#141 (permalink) |
Plug Whisperer
Ronnie,
That's GREAT news and thanks for the kind words . I'm really happy that you two got it going so well. I'm was pretty smitten with my EFI setup today as well (another day at the dyno )...Have a great evening. Best, Phil
#142 (permalink) | |
Dynamic Racing Solutions
![]() Join Date: Oct 2006
Very glad to see you guys are happy with the results. Good job! Kris |
#144 (permalink) |
Big head man
One more question, on abrupt throttle tip in, I'm immediately going lean before the accelerator pump has a chance to kick in, just for a second. I know there are parameters to control the accelerator pump, but so far what we've done doesn't seem to do anything. Any tips?
My car both sucks and blows. Now with added all natural smoky goodness!
#145 (permalink) | |
thanks, Kris |
#147 (permalink) | |
hijack done ![]()
2005 Elise 250 whp | Forcedfed Custom Intercooled Supercharger | EFI | Forcedfed Street Header | Fujita CAI | TB Bypass | Toda flywheel | ACT HD Clutch | Forcedfed Prototype Exhaust | Micromirror | Forcedfed Half Carbon Splitter | Greddy Catch Can | ForcedFed Engine Damper |
#148 (permalink) | |
Kris
Motorsport Components and Expert Service. Complete Lotus maintenance, installations, track preparation and specialty services. |
#149 (permalink) |
Thanks Kris !
#150 (permalink) |
Hi Phil and other,
I saw that the program have an option for the knock sensor. The ECU pin out did not indicates any thing about that. That's mean what? Is it possible to use a knock sensor? Or just not possible, and the software is made for more thing than what the specific ECU supplied by DRS is design for? I asked the question few times at Kris via e-mail, but nice reply from Kris are not that easy.
____________________________________ Elise 2006, white, Katana Europa 1969, green, H22A, 194 whp, 1550# CONFIGTECH.ca / Solidworks |
#151 (permalink) | |
Knock Control is in the software and is an option. The new version of the ECU will have it installed by default for those who choose to use it. I must warn though that knock control is not a 100% safety device. If it was no engine would ever ping (spark knock). There is more info here that you may find interesting, DRS Engine Control Support Kris
#152 (permalink) |
Kris,
If I understand right, it is not possible to have it with my actual ECU??? Is it possible to update my ECU in the future? I understand that the knock sensor is not 100% full proof. I did not spend time yet to find where I can program custom input output, is it because it is not available by the software? Thanks
#153 (permalink) | |
The new generation of ECU will have the knock built into the box. When this product was originally developed we opted to not include knock b/c in past experiences knock systems can be temperamental if not set up properly. I.e. noise from external devices, like a rattle from a loose clutch spline can trigger a false knock. Since there has been so much interest in having this as an option we are going to put it in. If proper time is taken to set it up and it is used without leaning on it too much it can work fine overall. We can currently offer the EFI X5 (aka 4.0 ECU) with dual-knock, dual-wideband, staged-seq injection, pit limiter, internal EGT, and many other features if someone needed these advanced features. These are the units we currently use for BMW dual-VANOS engines and other applications. We can set this up for a Lotus if someone were interested. Kris
#154 (permalink) |
2007 Exige S
I prefer to use EGT for my tool to determine detonation. Here is a good link to how EGT can be used and what signature detonation produces with EGT. I used EGT a lot on my 2 stroke Kart but the concept doesn't change for 4 stroke engines.
Knock sensors aren't reliable with perhaps the exception of those used in the Nissan GT-R (at lot of R&D was put into them) -- don't see them used in racing much at all, it's primarily for street use to help with "Bad gas" when one thinks they're pumping in 91 octane (and paying for it) but due to a mess up at the station they're getting a 87 or some less mix (this does happen more frequently than it should and the fines if "caught" are relatively low -- not suggesting stations do this on purpose but...). But from manufacturers stand point, a false positive is fine by them cause it errors on the side of caution (and hence saves warranty claims). It might be good to monitor the knock sensor, but it might not be so good to actually allow the ECU to pull timing based on it.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
#155 (permalink) |
2007 Exige S
DBW EFI users, would like to get your input/maps if possible -- specifically interested in the DC Motor and Accel/Decel sections.
I've got a low rpm "run-on" (<5K) that I'm trying to tune out. What I mean by "run-on" is that if I accel to 4K rpm, lift throttle and then press in clutch the rpm's will continue to increase (about 1K or so). I've read up on PID tuning and also looked at the Accel section and have a few questions: DC Motor - Constants Base Duty Cycle - currently at 50% - not sure how this factors in there is no table? Proportional Gain - 100 Integral Gain - 40 Integral Timer - 8 Derivative Gain - 20 Integral Band - 10 (degrees) Final output is defined as P+I+D so in case above 160 Integral timer and Integral band aren't really explained much. What I can gather from the documentation is that all of these values are used to basically smooth the DBW input/output and increase it's accuracy -- does that sound right? Accel / Decel - Constants Accel Decay - currently 8 bits, docs suggest 2-5 bit, reduce value perhaps? So, these are the elements I'm looking to adjust to try and solve the low rpm run-on issue. I start with Accel Decay since docs suggest 2-5 bit and I'm at 8 bit. Any hints/suggestions are most welcome. Cheers, Rob.
#156 (permalink) |
2007 Exige S
Quick update to my DBW tuning -- changed Integral Timer from 8 to 2 and this has greatly reduce my rpm "run-on" issue. A value of zero actually worked the best for run-on, but it had a side affect of creating throttle flap oscillation during moderate throttle input at <4K rpm.
WARNING: I don't really know what Integral Timer does -- I'm guessing it's some type of delay used to smooth output to throttle unit. Since Kris's tuning doc suggests NOT TOUCHING these constants I would have to urge DBW users proceed with caution. I wish I had a more methological approach ... but I don't as I just don't have a good understanding of these constants yet. Rob.
#157 (permalink) |
400HPFOCUS
good reading material...i have the stuck air conditioning thing going on too. I installed a kill switch for it but it never goes off even in the summer while using it. does anyone have a solution yet??? the problem seems to have surfaced after my dbw controller was installed
thanks
"HE WHO SAYS IT CANNOT BE DONE SHOULD NEVER INTERRUPT THE ONE WHO IS DOING IT" R.R.E RIP |
#158 (permalink) |
2007 Exige S
Kris suggested that it could be a result of the stock ECU going into limp mode and triggering the AC to stay on somehow. I tend to agree as my AC will work fine so long as I don't exceed 4K rpm -- which seems to be the trigger rpm that put the stock ECU into Limp mode and hence AC get stuck ON and as do my radiator fans.
I disconnected the AC clutch wire until I can find a good solution (fortunately hot days are 5 months away).
#159 (permalink) |
The AC turn-on and fan control will both be resolved in the new firmware currently being worked on. It is almost done...very close.
This was an unknown issue at the time of R&D b/c the early DWB controller systems were only fitted to cars that did not have AC and had manually controlled cooling fans (track only cars). thanks, Kris
#160 (permalink) |
Plug Whisperer
Yum, new firmware
