Old 10-07-2008, 09:48 PM   #1 (permalink)
About to install the BWR SC....am I nuts?
Ok, I have the SC....
Once the BWR is installed is it drive and forget or will it need constant care and feeding?
I am not having buyers remorse with the SC but..I don't want to ruin the Elise by by making it into a time and money suck.
So, any BWR owners out there who care to chime in about your ownership experience?
Plug and play or install and regret?
Louie is offline   Reply With Quote
Old 10-07-2008, 09:49 PM   #2 (permalink)
Live to Drive
Bavarian Motorist's Avatar
Just make sure she's well oiled.
Old 10-07-2008, 09:51 PM   #3 (permalink)
Seb
<3 QR25DE
Seb's Avatar
Plug and play, but get a wideband and monitor it.
Wideband = peace of mind.
Seb is online now   Reply With Quote
Old 10-07-2008, 09:53 PM   #4 (permalink)
Ok guys...
thanks for your answers....
now, more questions...
"Well Oiled" meaning added oil coolers beyond OE?
Wideband. meaning sensor?
Old 10-07-2008, 09:55 PM   #5 (permalink)
Live to Drive
No, you don't have to add oil coolers. Just check oil level every so often to be safe. Best to be oiled.
Old 10-07-2008, 09:57 PM   #6 (permalink)
Seb
<3 QR25DE
Seb's Avatar
A wideband basically monitors your a/f ratio real time. It is a great indicator if anything is going wrong, or if the engine is running hot etc...
Old 10-07-2008, 10:00 PM   #7 (permalink)
any reason to upgrade to the Moroso (sp) oil pan?
Old 10-07-2008, 10:01 PM   #8 (permalink)
Randy Chase's Avatar
Images: 761
If you do track days, specially with sustained sweeper turns.
Lexus GX-470 tow vehicle.
Old 10-07-2008, 10:21 PM   #9 (permalink)
Seb
<3 QR25DE
Seb's Avatar
I would only invest in that oil pan if like Randy said, you are a track junkie. All it does is prevent all the oil from being up against one side of the oil pan, starving the other side of oil. It would need to go on for an extended period of time for that to actually be a problem.
Old 10-07-2008, 10:42 PM   #10 (permalink)
Mediocrity is a sin.
cspak71's Avatar
Images: 9
recommendations for wideband? Also, outside of the new wideband sensor, does one need other equipment?
The wideband just replaces the OEM O2 sensor right?
'05 SY Elise
cspak71 is offline   Reply With Quote
Old 10-07-2008, 10:47 PM   #11 (permalink)
Seb
<3 QR25DE
Seb's Avatar
No you shouldn't just tap into the stock o2 sensor. Most would say it shortens the life of them, so I would recomend having a second bung welded in. With that said, there are some that use the stock o2 sensor just fine.
I personally like the AEM Uego for its style and functionality.
As far as other eqipment goes, you could choose to get a boost gauge, but with SC's its not as critical. Its all for peace of mind. The cool thing with the AEM is that it is a 6-in-1 gauge so you can flip between boost and what ever else, without having to mount multiple gauges all over the place.
Old 10-07-2008, 10:57 PM   #12 (permalink)
cspak71's Avatar
Images: 9
Interesting.. could you elaborate on what you mean by tapping into the O2 sensor? I assumed that the wideband is a more sensitive equivalent of an O2 sensor.. so you could remove the OEM one, and put the wideband in there...
I'm not sure if I understand how that affects the life of the sensor?
Thanks for clarifying.
'05 SY Elise
Old 10-08-2008, 09:53 AM   #13 (permalink)
Seb
<3 QR25DE
Seb's Avatar
If you buy a wideband with its own sensor, it is pretty much the equivilant to an o2 sensor. What I meant by tapping into the stock one is that you can use it to get the readout for the gauge as well as transmit to the ECU.
Basically the ECU is already reading the A/F ratio and logging it as you drive from that same o2 sensor. What I mean is simply splicing into it so now you have the gauge hooked up to too.
From what has been explained to me, it has something to do with two different systems being hooked up to it creating a higher electrical demand from it. For some reason they just burn out much quicker.
Old 02-19-2009, 11:10 PM   #14 (permalink)
the need for speed
Addictedto's Avatar
Images: 18
Hey louie, did you ever install the SC? Any updates? Hows it running etc.
Addictedto is offline   Reply With Quote
Old 03-02-2009, 01:36 AM   #15 (permalink)
the need for speed
Addictedto's Avatar
Images: 18
Hellooooooo, any one watching this? Did you ever do the install? If your still on the fence you should just send the supercharger kit to me, I like wrenching on stuff, I promise I'll put it to good use and give it a good home. I'll even post lots of pictures every month and give you visitation rights.
