#81 (permalink) | |
Future 2ZZ-GZE member...
I think the stock rev limit is still pretty safe. I've beaten it to hell and back with perfect 8,400 rpm shifts many times, and my econobox is still holding up fine. But then again...I only go in a straight line
. But I guess you guys won't exactly be holding out accelerating through a corner, and not taking advantage of the extra revs...If you're going to stay on the stock motor, that would be even more reason to invest in a J&S safeguard, assuming they come out with the new version sometime before we turn old, unless it's out now.
#82 (permalink) | |
Twisties Addict
This "idle issue" Is the only thing holding me back. Im very saddened that the only solution to the problem is $1k fix to what is supposed to be a complete product out of the (package). Its not really a package if you have to buy a $1k module to make the package work properly. As of right now i guess i will have to sit back and wait for somebody to figure out the problem or wait on another product to bring my Exige S to its proper Power level. ![]()
-Aspen White Exige S ![]() 04' Lexus Turbo IS300 BSM "track car"--SOLD "Straight lines dont mean sh**" |
#83 (permalink) | |
Dynamic Racing Solutions
The reason there is an additional module for the DBW cars is b/c the system was originally designed for the '05 non-DBW cars. Instead of redesigning the entire ECU around this (not a realisitc option at this volume) we opted for the external DBW controller. The fact is that even if you spend an extra $1K for the DBW control you are still getting a pro-level ECU system for much less than what other comperable motorsport level systems would cost. We know there are less expensive tuning solutions out there. But if you're looking for a self-editable ECU with powerful software this is the product. |
#84 (permalink) |
There are many advantages to having the EFI stand alone. I started looking into what equipment was needed to monitor my Lotus ecu tune. The simple
ODBII scanner with canbus doesn't work well on the Lotus. Especially the 06 and up cars. There's a delay and some have reported the info is incorrect or inaccurate. I had / have an A/F gauge but thats not enough. How could I monitor timing, fuel etc? Not an inexpensive undertaking. I want to add headers and intake. The Lotus ecu would have to be reflashed. The reflash wouldn't give me me max HP. It's flashed on a bench half way across the country. It will be in the ballpark but not tuned to my car, altitude, etc. With the EFI you can monitor everything real time. A great side benefit I think. External data logging for the Lotus ecu would be at least $2000.00 I'm no expert but the upside on the EFI is huge. I can tune for max HP and change my car configuration anytime I want. I can add a second map for 100 octane. I can change my rev limit for city driving etc etc. I too had sticker shock when I first looked at EFI a couple of years ago. I really didn't understand everything it could do. Now I consider it a bargain. my 2 cents
2005 Elise Storm Titanium |
#85 (permalink) |
I'm Back!
I've been gone for a while and did not read this entire thread. My experience with the EFI has been nothing but positive, but I did use it on an '05 non-DBW car. On my FF 340 Elise it made much more power than the Unichip piggy-back that I had at the time (I realize that with the other solutions out there that the Unichip is propably really old news that no one even talks about anymore; the new guys probably don't even know what a Uni-chip is
), and it was much smoother and allowed for much more control and better multiple maps and ...etcThis was back in Mar of 2007 when Casey flew out to install and tune the EFI on my 340 Elise and it was excellent then; with all of the work done since then and experience gained by Khris and Casey, it must be better than ever right now. As for DBW idle issues; that does suck. If the $1K solution works perfectly, then I personally would pony up the cash.
2008 Boxster - Ruby Red/Sand Beige Leather - Gay Options - Good car, but very gay 2008 997 GT3 - Carrara White/Black - PCCB/Carbon Package/Yellow Belts - Lots of weight reduction Past Lotus Cars: 2005 NFB Elise, 2007 CO Exige S, 2005 AR Elise, 2008 Exige S 240 |
#86 (permalink) |
Hydrocarbons Rule
Tagged for future reference as I plan on doing this some time in the future..
06 Exige; BWR Supercharger, Adj Sway Bar, Ohlins 2-way Suspension, BSK Oil Catch Can, Moroso Oil Pan, ORC Super Single Clutch, Arqray Single Tip, Work Emotion CR-Kai's w/ RT615's, 2 piece rotors, Pagid Blue pads, BSK Wet Carbon (Side Skirts, Front Lip Spoiler, Gas Cap Cover, Center Console, Door Pannels), Dry Carbon rear Diffuser, Harness Bar, HKS Boost and Oil Temp Gauges, BWR Gauge Mount, Sabelt Harness, JVC Head Unit, Alpine Sub Woofer, Polk Audio speakers, OMP Superquadro steering wheel. |
#88 (permalink) |
The freedom of EFI.
Just installed a nice intake. No CEL worries here. I'm not going to mention the extra 20hp I have gotten so far (just EFI and Phil's map). New HP doesn't include new headers, smaller pulley and intake. New dyno next week.
2005 Elise Storm Titanium Last edited by jim-clayton : 07-18-2008 at 07:32 PM. |
#89 (permalink) |
Congrats
2005 Elise 250 whp | Forcedfed Custom Intercooled Supercharger | EFI | Forcedfed Street Header | Fujita CAI | TB Bypass | Toda flywheel | ACT HD Clutch | Forcedfed Prototype Exhaust | Micromirror | Forcedfed Half Carbon Splitter | Greddy Catch Can | ForcedFed Engine Damper |
#90 (permalink) |
Plug Whisperer
Ah, the power of tuning!
![]() I didn't have time to perfect things really and I'm obviously not tuning for peak power, I'm just looking for the power under the curve as they say- For me that's 4,000 to 8,000 rpms... Check out the average torque gains ![]() The dip at the came change can be tuned out, but again, it was late in the date and the dyno operator wanted to go home... This is close enough for now though... Best, Phil
| '05 GG LSS Elise | A Track Chariot | BOE ClamHinge | BOE TVS SuperCharger 275whp/175wtq | EFI Standalone Engine Management |See my car at BOE Fabrication: www.boefabrication.com ----->Last Updated: 11/09/08 If something ain't worth doing right, it ain't worth doing at all... |
#91 (permalink) |
Plug Whisperer
For a point of reference, This chart shows Darksol's car today as well. Same dyno, same day... His dynoing was done earlier in the day as he had to go home... I did too.... but than I came back
![]() So I "fixed" the torque issue. Here you can see his Katana tune next to my rough EFI tune... His car has FF headers, bigger TB, and the 2.5" vonhep (I have the 2.25" Vonhep)... He's the green graph and I'm the blue and red with the red being the final for the day... Importantly, the tq is up a bunch and I'm running a lot more fuel... more power on a richer mix ![]() Awe, the power of tuning ![]() Best, Phil
#92 (permalink) | |
The Mad Scientist
![]() AND THE STOCK 3.4" PULLEY... ![]() A couple of weeks ago we were worried about the AFRs with the 3.2" pulley and the Katana tune so until I jump into the fray and get the EFI we decided that the best course of action would be to retrofit the original 3.4" pulley in the kit. After 250 miles of driving the AFR's have come back into the high 12's / low 13's... BUT here's the real kicker... last week I installed a true 2.5" AreaP / VonHep exhaust, replacing my wonderful 2bular unit... which is going up for sale soon! Anyway see the results below - last August's initial SC install is in blue, today's was in red - more HP across the board! Gotta love 230whp out of a stock Katana tune with the stock Katana 3.4" pulley! I think my car's running fine! ![]()
d.a..v...i....d David Thomas Stewart - davidtstewart@gmail.com Supercharged 2005 Graphite Grey Lotus Elise: 230whp, 1843lbs. 12.41 @ 110.0 mph. 300whp @ 1799lbs. or bust! |
#93 (permalink) | |
Looking good Phil. ![]() |
#95 (permalink) |
Mods are good for you
Dave/Phil,
Glad to hear all is well...looking real good! Dave, so what's with the compressions? Something just isn't jiving there. ![]()
Mod Maniac: '05 SY - Supercharged (3.2") TVS soon! . EFI Engine Management . ACT HD Clutch . FF Cold Air . Center Fed Fuel Rail . Catch Cans . PPE FI Headers w/ 2Bular 6" . Ported Throttle Body . Black LSS . Braille 9.5lb B129 . Boot Lid Pin . LED Tail Lights . CF Console . CF A/C Surround . CF Diffuser . FF Half Lip Spoiler . Custom Gut Wing . B&M Shifter . Painted Stripes . Rubbertite Mats/Buttons . S111 Booty. HIDs . LED Lighting . VonHep Dash Bag . Tinted Glass . Tesprit Mirror |
#96 (permalink) |
disproving HD MTBF daily
as far as we've found, the difference in hp between the 3.2 and 3.4 just isn't worth the added effort/stress anyway.
why does phils sheet showing darksols car, look way different to darksols sheet showing his car? its a bit hard to make out.
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660 |
#97 (permalink) | |
Plug Whisperer
Make sense? Best, Phil
#98 (permalink) |
Plug Whisperer
Here ya go Charlie
![]() Here's both forced and seperate scales with just or final runs... Very interesting...Notice when our respective rev limiters went off.___ mine is lower than the Lotus/Katana ECU and I have not changed mine since the valve dropping issue... You can also see how the Lotus/Katana rev limit cuts fuel where the EFI cuts timing (known as the "soft" rev limit) by looking at Dave's AFRs at the rev cut vs. my AFRs... Best, Phil
#100 (permalink) |
ahh ok, i didnt notice the scaling was different that explains it.
the stock ecu cuts fuel and timing, its got a hard and a soft.
