Old 05-10-2008, 12:10 PM   #1 (permalink)
P0171 after SC installation
Have been driving the car 8 times after the installation and recieve the code "P0171 System Too Lean" everytime. The car runs good except for the P0171. No other modifications than Tri-point sc with xede piggy-back and no P0171 before the sc installation.
Checked for loose gas cap.
Checked the 3 hoses on the airbox.
Airbox closed and the filter (tested with old and new) is installed right.
New and fresh 95 octan gas.
Clean MAF?
Could I get P0171 if the xede wires crank, MAF and O2 are tapped wrong to the ECU? If so shouldnt the car run badly?
Beacuse the car runs extremly bad if the xede doesnt have any power.
Could it be beacuse of injection fault? if so shouldnt the car run badly?
An other suggestions?
Short movie of the first test drive
Movie here
/Per
Pelle75 is offline   Reply With Quote
Old 05-11-2008, 12:48 AM   #2 (permalink)
2-Y-CHROMOSOMES's Avatar
Clean MAF?
Movie here
/Per
Check to see if you have a leaky injector cushion. Start the car and spray some electronic cleaner around the injectors and see if the idle increases.
I had gotten that same code from time to time. Never got it after reseating the injectors properly.
Do you have a no learn chip? If not you should talk to charlie.
2005 Elise 250 whp | Forcedfed Custom Intercooled Supercharger | EFI | Forcedfed Street Header | Fujita CAI | TB Bypass | Toda flywheel | ACT HD Clutch | Forcedfed Prototype Exhaust | Micromirror | Forcedfed Half Carbon Splitter | Greddy Catch Can | ForcedFed Engine Damper
2-Y-CHROMOSOMES is offline   Reply With Quote
Old 05-11-2008, 01:03 AM   #3 (permalink)
Thanks will try that. Dont have the no learn chip.
Old 05-11-2008, 05:41 AM   #4 (permalink)
Mods are good for you
Dave's Avatar
Not to sound negative, but there have not been too many successful installs, over the long term anyway, without a non-learn ECU. PS, I emailed your Xede file.
2008 Solar S240 Exige
2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt
Dave is offline   Reply With Quote
Old 05-11-2008, 06:07 AM   #5 (permalink)
Thanks! Read about that hopefully its just a leaky injector
Old 05-11-2008, 02:43 PM   #6 (permalink)
DO NOT RUN THAT CAR WITHOUT A NO LEARN CHIP!
Contact charlie and get a katana flash or get an EFI.
Its your engine....good luck. don't say I did not warn you
OOPS fix big type-o
Old 05-11-2008, 03:10 PM   #7 (permalink)
Dave's Avatar
I would NOT run that car with a no learn chip!
Mark, was that a typo? Running the Xede with a learning stock ECU is an ongoing tuning nightmare.
Old 05-11-2008, 05:56 PM   #8 (permalink)
Yep that was a big type-o. Thanks Dave!
Old 05-12-2008, 07:26 AM   #9 (permalink)
Phantom's Avatar
Images: 1
Which SC kit is this?
Is the Katana (w/ a Charlie tune) the only kit with the "no learn" chip?
Good luck, and keep us posted...
Grab Life by the Wheel
Phantom is offline   Reply With Quote
Old 05-12-2008, 07:46 AM   #10 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
This is a Tri-point sc kit with xede piggy-back
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Porterfield R4! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's!
ZTEC is offline   Reply With Quote
Old 05-12-2008, 09:41 AM   #11 (permalink)
OSX Black hat
charliex's Avatar
I'm not really selling the no-learn chips anymore, better off with the SC tune, so unless you really want to keep the xede for more tuning i'd go with
the straight xedeless ronin tune.
Old 05-12-2008, 09:55 AM   #12 (permalink)
Hey Charlie,
Will the xede tune work without the no-learning chip?
I found this thread, should I reset the ecu back to oem learn now and again?
Resetting the ECU back to OEM learn
Would like to keep the xede for more tuning.
Old 05-12-2008, 11:00 AM   #13 (permalink)
OSX Black hat
charliex's Avatar
no the reset is trickier, you run the car, switch the car off (key out) and then disconnect the battery completely before the relays clicks off.
I wouldnt run it without the no learn at least, if you really want no learn get a ronin have me change it to 'no learn' so it'll set the base line properly, zero out the xede, and then tune from there if you need too.
Old 05-12-2008, 11:40 AM   #14 (permalink)
Maybe I should do as Frank told me "get a proper tune"
Could you sell me the xedeless ronin tune? If so send a reply (email) and tell me where to send the ecu and how much for the tune.
Old 05-13-2008, 12:20 AM   #15 (permalink)
Talked with Wayne at Sinclaires he will help me with the Katana tune
Old 05-13-2008, 05:35 AM   #16 (permalink)
Ade
You did replace the injectors with 440cc ones?
Ade is offline   Reply With Quote
Old 05-13-2008, 08:16 AM   #17 (permalink)
Used the injection which was included in the kit. Dunno if it was the 440cc?
