| Sponsored Links | |||
Advertisement | |||
#62 (permalink) |
99 Car Problems
Just got it all wired and started up. Having a few issues getting it all set up and checking everything though, as it is running really rich.
Great overall quality, though I would suggest Radium have the interior AEM laser cut mounting plate as a separate option, as it seems like a lot of wasted effort and money for something that won't even be seen. Would also be nice if there was a little more instruction on getting the initial maps loaded and tweaked a bit (for those of use trying to drive it to a tuner for final tuning )
#64 (permalink) |
Aren't the default maps in any standalone EMS supposed to be rich? They're only there to keep the engine from eating itself before/while tuning...
-Ken 2005 Elise, LRG on Ruby, Sport & Touring, Car #60 in the US |
#65 (permalink) |
The main issue for me is the two base map types are stock or turbo with all the optional sensors ie. MAP Speed Density and Wideband O2. There is no turbo with stock sensors map. So I really had no start-up map that works correctly. Even with using the injector corrections I still had to spend lots of time changing each fuel cell just to get it to idle.
#66 (permalink) | |
#67 (permalink) |
99 Car Problems
Can anyone else confirm this? I too am having the same problem, and even after going through the setup wizard and changing as many sensors as I could find, it is still running at 10.4 a/f.
I would think the initial maps would use stock sensors, and based on the upgrades, users can go back in and change them based on what they have done. Now I'm in the same boat, unless someone out there has a map with all the corrections? Maybe Radium would be nice enough to provide one?
#68 (permalink) |
RadiumAuto.com
![]() Join Date: Feb 2010
The hardest part of programming ECUs is getting the setup complete; wiring, crank/cam sensor synchronized, sensor calibrations, etc. This is already provided in our startup maps. Different injectors, fuel pressure, load sensor, cams, compression ratio, turbo, supercharger, fuel type, etc. will all greatly effect the tune. Unfortunately we cannot provide a startup calibration for every situation. We are not in the business of providing final maps as there is a large liability associated with remote tuning.
Also, keep in mind that cold startup will be inherently rich to resist poor fuel atomization and prevent stalling. As the engine warms up you will start seeing stoich AFRs reading at idle (see warmup enrichment table). However, it is a slippery slope. An engine will idle all day long at 12:1 but will start idle surging at ~16:1. Your tuner should only have minimal effort, ie: fuel tuning, spark advance, cam timing, boost control, and whatever custom ancillary functions that you would like to add into the system. |
#69 (permalink) |
99 Car Problems
Wouldn't that be the point of starting with a map based off all the stock sensors? At least then, people know the exact changes they made from a stock setup. Providing a custom map is one thing, but the startup map should be close enough to run the motor near a tolerable a/f after a few sensor setups.
#70 (permalink) | |
RadiumAuto.com
-factory MAF sensor -factory O2 sensor -factory ignition coils -factory 330cc/min injectors -factory cam sensor -factory crank sensor -factory ABS sensor -factory coolant temp sensor -factory VVT solenoid -factory VVL solenoid -factory knock sensor -factory air box solenoid valve -factory low speed fan relay -factory high speed fan relay The base supercharged 2ZZ-GE map uses: -factory TMAP sensor -factory O2 sensor -factory ignition coils -factory 440cc/min injectors -factory cam sensor -factory crank sensor -factory ABS sensor -factory coolant temp sensor -factory VVT solenoid -factory VVL solenoid -factory knock sensor -factory air box solenoid valve -factory low speed fan relay -factory high speed fan relay The base turbocharged 2ZZ-GE map uses: -AEM 3.5Bar MAP sensor -AEM wideband O2 sensor -GM intake air temperature sensor -Radium 630cc/min injectors -factory ignition coils -factory cam sensor -factory crank sensor -factory ABS sensor -factory coolant temp sensor -factory VVT solenoid -factory VVL solenoid -factory knock sensor -factory air box solenoid valve -factory low speed fan relay -factory high speed fan relay In all of the above cases, the factory ECU takes care of everything else including: IACV, A/C request, A/C compressor, fuel tank sender, tire pressure, vapor pressure, fuel pump, CAN bus, DBW throttle, oil pressure, etc. The Radium turbo startup map does not use the factory MAF sensor or the factory injectors because they will easily get maxxed out with the flow of a turbocharger. The aftermarket wideband because it is most commonly used with a custom turbo setup. Last edited by Radium; 11-27-2012 at 03:13 PM. |
#71 (permalink) |
Radium many people will be upgrading to this ecu will have a turbo already using factory sensors. I think it would be helpful to have had a 3rd option which is turbo map ie fuel/ignition with factory o2 and MAF. Injectors size differences are easily corrected with the wizard so variances are easily corrected for that. However wide band O2 and MAP can not be converted to factory O2, MAF easily.
There should be... N/A Stock Map Turbo Map Turbo Map w/wide band, IAT, MAP This would get just about everyone at least up and running. Sent from my Nexus 7 using AutoGuide.Com Free App
http://www.lotustalk.com/forums/f25/1fastmx5s-monkey-wrench-racing-turbo-nightmare-22211 |
#72 (permalink) |
99 Car Problems
Anyone else having the same rich map problem as well, on MAF or MAP setup? Ive got mine set up on MAP with all the same sensors as the turbo map short of the AEM iat (BOE iat here) and 630cc injectors (550cc RC here), yet it's still incredibly rich.
Just want to confirm its the map and not a sensor issue... Last edited by wek120; 11-28-2012 at 02:54 AM. |
#73 (permalink) | |
I don't think you can use MAP and MAF sensors at the same time. It's either MAP and IAT and disconnect you MAF or use all MAF. Last edited by Lotus F1; 11-28-2012 at 12:29 AM. |
#74 (permalink) |
Haxord but mine
You, the community, should make your maps available and describe the various mods/conditions of the map. That way others that come along can use your maps as templates. As Radium said its a risk, but isn't that part of the purpose of a user modifiable map?
I would never expect those that are the business of making money to release their maps, but I would hope that the community would be willing to help each other.
-David 2006 Storm Ti Exige + VF TVS BOE Nikasil 10.5:1 + Vision Function TVS Vision Function MP62 Based Supercharger Install Thread Turn Signals Blink Fast? Stereo Harness Info |
#75 (permalink) | |
#76 (permalink) | |
Haxord but mine
How is that not what I expressed?
#77 (permalink) |
99 Car Problems
What is the harm in throwing up a good map? Since everyone's setup is going to be slightly different (anywhere from completely different setups to even a slight difference in individual sensor readings), a map that works flawlessly on one persons car is not going to work absolutely flawlessly on another car. BUT it would run enough to get it moving (to a tuner where you get what you pay for).
So sharing maps wouldn't be a terrible idea just to get the cars running, since you are still going to have to go pay a tuner to get it to that same level of quality as the person's car who paid for it in the first place. Make sense? As for my progress, for some reason the engine is detonating as soon as it blips in with even a little boost (1psi) yet from the data log, A/F is reading ~12:1 right up till detonation.
#78 (permalink) | |
RadiumAuto.com
Since you wired in your own switch, make sure you do not have your Power Select accidentally activated . It could either be accidentally flipped "ON" or you could of mistakenly purchased a N.C. (normally closed) switch. If you open the Tuner software, go to the Setup tab and find the "Options - Power Select Switch" dialog box. This function is preset for race gas by pulling 5.1% fuel out (Alt Fuel Trim) and adding 2.1 degrees of ignition timing advance (Alt Spark Trim). However, this feature is ONLY active if your switch is grounded. View the "PWR Select (ALT)" channel dialog box to see its current status. Note: in the start up calibration file, it activates above -1 psi (engine load). RADIUM Engineering |
#79 (permalink) |
99 Car Problems
It detonates with power select both on and off
I didn't want to mess with the timing myself, but it sounds like that would be the only cause, as the a/f is fine the entire time.Edit: looks like a/f suddenly drops right before the detonation, as if there is a fuel cut or something the instant it goes into boost? Grrr! If the base map was fine, then at least I would know it's a problem specific to my setup. Killin me here! Last edited by wek120; 12-02-2012 at 04:51 PM. |
#80 (permalink) | |
I wasn't suggesting they need to release final tune maps they may have. Just a few variations that cover a few configurations so that most can start and drive it mildly to the tuner. There really should be a "all factory sensor" Turbo map to get people started and to a tuner. I think that's pretty basic. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
