#101 (permalink) |
2007 Exige S
Think this thread has an indexing problem, can't get to the last page, just repeats page 5....oh well.
I didn't install the EFI myself, but wish I had now. Found some issues with how the IAT (post IC) sensor was installed -- no bung (which it should have given the length on the sensor probe) -- if you want to do this right, you want to weld a bung on the post IC tube. I just spent today fixing the crap work that was done to my tubing -- grrrr. If you don't want to do the bung, then use some crush washers (3 or so) and A LOT of sealant and pipe thread. You can do this without the clam off, just take off the driver side tire and remove the wheel well liner -- easy to access. If you want the Serial cable to run into the interior of the car, then you'll need to go thru a wiring gromet in the bulk head -- not a big deal as some have done this without even removing the seat or harness bar or rear plastic panel. As far as tuning goes, I went thru at least 3 tunes and all three of them were total crap (car stalled all the time, 6th gear wouldn't accelerate past 100 mph, idle fluctuation - worse with AC on, completely undriveable on the track -- jumping jack VVT on..off..on..off..on. But, I didn't give up hope... I'm hoping the latest software/firmware revision from Kris and a base tuning from Kris will solve all those problems. If not, well it's back to a stock ECU, sell the car, and go buy a GT-R. Sorry if I sound harshly realistic here, but I'm giving my experience so far. The EFI gets one more shot and if it doesn't come up trumps, it's back to stock. So far it has cost me a small fortune, well beyond the EFI's purchase price. My Suggestions/Comments: 1. Nobody stepping up to the plate and using the "race use only" clause as the way out of responsibility 2. EFI 1.2 (Lotus) should not be provided to "any" installer, especially those that can't install it and tune it correctly 3. Exige S kits based on the EFI 1.2 (Lotus) are still advertised with 2.5" pully (again this will just make EFI look bad) 4. The kit was sold for Exige S before it was really ready and it may still not be ready (wait and see if latest firmware/software fixes all the issues) 5. Certification program needs to be established if you want to retain a solid reputation As much as I respect Kris, these issues should have be addressed BEFORE being sold to Exige S owners. It would have been nice (especially in my case) if Kris had come to me and said he'll resolve all my issues free of charge, but no such offer and it'll cost me another $500-$1000 to get yet another dyno tune from Kris once I get this motor back in the car. How much do I have into this car, just a tad over $102,000 and only about 15-18 laps to show for it and 7,000 miles. Pretty sad actually. Rob.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs Last edited by robains : 10-06-2008 at 08:03 AM. |
#102 (permalink) |
Parts scattered about...
Hi Rob,
My comments are sincere and not intended to start a heated debate, but.. Have you considered asking Charlie for a tune using the stock ECU? He's 'relatively' local to you, seems like an easy fix to a big problem. There are some mechanical issues also, but this would probably eliminate the ECU problems. Good luck getting this going, I know it must be frustrating. John
My car is modified.
#103 (permalink) |
2007 Exige S
I have considered it and it will be one of two alternatives if this EFI 1.2 (Lotus) will not work to my satisfaction. However, I don't think CharlieX is in any position to step up to the plate either -- I've been made aware that ECU issues and engine expires have occurred on both sides of the fence (regardless of pully size). Everyone in this business has an "out clause" - not that it is a bullet proof safety net, but who wants to spend the money to challenge it?
The only positive is that once I finally get this motor in (this week I hope) it will be done with quality and care and I'll have the tools (sensors up the nose) to really look at how to make this a very reliable safe motor. Of course, this IS assuming I don't run into more hack jobs -- I have not inspected how the EFI was wired into the stock harness yet and this "could" be another ugly mess that'll I'll have to fix before dropping the motor back in. Also, I have yet to determine how I'm going to fix my butterfly in my throttle body that was apparently drilled and then JB welded. Called Toyota and they will NOT sell just the butterfly, if I want that fixed it $1000+ new throttle body or spend a day surfing junk yards. I'm looking into finding someone that can weld the holes and then make flush -- I may have a friend that can help out. These holes were drilled in an attempt to "cure" the idle oscillation problem after installing the FF kit. Yeah it is frustrating. More so when I've attached good $$$ to it. Rob.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs Last edited by robains : 10-06-2008 at 10:47 AM. |
#104 (permalink) |
Republic to Thugocracy
Rob-
A standalone ECU, as you and others are learning the hard way, is not a "bolt-on" but rather are designed for off road applications and needs to be tuned by a professional with all the required tools at his disposal (steady state dyno, test track, scopes, full service shop with trained technicians, etc.) No certification need be required. Do not confuse EFI with either DRS or ForceFed -- they are merely marketing to Lotus enthusiasts. Always trying to be helpful and informative... ![]() PS -- I have a buyer for your EFI!
"This is the moment when we must come together to save this planet. Let us resolve that we will not leave our children a world where the oceans rise and famine spreads and terrible storms devastate our lands." Community Organizer and Chief Obama...now intervening with natural occurrences!
#105 (permalink) |
What engine/tune has CharlieX ever had an "issue" with?
#106 (permalink) |
Have not heard of a single engine expiring due to Charlie's tunes (Gotham, Ronin, etc.), I'd be surprised to hear this is actually true.
Hang in there, it sounds like you have some things under control and identifying the problems is half the battle.
My car is modified.
#107 (permalink) |
OSX Black hat
Rob,
I'm more than happy to help you with your tune on the stock ecu, but i've never blown an engine up,.
#108 (permalink) |
2007 Exige S
Don,
I paid for all that "professionalism", it didn't make any difference to the life of motor #1. I appreciate your EFI buyer -- may still be in the cards, but DRS get their shot to make good -- and this time around I'll have the tools to know good from bad. As far as bolt-on, not sure I find the relevance there. I've built and tuned other motors so I'm aware at what is needed -- VVT is the only variance I see here. Still not sure I understand your "off road" reference, my first track experinece with my EFI 1.2 (Lotus) setup was a car that was EXTREMELY difficult to drive on the track due to how the VVT would go into violent convultions as it kept switching the cams. If this is designed for "off road" only then it clearly has a LONG way to go. Some of these issues were able to be tuned out somewhat but at a loss of lower end power/TQ. The entire point of VVT is to provide best of both worlds with smooth low rpm driveability AND good high rpm power. I disagree, certification of installers/marketers and tuning should be required, in fact, if it were required, I think we'd see far fewer problems. As interesting as VVT is, this really is NOT rocket science, and these aren't F1 motors with exotic materials. Sure it's not a bolt on and takes some additional reading/understanding to figure out exactly how the EFI works with the existing sensors and some new sensors. I'll hang in there for a little while, but not going to keep this up forever.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
#109 (permalink) |
OSX Black hat
Unfortunately here is no industry standard for tuning certification, EFI university is trying to become that standard, ben strader is an awesome tuner and well known, and a lot of places have already accepted their certificate, i did that certification last year, but i never use the certificate.
A lot of the certification places are just diploma mills anyway, how to tune can be learnt in a day since its just simple math, but then you pick up all the things that go wrong on the dyno itself, you get the cert after 18 hours dyno i think, i'm around 200 hours and i'm still learning all the ins and outs.
Black Exige S - http://goth.am 265 Mule / Elan M100.ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660 West Coast Lotus Meet - Las Vegas - November 6-9 2009 http://www.westcoastlotus.com/ Last edited by charliex : 10-06-2008 at 12:31 PM. |
#110 (permalink) |
2007 Exige S
Part of my point wasn't just the "tuning" certification but includes several factors:
1. Coming up with a complete kit that works safely 2. Installation of the kit 3. And finally dyno tuning (if necessary) I'll admit, it is pretty rare to see certifications in this business, but I just can't see how long the clause "race only" is going to survive on street based cars. I'm certainly not trying to trivialize the necessary knowledge, in fact, just the opposite - hence certifications. Charlie, do you have a pricing structure and turn around schedule for stock ECU reflash? Also, is there any switching ability to return to stock ECU map (aka one that can be used to pass smog)? I have onboard accelerometers with GPS for speed (pretty darn good ones in my IQ3 dash/data logger) so I can easily evaluate the real world effectiveness of a tune either with EFI or a reflash to determine if I'm loosing or gaining power (along with EGT, AFR, IAT, etc. etc.). Rob.
#111 (permalink) |
Live to Drive
The obvious benefit of EFI vs. Charlie is that it's not realistic to keep going to Charlie and making changes as you need them, but EFI allows you to do that. The other end of that is that Charlie will get it right the 1st time and not do a service that does not work. He cares about his reputation.
So if you intend to make some modifications (or not), be done, then get a one-time fix from Charlie and recoup some of your ASTRONOMICAL ($102,000??) expenditures from the EFI. If you think you want to keep "tinkering" and making additions/changes, the EFI is probably easier, but not "guaranteed" as you've had problems getting a proper tune in the past. I don't understand the "off road only" thing. Are these incompetent tuners using that as an excuse to not give you a healthy, functioning product? I don't see the relevance. It's not like you're buying crack.
Be an alpha male. Drive a Lotus. |
#112 (permalink) |
2007 Exige S
That's my point, get certified EFI tuners and have certified kits -- if the kit needs a wideband, then why does it come with a narrowband? If the kit is supposed to be easy to get back to smog legal (will pass smog test) then why is the harness hard wired in? To put a very fine point on this, one can't be charging this kinda money for Kit that is very unfinished. Can the fuel pump and fuel rail even deliver reliable pressure for 550ci injectors? All my 550 injectors appear to flow just fine with a good spray and within tolerances of each other. But does that mean I had adequate fuel pressure? I don't know -- yes, yet another sensor I need to add -- in this case I think I'll just feed from the fuel pressure wire going into the stock ECU.
That $102,000 includes cost of the car ($75K) out the door (tax and license). The EFI has incurred about $16K (including cost of FF kit, sensors, DBW kit, tunes, new short block, etc.) the rest are track bits $11K. And that's doing motor #2 work myself. I'm on the "edge" right now -- deciding whether to keep the car or just go sell it and get a GT-R (they actually have one in Walnut Creek on display - no mark ups as the dealer would get dropped from their allotment if they did). Part of my frustration is I keep running into more and more hacks as I progress -- I got a lot of really cool stuff setup for this car now, but I keep hitting on these other issues one after another -- and they'll fail if I don't take care of them and do it right -- especially on track. I haven't ruled out going to Charlie and appreciate his offer -- hopefully he can answer my questions above.
#113 (permalink) |
Off-road? OBDII? What is missing?
More importantly, from the comments above it is clear that the level of understanding about the race/track verses street is grossly misunderstood. The reason I post in threads like this is to help illuminate those who want it -- not to argue. So in that light, remember that a team of engineers worked on the Lotus ECU. An aftermarket ECU like Motec and EFI will not have the level of detail needed to rival street drivability. The track is another matter but this thread involves dual purpose cars. Certification: We have the EFI certification. It’s worthless.
#114 (permalink) |
2007 Exige S
Don,
Knowing Lotus, it's probably just one engineer, not a team But again, why does my stock ECU have an EFi logo on it?VVT is intended to be dual purpose, that's why it exists. If your reference about "off-road" is because VVT has no place in racing, then OK -- I can understand that. VVT isn't necessary for a track/racing duty. In fact, it's a lot of extra complexity you wouldn't want in a race car. Maybe this is what you're getting at Don??
#115 (permalink) | ||||||
OSX Black hat
You're a software guy i think ?, think MSCE, even the cisco advanced ones, they're next to useless, its just something easy to ask for in an interview, they're looking for someone that has shown willingness to go and take the course and expand, but you cram it all in a nite and pass easily. Quote:
every time the car was modded or tuned , it'd have to be recertified to keep it streetable, once you've done the first round of CARB and passed, any mods you make are either retested or supplied with a massive amount of paperwork covering why the changes made won't affect smog (if they don't), if their engineers agree they'll pass it, if not you retest at cost. Given that from what i can tell the EFI standalones are going out with a fairly large set of different tunes for, so that'd be impractical, then i don't believe it supports OBD II so it couldn't be legally certified anyway, yes you could drop back to the stock ecu but it'd have to work and all the OBD II subsystems as well. Experience is what counts, i've been very lucky that i have people around me with decades of experience that share it with me. I've seen smart people pass tough courses to get the certification, and they know nothing about the subject, and i betcha there is nothing in the course that covers when stuff goes wrong, only the basic stuff, its like the bible lots of subjective empathy and anecdotes, but no real answers. Quote:
All the pricing and turnaround is on my faq at Temporary goth.am webstore - excuse our dust! Quote:
Steady state dyno (if your clutch is upto it) and a few hours tuning should get it almost perfect, then you just look for the 'throttle stab lag' and such on the street/track. like don says, the certificate, its worthless, i enjoyed the course i went on but mainly because i got to ask questions from a guy with tonnes of real world experience and he was very willing to share it which is very uncommon, all the other stuff you read in a book, its just physics, then you learn all the interesting stuff actually doing it.
#116 (permalink) | |
Why do you assume it different? Why do you see ecu race engineers at the track? And why are they tweaking on the maps constantly during a race weekend?
#117 (permalink) | ||||||||
Dynamic Racing Solutions
![]() Join Date: Oct 2006
Charlie has his product and it works fine for its purpose. We have certain features we allow the end user to determine, and we can customize systems upon request. It's a matter of making sure that you feel your set up suits your needs. It's a shame you still have not got to experinece how well your current set up can work. Hopefully you will get to before you decide otherwise. |
#118 (permalink) | |
As someone who is employed for these specific tasks I will agree with you that in most cases it would be silly to assume that anyone can take a standalone and get the same or better results than the factory engineers in ALL conditions. I am one of those guys you have seen at the track with the laptop tweaking, etc... However, I am also one of those guys who has spent months on different dynos with different cars comparing maps, testing cars in real world conditions, traveling to different parts of the country, i.e. Wisconsin winter in sub-zero weather to tune as well as tuning in the middle of summer in Tempe AZ. Even with all that I still advise people to remember that this is a stand-alone unit and we still encourage people to make sure thier engine is optimized for thier intended use on a dyno. But than again...that's the whole point. If you can't do this or are unwilling to pay someone to do this for you than this is not the product for you. Kris Last edited by Kris from DRS : 10-06-2008 at 08:35 PM. |
#119 (permalink) | |
I'm looking forward to tuning your car. thanks, Kris |
#120 (permalink) | |
![]() Quote:
Don't confuse me (DRS) with anyone else. We have worked closely with EFI for several years on several projects. I've personally been involved with mapping and data analysis for customers in various forms of professional motorsport. You can have your opinions of FF and anyone else, but you don't know me or my history so please refrain from assuming that we are merely marketing to the Lotus community. You don't see me going around making assumptions about your business and your services. And as a fellow LCS sponsor I would hope you would have the same courtesy, but you seem to like "tip toeing" on the edge and its pretty obvious. Not sure why... Kris |
