Old 06-26-2008, 01:24 PM   #1 (permalink)
Bruised thighs daily
Tracktimeplz's Avatar
@Charliex
So since Forcefed has no solution for my FF275+unichip other than "Get the EFI"(At 3k+) How much would you charge for a custom tune/ecu for this kit?
LSD, Power steering, A Jedi craves not these things.
2005 Magnetic Blue Elise
Forcefed 275 turbo SSR comp Wheels
Tracktimeplz is offline   Reply With Quote
Old 06-26-2008, 02:20 PM   #2 (permalink)
disproving HD MTBF daily
charliex's Avatar
depends on the length of time it takes to do the base tune, i usually charge $100 ph and any travelling expenses if its out of my usual area.
it also depends a lot on how well the car is setup, if say for instance the fuel pressure kept changing it'd take longer, the boost wasn't consistent, something was bad etc. etc.
sometimes it can be baselined in a working day, others upto 4 days, then with a couple of hours here and there making little tweaks, some owners just want it setup to where it just 'works', which means they're happy with all the little pecadillos, others want it absolutely perfect, which just takes time.
what sort of dyno used also affects time, i'm happiest with a dynopak, then a steady state capable dynojet, then everything else, having an operator thats not a muppet also helps, as well as having people to wrench or fix any immediate issues.
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660
Old 06-26-2008, 02:23 PM   #3 (permalink)
Do you have a contact email? Didnt see it on your site
Old 06-26-2008, 02:46 PM   #4 (permalink)
2006 Lotus Elise
akandok's Avatar
X2 on the email...
“The biggest cause of trouble in the world today is that the stupid people are so sure about things and the intelligent folks are so full of doubts.”
Bertrand Russell
John 3:16
akandok is offline   Reply With Quote
Old 06-26-2008, 02:56 PM   #5 (permalink)
charliex's Avatar
Contact Info
HTML code is On
