w00t
To EFI Users; what coil dwell
i've seen various settings mentioned for coil dwell on toyota COP units ...
what are you using for your dwell settings ? thx
1zz Elise Blown by Rotrex: Build Thread: http://www.aussieelises.com/forums/i...showtopic=9609 |
w00t
oh, and one more thing - what frequency do you run the vvt solonoid at ??
Plug Whisperer
Tang- I can help with some if this just by sending you a map... or are you applying the info to another stand alone?
In any case, I don't recall the dwell off the top of my head. The freq for the VVT solenoid works well at 120... Hope that helps, Phil
w00t
thanks Phil .. the Freq helps ...
its going into a completely different standalone ... i'm using a Vi-Pec v88 ... the 'new' version of a link g4 extreme ... its a very capable ecu ... and cheap as chips ! well, then you compare it to other ecu's with the same spec ... i'm running everything off it now, including drive by wire throttle ! but i've having a slight issue at what feels like soft rev limit at 6000 rpm ... i've just ordered new coils tho ... want to make sure my dwell settings are right ... Cheers
w00t
i'm assuming this is at 14v ?
crank voltage - 12v ish - i'm using 3.3ms and i'm glad to see that i'm using 2.7ms @ 14v thanks
#7 (permalink) |
w00t
do you stand alone guys set dwell edge as rising or falling ?
thx
