Old 07-20-2008, 09:43 PM   #1 (permalink)
trompazo's Avatar
Traction Control permanent disable?
Does anyone know how to permanently disable the traction control?
My issue is that I am running smaller diameter rear tires (23.5") for autocross. Just holding the button will turn the traction control off initially, but whenever the car gets loose or hits a bumpy spot, it will come on and then it cuts power bad becuase of the smaller diameter tires.
So far the only way to get the car to run on these tires is to disconnect all 4 wheel speed sensors, which of course disables ABS. I have found without ABS I get lots of wheel lock and flat spotted some new Hoosiers today.
I have heard that the ECU looks to see if the switch is wired up, and if not it permanently disables it after 5 ignition cycles. Although, I tried this and it did not disable it.
2007 Exige S Krypton Green: 2ubular/FF RaceHeader/Penskes/Hypercoils/H20 injection
2006 Corvette Z06 = 590whp.
2004 Lamborghini Gallardo: Daily driver
2004 STi: project car #2
1994 Supra Turbo: project car #1
trompazo is online now   Reply With Quote
Old 07-21-2008, 06:42 AM   #2 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
I cannot answer your question, but something isn't right.
Once you turn off the TC, how is it sensing anything and deciding to turn back on? That doesn't make any logical sense with regard to how it should operate. I suspect it isn't really turning off correctly?
xtn
Old 07-21-2008, 08:26 AM   #3 (permalink)
Forum Founder
Randy Chase's Avatar
Images: 761
I have the pin put instructions from Lotus somewhere around here.... but if I recall correctly, the ECU looks for the two pins being connected (pressing the switch disconnects them). If the ECU does not see the two pins connected for some period of time, it permanently removes the TC option. All based on stuff I was told from Lotus 3 years ago... so YMMV and probably will.
If it was me, I would disconnect the wires from the TC switch.
That does not address the problem if your TC is actually working when it is supposed to be off, but it would be a start.
We have been feeling the buzz since 2002
2006 Noble M400. Getrag tranny, Quaiffe LSD, Hinged clams. Duratec dual turbo V6. Hoosier 315-18 tires. 2350 pounds. 0-60mph in 2.9 seconds.
Old 07-21-2008, 08:34 AM   #4 (permalink)
Help!!!!
cory1000's Avatar
I had switch removed for 3 weeks and had more then 5 starts (I would say a good 30-40 starts) and then plugged switch back in and it still worked. I have heard of the 5 start rule also, but it didnt work on my car.
2007 GG Exige S - Sold
2005 CO Elise - Sold
cory1000 is offline   Reply With Quote
Old 07-21-2008, 08:37 AM   #5 (permalink)
Forum Founder
Images: 761
Well there you go then. I never could tell because we reflashed my ECU and then there was not TC after that.
Old 07-21-2008, 08:38 AM   #6 (permalink)
xtn
xtn's Avatar
cory1000,
But did it stay off for the three weeks that the switch was unplugged? If so, that should satisfy trompazo's requirements.
xtn
Old 07-21-2008, 10:18 AM   #7 (permalink)
disproving HD MTBF daily
charliex's Avatar
Randy, you can't disable the TC on the 05, its always on by default so the switch trick doesn't work.
On the 06 it detects the light in the switch, not the switch itself (since its momentary on theres nothing to detect), so the TC harness has to be disconnected
I wonder if the wiring itself is causing it not to detect properly, but it does disable it when it works properly
You have to hold it to turn it off, but turning it on only requires a few miliseconds, thats why its so easy to knock it.
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660
Old 07-21-2008, 10:22 AM   #8 (permalink)
Forum Founder
Images: 761
I wonder then if switch bounce when autocrossing is causing it to trigger. That would make sense.
Old 07-21-2008, 10:36 AM   #9 (permalink)
charliex's Avatar
Thats what i'm thinking too, it doesn't seem like it ought to but i know some people swear they never depress it (apparently including peeps at lotus, but it was shown they were just tapping it lightly with the knee).
Old 07-21-2008, 10:42 AM   #10 (permalink)
Forum Founder
Images: 761
I know on our PDR, that the switch is probably more robust (bounce resistant) than the one used for TC, and we had to add debounce code to our recorder.
Old 07-21-2008, 10:55 AM   #11 (permalink)
charliex's Avatar
It protects agaisnt debounce for turning it off just not on, since it uses a timed interval for the off part.
maybe just a higher amperage switch instead, if thats what it is.
data logger on the switch + autocrosser = find out whats really going on.
Old 07-21-2008, 11:04 AM   #12 (permalink)
Forum Founder
Images: 761
Also makes sense since it would be a fail safe way of looking at it.
Old 07-21-2008, 11:06 AM   #13 (permalink)
charliex's Avatar
OK found out why it doesn't appear to work, its the first 5 starts for a new ECU, not any 5 starts, my bench ecu's are always within the first 5 thats why I hadn't noticed earlier.
Update your local rep/dealer then we can fix the rumour
Maybe we'll be able to fix that remove the battery for 5 minutes to clear/reset the learn rumour next.
Old 07-21-2008, 11:07 AM   #14 (permalink)
'07 Black Exige S
Pestodude's Avatar
I have the same problem when tracking. Turn it off when I head out for the session, look down, usually before I've completed a lap and the dash light is off (TC on). I thought maybe my knee was hitting the button but maybe its from the tires hitting the curbs. Antone else have this issue on track?
Randy
'07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, ForcedFed engine dampener, de-snorkle/ vel stack, cf side scoops/ mesh removed, algnmnt set up by Lucent in LA (machined control arms, etc), SS brake lines, 160 deg. thermo, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Stealth signal bulbs, blacked out turn side markers, 5 point harness
Pestodude is offline   Reply With Quote
Old 07-21-2008, 11:13 AM   #15 (permalink)
charliex's Avatar
Lots of people say it happens to them on the track, but i don't think anyones proved conclusively that they're not accidently hitting the switch.
Though i do recall someone mentioning a relocation of the switch itself.
Old 07-21-2008, 11:23 AM   #16 (permalink)
TimMullen's Avatar
Images: 19
Another possibilty is that the driver's leg is bumping the switch button and turning it back on. I wonder if a "protector ring" around the button would prevent this - something like an inverted pop bottle cap such that you have to stick your finger into the recess to access the button. You could even test this theory by turning off the TC, and duct taping a bottle cap over the button. Then test to see if the TC gets turned back on. If it doesn't, then you have figured out that bumping it is causing it to tun on.
94 Miata R Package - Black
Old 07-21-2008, 11:30 AM   #17 (permalink)
charliex's Avatar
how about one of these.
Old 07-21-2008, 11:56 AM   #18 (permalink)
necro's Avatar
Images: 1
Or something like this?
Oddly enough there are 4 wires to the Traction Control switch; one is the momentary one, the other two - I do not know. At least one is for the LED.
07 SY ExigeS
necro is offline   Reply With Quote
Old 07-21-2008, 12:16 PM   #19 (permalink)
Bruised thighs daily
Tracktimeplz's Avatar
TC is only an option on these cars right? I would never buy one of these cars with TC as long as I had the option not to.
LSD, Power steering, A Jedi craves not these things.
2005 Magnetic Blue Elise
Forcefed 275 turbo SSR comp Wheels
Tracktimeplz is offline   Reply With Quote
Old 07-21-2008, 12:20 PM   #20 (permalink)
charliex's Avatar
two wires for the switch, one ground, one input to the ecu
two wires for the led one for ignition switched power, one output from the ecu.
HTML code is On
