#101 (permalink) |
PS I have a Hydra sitting awaiting install in my project car (which has gotten a bit out of hand, as I have now found a crack in the transmission case due to its former tought life), but I have not spliced it into the wiring harness yet. I am just too busy getting the mechanical issues worked out. I'd frankly perefer a tunable stock ECU, but the Hydra works GREAT in the Miata turob track cars - got 300 rwhp in the last lowly STOCK 1.8 liter miata we built based on the Flyin Miata kit. A FM kit, with Hydra, turbo, intercooler, the works is about $5500 and makes good power and reliability on a stock engine. If there was an easy transaxle solution I'd put a Miata motor in the Elise! Oh shame on me this is getting all hijacky so I'll stop.
#102 (permalink) |
OSX Black hat
agreed you're a lunatic, thread jacks don't fuss me any.
get an xede, it works, its cheap and you can tune at will.
#103 (permalink) | |
formerly 1FASTMX5 |
#104 (permalink) |
OSX Black hat
well if he's going with a hydra it'd be a lot worse.
#105 (permalink) | |
The idea of the the reflash really is soo appealing..nice and clean. Charlie, does the reflash disable the cars ability to adaptive to winter driving compared to hot summer driving. Can I tune this thing and not have to worry about seasonal changes?
formerly 1FASTMX5 |
#106 (permalink) |
OSX Black hat
can't see why it would, (most) people didn't retune their carbs for winter, but we haven't tried it in very cold conditions yet.
maybe he is getting the connectors, so i guess i'm even more confused as to why he needs ecu tuning if the hydra works ? i still think the xede is a simple solution for tweakers, its not that many wires, apparently the emanage ultimate is a real pita to wire in and remove.
#107 (permalink) | |
Haxord but mine
If you plan on going with an aftermarket mapping hardware (Hydra, Xede, whatever) you can attach a MAP sensor for it to use. The ECU wouldn't know about it, but your aftermarket hardware could use it to adjust trims. I could dig up a graph that shows PSI readings versus voltage readings for the MAP sensor off the Dodge SRT-4's. They read up to 18 PSI and then there is one that reads up to like 30 PSI.
-David 2006 Storm Ti Exige + VF Stage 2 Vision Function Supercharger Install Thread Stereo Harness Info | Exige with no wing?? |
#108 (permalink) |
Don't get me wrong, the emanage works really fine for almost everything. I have what I think is a timing retard issue over 6500 rpm and I want to experiment with taking timing out of the Lotus ECU maps above 6500, as I think the Ltous ECU is overriding my existing timing retard. I have enough other projects that this is not that urgent for me and as Charlie said, I will probably try the XEDE as it appears to adjust timing by intercepting the CAS sensor instead of the coil output.
Charlie's solution is far more elegant and why I'd prefer to try it. |
#109 (permalink) | |
Mods are good for you
2008 Solar S240 Exige 2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt |
#110 (permalink) |
McLareghini Bugatterrari
Gosh I hope not. My stock car runs like crap.
xtn
#111 (permalink) | |
#112 (permalink) |
Haxord but mine
Didn't see it posted in the intial list, but if the torque was there you could extend the rev limiter and associated maps?
#113 (permalink) | |
OSX Black hat
aye laddie ah cuhd
i'm in cali at the moment prepping for a new tuning session.
#114 (permalink) |
I have now read this threadand someone has told me that you should discuss the new track ecu which lower the power cam rpm. The new ecu lower from 6200 to 5750.
I have this fitted recently and someone at seloc forum says that this is a learning ecu, which means if you have uprated the engine with induction kit, exhaust, sports cat and so on, the ecu is lower the hp so it is still 189 bhp. Anyone know anything about this? I had done a dyno before and after and before i had 188 hp and after 208 hp. This mean that now after i fitted the new ecu, this ecu is lower my hp in the engine back to 188 hp. |
#116 (permalink) |
OSX Black hat
kotten, my stuff still learns if you want it, i can also set the cam anywhere.
the learning ecu will correct for emissions , not power, so if that means dropping power for emissions (typical) it will. legally this is not approved for road use, so it will not pass , although there is no way to know its there, and it will still pass an emission sniffer test and OBD2.
#117 (permalink) |
For background, i'm in california and it's my daily. I've a couple questions for charlie...
so if I wanted cam switchover at 4.5k to 5k is there any reason not too? Would that still be an off the shelf change?It's my daily and i just wouldn't mind the cams switching earlier so i can get that extra power without having to really make it scream. Also, can the Traction control switch be tweaked to also kill the ABS? On the lotus and on my g-wagen i've observed that ABS can be scary, scary, scary on bumpy roads becuase it drastically increases stopping distance. Off the shelf feature? I'm not a big fan of ABS. If my car gets re-flashed by the dealer, i lose the tune correct? Thanks ahead of time. |
#118 (permalink) |
OSX Black hat
i can disable the dealers ability to reflash either with a new program or a simple electrical modification to the car ( a hidden switch )
ABS is something i'd be very cautious altering, its also seperate to the ECU, you could probably disable it by wiring a switch to the speed sensors, however i can't recommend it. never mind all the legal ramifications. The ABS in the elise is different to most of them, its pretty well done and you can definetely shorten braking times with it, i'd suggest looking at andy walshes DVD that shows how to shorten abs by modulating the brake and letting the ABS kick in too. bending the rules, http://www.carlimits.com/shop/catalogue.php?c=6 = just don't lend him your car ![]()
#119 (permalink) | |
Do you have any comment on the above? Thanks!
'05 Lotus Elise Saffron Yellow, Touring, Sport, Stainless Brake Lines, Moroso Oil Pan, RTD Brace KBS Mark 7 Formula 500 with a heart transplant in progress '09 600cc GSX-R Due to hit the track in August '09
#120 (permalink) |
OSX Black hat
Simply answer, we went with a safe, conservative tune.
re intakes, the stock one, it works great ![]()
