2007 Exige S
What EFi can do for you...
I did a quick search and noticed there is no real thread about what EFi based systems can do for the user beyond just "tuning" of the engine.
So I'm starting this thread in the hope folks like Kris from DRS and Phil and others will contribute in new ways and/or existing ways on how they are using their EFi based system to do more than just tuning. I'm intending this thread to be more about Engine protection, Engine monitoring, traction control, fan control, shift control, etc. etc. So let me start this thread with some questions: 1. Fuel pressure monitoring and how to use thresholds to protect your motor? 2. How to setup no lift up shifts? 3. How to setup auto blip down shifts? I hope to come up with an comprehensive how to for item #1, but gotta get my motor back together first. As far as #2 and #3 anyone? Rob. P.S. please don't use this thread as a EFi vs. XYZ -- it's not a comparison to other technologies nor is it this is better than that thread. Thank you.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
Dynamic Racing Solutions
![]() Join Date: Oct 2006
Yes. Actually the no-lift-shift stategy has been around since day one of this particular ECU, and was present in the other more advanced versions of the ECUs for several years before.
The auto-blip of the throttle is something we can also do. We have not done it yet for a Lotus customer, but it's been discussed recently and should not be a problem. However, I would think either control strategy would be better suited for a car fitted with a sequential gearbox. I can get into more details as to why if you like. thanks
Motorsport Components and Expert Service. Complete Lotus maintenance, installations, track preparation and specialty services. |
Rob, I'll work on some other things non-tuning related to share as well.
thanks Kris
2007 Exige S
Excellent, thank you Kris!
Please do get into more details on the auto blip down shifts -- like what hardware is specifically needed. Rob
#5 (permalink) | |
Kris
2007 Exige S
Can these sensors be outfitted to standard manual 6 speed with necessary reliability/consistancy?
I'm no expert on the Matrix tranny, but as I understand it, there is a lever for up and one for down? This is actually a good thing? What elements are acted on? Throttle (for DBW) or spark or fuel, combination? Rob
#7 (permalink) |
2zz exorcism complete
For the standard transmission we have always used a clutch switch input which triggers a non-timed engine cut for shifting. Works very well. Clutch switch needs to trigger just before clutch disengagement. Cut must have minimum rpm to allow bottom gear to be selected & non full throttle driving.
-2ZZ +K24 +150hp +118tq +7mpg +LSD -30lbs -CoG +F.bias |
#8 (permalink) |
2007 Exige S
dstevens,
Clutch switch in addition to the up/down "strain gauge sensor"? I can't visualize how a clutch switch alone would work for down shift throttle blips? After reading up on the strain gauge sensor I can visualize how it could measure forward/backward deflection in the shift arm -- and I "think" I can understand why such a sensor would be more suited to sequential motion rather than H pattern. With that said, couldn't the same Up/Down with the standard tranny be fitted with a switch at the levers on the tranny -- combine this with a clutch switch and I would think one would have a relatively reliable system for no-lift up shifts and auto blip down shifts. To expand on this, one could simply do a map switch in real time to turn the system off (say for pit entry and/or cool down lap), because my hunch is this setup would be hard to keep "active" for low speed situations and not suitable for street use? Would there need to be an additional EFi module for this or can the existing expansion harness support these 3 inputs? Rob.
#9 (permalink) |
The No-Lift-Shift does not require an add-on box.
The Auto-Blip downshift will require a DBW controller. Traction control does require the use of a Multiplexer and chassis loom that we build here. 12 Pos adjustable knob is optional. Kris
#10 (permalink) |
Never tried to use either of these tricks on an H pattern box. The thing that scares me about doing no-lift-shift on an H pattern is the potential error for missing a gear, or a slow shift and exceeding the timer for the engine cut.
Besides, you would need dog gears at a minimum.
#11 (permalink) |
I think you're making the H pattern no lift shift more complicated than it needs to be. For upshifting, it is very simple. Cut the engine output while the clutch is down. To shift, you just keep your throttle wide open and operate the clutch and shifter as per normal. It works very smoothly. No timer used, no dog gears needed. For downshifting, blip the throttle manually (well, there's no other way with a manual throttle body).
#12 (permalink) | |
kris
