Old 07-09-2008, 03:33 PM   #1 (permalink)
Ned M
Ned M's Avatar
P0016 - Crankshaft / Camshaft Position Correlation
My 2006 Exige showed a steady MIL and logged code P0016 (no others) following a noisy startup. After searching elsewhere on the forum I realized this was probably the timing chain tensioner not doing its job after the car sat for a couple of weeks. Rattling noise at cold start up
This is the only time the noisy startup occurred since I bought the car in 2006. The MIL has cleared itself, I assume after logging three good startups.
Does this correlate with anyone else's experience? The P0016 makes sense to me if caused by the timing chain tensioner issue.
TIA,
Ned M
06 Exige
Chrome "wot, there are other colors?" Orange
Track Pack
Touring Pack
04 RX-8 6spd
Ned M is offline   Reply With Quote
Old 07-09-2008, 03:39 PM   #2 (permalink)
ZAMMY
ZAMMY1's Avatar
that's a logical explanation.
also, i think i got a similar indication when i was fiddling with the signal to the transducer which advances the cam timing.
i tried putting a switch on the transducer to manually change the cam timing.......it didn't work!
apparently the system has feedback and looks for the appropriate changes...
sam
Sam Mayberry, W3CYO/R, resident curmudgeon.
aspen white '06 elise.
youtube: sam's jet turbine scooter
Old 07-10-2008, 03:47 PM   #3 (permalink)
Ned M
Ned M's Avatar
Thanks Sam. From one old guy to another, old age and treachery rules.
Ned M
06 Exige
Track Pack
Touring Pack
04 RX-8 6spd
HTML code is On
