#24 (permalink) | |
On manifold is not present a flexible and then you have little tolerance to vibration. The two screws with springs on the flange are not sufficient to dampen vibrations and manifold surrender, because I manifold must bear their weight and the weight of kat and in the area of the flange, is too thin. B) A second problem is my kat 200 cells that reads an insufficient intervention kat (Error code P0420) from our ECU and turns the light engine. You have to buy a spacer, but only "KLS by Bonalume" (over 250 $) and not a spacer any. C) A third problem is the attack between manifold and kat, because the tape tends to loosen. You must install a bolt self-blocking. However, after each race, you must tighten. If not closed, loses air, you turn the light engine because the lambda sensor reads the error code P0171 D) A fourth problem is the collar between kat and muffler terminal, which loosens, even in this case, you need to mount a a bolt self-blocking. However, even in this case, after each race, you must tighten. Despite these "few" problems, the line is sufficiently performance... But I can say more when I receive the replacement manifold that will allow me to test thoroughly and finally the line... INFACT, I AM STILL IN WAITING TO RECEIVE THE SUBSTITUTE MANIFOLD, but for now Larini not answered? Waiting for another few days and then I go by my lawyer, because I'm tired. Two months of hassles and inconvenience and hours have passed another 15 days for replacement manifold ![]() I hope you understand my English ![]() Last edited by Orange1964 : 08-09-2008 at 09:07 AM. |
#25 (permalink) |
Thank you, your English is fine, I understand it well enough. But the one thing I don't get: what is the "KLS by Bonalume" spacer? Can you provide a link? I did a "google" search, and came up empty.
Thank you again!
-Ed '08 Arctic Silver Exige S240 |
#26 (permalink) |
I do premise: I do not have anything to do with them, not sell for them, I just bought from them ...
![]() Here's the link : Valvola Waste Gate Pop Off Elaborazione Colt Czt Mitsubishi Audi Volkswagen -Bonalume |
#27 (permalink) | |
#28 (permalink) |
Katana Exige!
Wow that looks bad. I called Larini to check on this failure and I guess they are managing through Larini dealer in Europe that Orange bought the kit from.
We have been running the header on our Exige with a straight pipe. It has performed well. We had it on track at our last track day and several members here flogged the car with no issues. I know they have sold many in the UK with good results. The muffler is now on our car and it sound good. Much like the Larini 6" system. |
| Display Modes | |
