Wrench light and sensors - Page 2 - LotusTalk - The Lotus Cars Community
 1Likes
post #21 of 26 (permalink) Old 11-19-2012, 04:25 PM
RWLott's Avatar
Error Codes, etc.
Originally Posted by Plackslayer View Post
I have no issues and no fault codes. I check periodically.
Have you connected a reader to your car? I have permanent error codes, but no error code icons, e.g., check engine, wrench, etc.
Error code icons would appear after washing the car. The dealer washed it three times, thoroughly hosed it down, and was unable to generate any error codes. The tech put some dielectric sealant on some of the connectors - apparently fixing my problem.
The explanation given for the error codes is:
As for the codes, those are stored history codes; not active failures. Codes are from misfires; mostly commonly at cold start ups. Ben consulted with factory and everything cleared with them. When we hook up the factory computer, it stores a fault memory. None of the codes in the fault memory are active or present. They are readable; but not active failures.
Will have to see if the folks at E-Check will accept "stored history codes" as OK.
2012 IPS Evora 2+0 Starlight Black, 2012 Elantra, 2005 Astro Van
[SOLD]2005 Elise Starlight Black, hardtop, touring pack, Larini Sport Style exhaust.
RWLott is online now
post #22 of 26 (permalink) Old 11-20-2012, 03:38 AM
Plackslayer's Avatar
I use Torque (Android app) and don't have any.
Plackslayer is offline
post #23 of 26 (permalink) Old 11-20-2012, 05:08 AM
tbd_Evora's Avatar
Glad to see your problem was solved.
Those historic codes are to support problem solving when there is a current active fault. Misfires and such can happen under numerous conditions, so by themselves they wouldn't be a problem. But they would be an indication if ssomething else is going wrong (such as an engine that dies when cold or wet).
tbd_Evora is offline
post #24 of 26 (permalink) Old 06-30-2016, 04:34 PM
I get the wrench icon every few start ups. Not every time. My car will occasionally stutter on a cold start up. Sometimes it wont even turn over after turning the key. You will hear the starter solenoid click and then nothing. Generally starts up after one or two other tries. Already replaced a busted starter and the battery is good as new. Do you have to have a lotus dealer specific scan tool to narrow down codes shown by the wrench icon? Thanks guys.
2011 Lotus Evora NA 6spd. White with red/black interior
Conan O'Brien is offline
post #25 of 26 (permalink) Old 07-01-2016, 10:22 AM
Chaos's Avatar
Yes, lotus techcenter is the only way to read these codes. Unfortunately the scanner from lotus will cost you about 5 grand. Best off going to the dealer to have them read
Any engine light can be checked with a universal reader as it is a standard protocol
Chaos is offline
post #26 of 26 (permalink) Old 07-02-2016, 12:26 AM
Thanks!
Human Verification
