#121 (permalink) | ||
Future 2ZZ-GZE member...
As of today, you got yourselves a new dyno to see, and a new race header to purchase!
New race header development thread Quote:
For the purposes of this thread...I'll be looking forward to his 1000+ mile dyno...
#122 (permalink) | ||
Until Bane posts up his 1000+ mile dyno, I think this should suffice to add on to the thread, even though I'm a bit late to adding it on here. Remember that Weapon R 4-2-1 design race header (like forcedfed's) that a bunch of people though would flop and not produce power just because it was a "ricer company's" product? Well check out the latest dyno & gains (Post #111):
http://www.lotustalk.com/forums/showthread.php?t=50526 Quote:
Now lets see a PPE Race header dyno versus a Weapon R one! ![]()
#123 (permalink) |
I hate picking usernames
Still don't understand the "unlearning"
My apologies for dredging up an old thread, especially one with such intense arguments going on, but I really wanted to comment on a couple of issues.
Concerning low and midrange torque: I definitely agree that this can be an important aspect of engine performance for acceleration, especially when outside of the highest RPM range of the engine. On the other hand, this was clearly not a concern of Lotus engineers when selecting an engine for this vehicle, because if you want low range torque 2ZZ is not the right engine to be working with. The entire idea of this engine is sacrificing low and midrange torque for high range HP. If low and midrange torque is the desired outcome there are other engines that would be more desirable selections (Ecotec?). Same thing if you want an engine that can take a ridiculous amount of boost and make crazy forced induction power, I don't think 2ZZ is the answer. Concerning the ECU "unlearning" modifications: I know the accepted answer is that this ECU unlearns modifications over time. After reading many threads and comments here I still do not fully understand how or why though. From my understanding ECUs make adjustments to meet certain conditions. These adjustments are likely geared to achieve a number of goals, power output, emissions and engine longevity. The primary inputs for these adjustments are the intake sensors (MAF or MAP depending on the engine), the oxygen sensor and the knock sensor. Based on the knock sensor the ECU may retard ignition timing to prevent detonation, this is a longevity issue. Based on the oxygen sensor and the intake sensors the ECU will adjust fuel delivery. Too lean is bad for longevity, too rich is bad for emissions so the ECU makes adjustments to maintain the appropriate AFR. Since the MAF sensor measures the mass of air that is flowing past it, one would assume that more airflow would result in increased fuel delivery. My understanding is that MAF based ECUs are much better at making these types of adjustments in response to bolt on intake mods than speed/density systems are because the MAF measures the actual amount of air instead of estimating the amount of airflow based on manifold pressure. So, if more air is being delivered I do not understand why the ECU would learn to deliver less fuel overtime as this is not ideal for emissions, longevity or power production. I do understand that at some point you will move outside the ECU's ability to adjust for these changes but for simple low impact intake mods I really don't understand how or why the ECU would "unlearn" the ability to produce more power; it's simply not in its best interest to do so as long as you are within the ECU's range of available adjustments. Either way, I think I agree with GTsRasta that the ECU should not be unlearning power increases from simple intake mods, and I agree that the spirit of the engine is high end power, not low range torque. If improved low range torque is the goal, maybe a different cam is the answer. Idle to 6200 rpms is a pretty broad range for a cam, so I would suspect that even the "first" cam has significant overlap (don't know the cam specs), which is good for high RPM power but bad for low/mid RPM torque. So maybe the ultimate mod is a new cam with a more midrange grind for the lowrange lobes and then a lower cam switch over point to go to the highrange cam?
2007 Elise, Ardent Red, LSS, Touring, HT, TC |
#124 (permalink) | ||||||
http://www.newcelica.org/forums/showthread.php?t=273079 Quote:
And on that note...look at the NEW Lotus PPE race header dyno update: New race header development thread Quote:
#125 (permalink) |
Holy $hit!
This thread is an absolute bitch to read and follow. I'm going back to playing Dungeons and Dragons. Oh...wait...I don't play Dungeons and Dragons...![]()
'06 Krypton Green Elise (touring/LSD/HT) '05 Magnetic Blue Elise (sport/HT) dedicated track car '07 Jeep Wrangler Unlimited (4 door!) Excelsior-Henderson Super X/Ducati Monster 620 ie 3 Series BMW/Acura MDX Carver Yacht |
#126 (permalink) | |
When you change the intake filter, you change the mixture - at least for a while. The tendency is to lean out the mixture a bit and this in turn makes more power. But the ECU "learns" its new conditions and makes long term adjustments to the mixture - this negates the temporary leaning (and power improvements) by returning things to "normal". The ECU is attempting to keep things in compliance with the emission regulations, not necessarily in making small improvements in power.
#128 (permalink) |
It gets a bit frustrating saying the same things over and over.
I ran that intake on my car for over a year and it is still on my ex-car. It does not and did not lose hp or torque. It gained. Dyno tested. We also tested many different intakes and they DID lose torque or hp. Some up to 9hp. Some gains were seemingly caused by the engine running lean because the intake fooled the MAF temporarily, but eventually the ECU recalibrated the fuel maps and gains would go away.
* V E R I T A S * A E Q U I T A S * No Longer the ADMIN here, please do not PM me asking for help. Thanks! http://www.facebook.com/randychase 1991 Toyota MR2. AutoX Beast 2006 Noble M400. Track weapon. 2009 Rossion Q1. Monaco Orange. Canyon Carver. In build: 2009 Toniq R (300whp? 1100 pounds?). Chrome Orange. Lexus GX-470 tow vehicle. On Order: Lotus Evora Next: McLaren MP4-12C |
#129 (permalink) | |
thank you timdavis130. yours below is the only kind of philosophical assessment of this topic that makes sense to me (also acceptable to me is the pragmatic approach of testing what works and what doesn't and not worrying too much about why). and it's also put simply and clearly. i meant to write up something like this too but never go to it. i program ECUs for a living.
#130 (permalink) | |
Shish Kebab
"Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?" - George Carlin |
#131 (permalink) |
Yes and not a lot.
#133 (permalink) |
When we first used the "stage 3" intake above, it was with a Lotus supplied ECU. This was with the stock MAF. Most of our testing back in summer of 2006 was using a stock ECU and MAF. I think it was fall of 2006 we switched over to the EFI. I know some people get confused trying to follow the sequence of my ECUs. Stock. Reflashed from Ragnorak for a month. Reflashed from Lotus. New Lotus stage 3 ECU. EFI.
Once we had the EFI, we still did some more testing. We tested cams, headers, exhausts, intakes.... and found that the de-cat was good, headers not bad, and still the best result among the things we tested was the above intake. Not huge by any means, but better.
#136 (permalink) | |
Parts scattered about...
![]() One more question, if you don't mind - Supercharged or NA? The reason for my question is - I think Supercharged with EFI/MAF (I don't think MAF can be used with EFI) will have different results with regards to intakes. Of course no one knows without testing...
My car is modified.
#137 (permalink) | ||
I troll through here because I hope to own a Lotus one day, just as I trolled through newcelica.org in the hopes that I'd get a Celica GTS one day. Now that I have my GTS, I hope to use that as a test bed for when I get a Lotus. That's all. What's the problem with me surging interest in things? Was the PPE race header that I brought back the interest to here that bad of an idea? Whatever.Why do I care? I answered that in the beginning of the thread. It's because I thought it was just absolutely STUPID for certain vendors to be praised with magical bolt on mods that will undoubtedly give power while others get flamed with the "lotus ECU will unlearn the gains" BS. The intake argument is up in the air without any supporting mods to go along with it, but I'm pretty sure I fleshed out the header part in this thread for good. Woes me for not finding that magical dyno graph where a breather mod showed 100% power loss in all RPM ranges...I did this site suchhh a diservice...
#138 (permalink) | |
There were other things to test post-SC, but I never got around to them.
#140 (permalink) |
OSX Black hat
Heres a diagram on why a CAI might lose power. The spark advance tables are also the same.
Black Exige S - http://goth.am 265 Mule / Elan M100.ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660 West Coast Lotus Meet - Las Vegas - November 6-9 2009 http://www.westcoastlotus.com/ Last edited by charliex : 04-11-2008 at 01:34 PM. |
