2012, 05:26 PM
Jonathan's Avatar
Check your manual, if it stays on for 30 sec I think there's a minor fault/ problem
Jonathan is offline
post #6 of 26 (permalink) Old 07-10-2012, 11:09 PM
squidward's Avatar
it's a minor fault.. I wouldn't worry too much about it.. happened only once to me a long time ago.
squidward is offline
post #7 of 26 (permalink) Old 11-15-2012, 09:44 PM
I have nothing material to add, other than your dealer seems to be guessing rather than finding the root cause. Switch to another dealer if you can, or speak to Lotus yourself and get a code scanner.
2009 Elise SC
Surge is offline
post #8 of 26 (permalink) Old 11-16-2012, 05:19 AM
anthonyseven's Avatar
Yes.
In the beginning it was just the wrench/spanner light coming on intermittently. Eventually (about a year after delivery) it progressed to the airbag warning light, and increasingly frequent spasms of the traction control system and engine stalls.
A defective seal on a water temperature sensor was slowly weeping coolant, which contaminated my engine harness. It eventually wicked its way to the ECU connector, where it started to cause random shorts between the pins. This is not a very common failure mode, but keep it in mind if the mechanics cannot find the cause.
I was lucky to have TJ at Fox Valley troubleshooting the problem on my car, he discovered the cause rather quickly.
I was unlucky in that I had to wait months for a new engine harness.
anthonyseven is offline
post #9 of 26 (permalink) Old 11-16-2012, 07:05 AM
Justin182's Avatar
The wrench/spanner light is a warning to say something is about to go wrong, rather than something has gone wrong.
I've had it a few times and its normally gone once I've refilled with petrol. (dodgy batch maybe)
Justin182 is offline
post #10 of 26 (permalink) Old 11-16-2012, 07:44 AM
Disciple of Chapman
Chhirowolf's Avatar
The "wrench light" comes on in my car everytime I start it and stays on for about 30 seconds and then goes away. is this normal. dealer says
Chhirowolf is offline
post #11 of 26 (permalink) Old 11-16-2012, 08:05 AM
tbd_Evora's Avatar
No, its not normal - it indicates a non-critical fault that your dealer should fix. They definitively DO NOT all do that!
tbd_Evora is offline
post #12 of 26 (permalink) Old 11-16-2012, 08:38 AM
Disciple of Chapman
Chhirowolf's Avatar
Think it is time for a road trip to a new dealer. So far my dealer has fixed nothing, and worse in some cases made things worse. All fixes have been done by myself with help from this Forum.
I live near St.Louis, but I think I may take the car to Chicago.
Any suggestions.
post #13 of 26 (permalink) Old 11-16-2012, 11:55 AM
Sven76's Avatar
Mine never had that, although it was quite common for the Eliges.
2011 Evora S 2+0 // carbon grey // diamond cut rims // charcoal leather // Schroth Rallye 3 ASM harness // Moroso oil pan // after-cat delete
Sven76 is offline
post #14 of 26 (permalink) Old 11-16-2012, 11:59 AM
brgelise's Avatar
Let's talk about the airbag light and things to look for
16 Range Rover Sport HSE, Montalcino Red w/Ivory Leather-->stunning
12 Maxda MX-5 Miata GT PRHT True Red/Black leather (LUCY)
11 BMW Xdrive35d, Vermillion Red w/Cinnamon Brown Leather
08 Isuzu Ascender Lux Flint Grey, Grey leather
brgelise is offline
post #15 of 26 (permalink) Old 11-16-2012, 12:27 PM
RWLott's Avatar
wrench light
I was told the 30 second wrench light was due to the cruise control not working correctly? It is currently at the dealer for a cruise control fix - parts were ordered.
Also the car has several error codes that will not clear - mainly cylinder misfire codes.
It temporarily generates a variety of error codes (check engine light, wrench, transmission solenoid, etc., etc.) whenever it is washed. I told them this has to be corrected, else it will not pass E-Check.
I'm keeping my fingers crossed.
Moisture working its way into the ECU sounds like a possibility?
2012 IPS Evora 2+0 Starlight Black, 2012 Elantra, 2005 Astro Van
[SOLD]2005 Elise Starlight Black, hardtop, touring pack, Larini Sport Style exhaust.
RWLott is offline
post #16 of 26 (permalink) Old 11-16-2012, 01:07 PM
tbd_Evora's Avatar
More likely a cable issue within the engine bay. Check the engine harness connector.
Lckitty likes this.
post #17 of 26 (permalink) Old 11-16-2012, 02:21 PM
Plackslayer's Avatar
My wrench light only comes on when I insert the key while all lights are going on - it turns itself off shortly there after - not 30 seconds worth.
Plackslayer is offline
post #18 of 26 (permalink) Old 11-17-2012, 07:21 AM
Regarding clutch sensor:
'11 Evora engine stalling on deceleration with clutch in
Evora S Chrome Orange, loaded - KomoTec Stage 3s - Larini exhaust - Pioneer HU - custom interior
Nissan GT-R 2012 (550HP) Black Edition - Wrapped in red - Flapped exhaust - Racing brakes - Spec-V Wheels
Mini Cooper S (Turbo) Convertible - Black - unmodified
Range Rover Evoque Prestige Si4 - loaded
Sold: Nissan 370Z Roadster Pack - Black Cherry - unmodified
Sold: McLaren MP4-12C, Nissan GT-R 2011
dmpriso is offline
post #19 of 26 (permalink) Old 11-17-2012, 07:53 AM
tbd_Evora's Avatar
That is the system self test. You can find the full list of Error Codes here: http://db.tt/BOZbkw1k.
Just search for MIL or "Service Light" in the document to see under which faults the Engine or Wrench lights come on.
post #20 of 26 (permalink) Old 11-18-2012, 08:34 PM
Yeah - I was just mentioning it to show it is normal.
I have no issues and no fault codes. I check periodically.
Human Verification
