Katana Exige!
Sector111 308mm BBK Preview
We've been plugging away with some new product development with our friends at Girodisc. Our AP BBK is an 'Evil' solution - no doubt. But a 'Good' alternative is clearly needed.....
Expect this front kit in about a month or less for under $2k. Designed to fit in a 16" wheel. We've had to make a few tweaks to the brackets so should be testing them very soon....if you are interested pls contact us and we will get you on our list. |
Hydrocarbons Rule
Do these Willwoods have dust seals on the pistons?
06 Exige; BWR Supercharger, Adj Sway Bar, Ohlins 2-way Suspension, BSK Oil Catch Can, Moroso Oil Pan, ORC Super Single Clutch, Arqray Single Tip, Work Emotion CR-Kai's w/ RT615's, 2 piece rotors, Pagid Blue pads, BSK Wet Carbon (Side Skirts, Front Lip Spoiler, Gas Cap Cover, Center Console, Door Pannels), Dry Carbon rear Diffuser, Harness Bar, HKS Boost and Oil Temp Gauges, BWR Gauge Mount, Sabelt Harness, JVC Head Unit, Alpine Sub Woofer, Polk Audio speakers, OMP Superquadro steering wheel. |
blah
after cracking pistons on two sets of wilwoods on my old miata I'll never go that route again.
AJ 06 Aspen White Exige - MWR Stage 4 motor : Exige S manifolds : MP62 : CharlieX Tune : FF 10psi pulley : RLS IC and pipes : Walbro 255 : RC550cc : Moroso Pan : VonHep Single : WR Race Header : JRZ DA Race Coilovers...(tons of other goodies)... 267hp/167tq at the wheels : Dyno |
Katana Exige!
Yes. See more info below. Girodisc has had great success with these calipers in much heavier cars. The overall small profile gives us the opportunity to fit them to our 16" wheels. I've highlighted the features that are really sweet:
Billet DynaPro Caliper Highlights: The DynaPro four-piston radial mount caliper combines pure race technology with a new generation of Wilwood performance enhancements. Its sleek profile, superior strength, and durability in adverse conditions are easily adapted to a broad range of sports, rally and off-road driving applications. The strength of the DynaPro is a combination of process and design. The process of stress-flow forging re-aligns the metal's grain structure within the contour of the caliper body. This eliminates the stresses and interruptions to the internal grain structure that occur when machining a straight block billet. The FEA generated radial transition design eliminates steps and shoulders in the area between the piston housing body and the caliper bridges. Incorporating a radius in this critical area substantially increases resistance to deflection and caliper separation under load. Structural deflection and volume displacement tests have proven the efficiency of this innovative design. Without even considering the overall greater strength and reliability of the billet forging, the reduction in overall deflection and fluid volume displacement translate to increased clamping efficiency with less pedal travel. The bottom line is a firm pedal with outstanding stopping power. The superior strength of this innovative design is combined with a new generation of Wilwood performance features. The DynaPro uses a new 7816 type brake pad that is supported from the top by Quick-Clip pad retainers. This feature eliminates the need for a pad support step in the bottom of the caliper and adds additional clearance for mounting closer to the hub on small wheel and small rotor applications. The Quick-Clips also accommodate easy pad access without caliper removal. Other new Wilwood features include coated aluminum pistons fitted with high temperature rubber boots that seal out dirt, moisture, and debris from the piston bores in less than friendly environments. Every caliper is equipped with Wilwood's SRS stainless steel bridge plates. The SRS plates eliminate the bridge wear caused by pad gouging and extend the service life of the caliper body. The spring-loading action of the SRS plates also eliminates pad rattle and dampens the vibration harmonics that contribute to squeal under braking. Internal fluid passages eliminate the need for external tubes. Four corner bleed screws assure simple and effective air evacuation, and allow one caliper to be mounted in any front, rear, right or left position. |
blah
I'll check when I get home. I have one sitting on the shelf still. I know they did not have the dust seals though. Its good to see they are doing that now.
#8 (permalink) |
LOG29 Co-chairman
I had the Wilwood Big Brake set up on my Miata also and loved them. Serious stopping power.
Shinoo, how much does setup this weigh compared to stock?
2007 Exige S265 - Krypton Green - Gotham 265 ECU - Volk TE37s - Toyo R888s - B&M Shifter - QuickSilver exhaust - stripes - harnesses - Pagid pads - Green air filter LOG29 - http://www.log29.org President - Lotus Limited Southeast http://autos.groups.yahoo.com/group/LLSE/ |
#9 (permalink) | |
Katana Exige!
Lighter than stock. I will have the official weights soon. The kit is now on the road and getting some miles on it. Initial feedback is great. One great plus is that the stock forged wheel fit with no spacers. |
#15 (permalink) |
Katana Exige!
We tested them at Streets of Willow yesterday with great results. Paul is a driving instructor who teaches on that track - so he knows it well. He pounded his Exige with our 308BBK and was very happy. I drove his car and found them to work very well. Excellent pedal feel and easy to modulate. No fade was noticed. I think you guys will be very pleased.
We should have them in stock within a week or so. You can preorder here: 308BBK |
#16 (permalink) |
Compatible with stock rubber lines?
Shinoo-- I understand replacing front brake lines on an Exige is pretty difficult without removing the front clam. To avoid (or defer) this pain, will the stock rubber lines properly attach to these Wilwood calipers?
Thanks.
9and3 '07 Exige S, Performance Pack |
#18 (permalink) | |
#19 (permalink) |
Liberté!
Am I the only here that think upgrading the front only is gonna screw the balance?
I remember when some Miata tuner went with Baer BBK and the car actually took longer to stop despite the bigger more powerful, front brakes. I saw it happen on a Civic brake in Sport Compact Car. The frint bias killed the stopping distance. I also feel our car can use more rear brake bias for track use. So I think a BBK for the front only is not gonna help shorten braking distance. In fact, it might now take longer. This happens all the time and I have yet to see hard numbers of front biased BBK that shortens braking distance. The only true advantage is better fade resistance. But if you use track pads, fresh fluid and titanium shims, I doubt you will ever fade the stock braking system. Plus, you might actually brake harder than with a front biased BBK. I'd really like to see a BBK for the rear brakes. Or at least a full BBK (front and rear) then we should see some improvements. My 0,02$.
BMWCCA Instructor VanDiemen F2000 2008 BMW 328Xi 2006 Lotus Elise Chrome Orange Ronin Katana
#20 (permalink) | |
blah
