Go Back   LotusTalk - The Lotus Cars Community > Marketplace > Aftermarket Suppliers
Old 07-02-2009, 11:00 AM   #1 (permalink)
Project Nirvana Elise
shinoo's Avatar
V2linx - Newest Suspension Tweak
Proper corner balancing requires a swaybar that does not impart any load on a chassis when static. Disconnecting the swaybar is a part of the process. The stock end links don't offer adjustability so when you reconnect them, the swaybar gets loaded. Many of you have probably experienced odd weight transfers during corner balancing. Our new V2linx are fully adjustable to insure the swaybar is NOT loaded, allowing you to achieve the perfect set-up.
Engineered by Ralph@V2, these links are made from high quality components and produced for us in the good 'ole USA.
We've made a small batch of them initially and have stock now.
Order them: HERE
Note the trick conical spacers - more strength + no bind
shinoo
sector 111 - tasty bits for your elise & exige
shinoo is offline   Reply With Quote
Old 07-02-2009, 11:27 AM   #2 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
Nice idea!
Old 07-02-2009, 02:43 PM   #3 (permalink)
sleepe's Avatar
Do your endlinks work on the same principle as BWR's?
Are yours different from BWR's?
-Robert
p.s. got the tailhook, thanks
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
sleepe is offline   Reply With Quote
