Old 08-04-2009, 05:35 PM   #1 (permalink)
w00t
Tang0_au's Avatar
Crank & cam sync / timing
this might be a bit of a long shot, but does anyone know if the 2zz uses the same crank trigger and cam trigger / sync as any other toyota engines ?
for example, i know for a fact that the 1zz-fe uses the same crank / cam triggers as the 2nz-fe
Thanks
1zz Elise Blown by Rotrex:
Build Thread: http://www.aussieelises.com/forums/i...showtopic=9609
Tang0_au is offline   Reply With Quote
Old 09-13-2009, 09:05 PM   #2 (permalink)
choi0706's Avatar
easiest way is to contact your local toyota parts dealer..
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 09-15-2009, 08:27 PM   #3 (permalink)
w00t
Tang0_au's Avatar
doesnt really help - if the part numbers are the same or not if its a different trigger then its not going to work.
