Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus Inspired Cars or Cars with Lotus DNA
Old 10-15-2009, 02:04 PM   #21 (permalink)
Race lines on the mind
Tracktimeplz's Avatar
Originally Posted by kverges View Post
All in, I think I'd prefer a C6 Z06 - not all that much more, esp if you buy a 2006 model, which by definition is newer than the Miata conversion by at least one model year. And you'll likely get a mfg warranty and thinks like 505 hp, 32 secion rear tires, stuff that can never be had in the miata conversion.
Id think you, of all people would realize the benefit of lightness!
The miata weighs 1000lbs LESS than a Z06 Vette
Thats HALF an elise, LESS
Stopping distance, corner entry speed, traction in during transitions are all GREATLY higher in a lighter car.
Oh, and the Ecotec setups ARE NOT better balanced in a miata than an LSx setup.
The main reason (Besides the heavier part of the LS motor sitting LOWER and further BACK than the stock motor/ecotec) is the t56 transaxle.
the LSx swaps, when done properly, weigh about the same as stock, but have a considerably lower CG.
2003 Honda S2000 - Suzuka Blue
2005 Magnetic Blue Elise
Forcefed 275 turbo - Sold 05/20/09
Tracktimeplz is offline   Reply With Quote
Old 10-15-2009, 02:12 PM   #22 (permalink)
Live to Drive
Bavarian Motorist's Avatar
If it's $30 g's+, I'd rather have a Caterham or 7 type of car.
Old 10-15-2009, 02:18 PM   #23 (permalink)
For many years Flyin' Miata has had a gathering in Grand Junction, CO in August which used to be called an open house and has since become their summer camp. Some of their scheduled activities take place at a local shifter cart track which resembles an autocross circuit. This year they had a couple of their V8 conversion Miatas at the track. They performed very well, and they sounded incredible. I didn't take the opportunity to ride in one of them, but those who did were favorably impressed.
Bill in
Cincinnati
webowser is offline   Reply With Quote
Old 10-15-2009, 04:45 PM   #24 (permalink)
Legend in my own mind
MightyMike's Avatar
Images: 9
I'm seriously thinking about taking the plunge. While owning an Atom and Caterham is appealing, something as wild as putting an LS3 into a Miata without jacking up its handling characteristics sounds like a lot of fun.
06 ST Elise
02 SLK32 AMG
BWR Supercharged w/CharlieX tune, Borla Exhaust, OCC, ACT XTSS Clutch, Zeitronix A/F Meter, LETSLA, Manly Mounts, RTD Brace, ReVerie Diffuser, Scoops, Side Skirts, & Shifter Ball, Forcefed Spoiler, & a bunch of other stuff
MightyMike is offline   Reply With Quote
Old 10-15-2009, 04:56 PM   #25 (permalink)
NOT ßANNED!
Demonized's Avatar
You'll have to invite me down (Or up, if you move) to help with the install.
Old 10-15-2009, 09:27 PM   #26 (permalink)
DWebb's Avatar
Images: 20
Originally Posted by mrcarcrazy View Post
I see your point, and while I think V8 miata's are psychotic, I'd go that route before I bought a vette...but I am the anti-vette type.
+1
Yes, that's very nice, Thank You.
DWebb is offline   Reply With Quote
Old 10-15-2009, 10:56 PM   #27 (permalink)
rnr
daily driver
rnr's Avatar
An LS3 Miata would also be comfortable, (relatively) practical and daily drivable while an Atom/7/etc are none of the above.
http://www.rahulnair.net/blog
rnr is offline   Reply With Quote
Old 10-16-2009, 10:09 AM   #28 (permalink)
The art of lightness
Keith Tanner's Avatar
Hey guys, Keith Tanner here from Flyin' Miata. I just figured I'd pop in and answer a few questions. If there's anything you'd like to know, just ask.
When we build a car for a customer, we use all new parts and the entire drivetrain gets replaced. The engines are the LS3s from the 2009 Corvette and come with a 2-year warranty - better than you'd get with a used 2006 Z06! Even the LS376/480, an LS3 with a hot cam that gives an extra 50 hp, bumping the total to 480 hp, comes with that warranty. So not only are we dealing with a car that's approximately 750 lbs lighter than a 2009 Corvette, we've also got an extra 50 hp Makes for a fairly perky little car.
If you want the 505 hp LS7 from the Z06, that's certainly possible. But it's a dramatically more expensive engine to buy without much of a performance increase, so almost all of our customers are going for that cammed LS3. I think we have a customer building their own with an LS7, I'd have to check.
We don't use the T56 transaxle. Packaging that thing is difficult in our chassis to put it mildly. We use the F-body version (Camaro/Firebird) of the same transmission.
As for rubber, we certainly can't fit Corvette-size meats under the back. Most of our customers are running 225/45-15 R-compounds. Matched with the effective Positraction LSD in the rear, that works pretty well. We've set up our own car to run up to 255-series tires in the rear without any visible body modifications, but we do have to go to a larger diameter tire to get that size so it's not ideal. With the 225s, the car does hook up much better than you'd expect out of corners - the first time I took one of these to the track at Laguna Seca that was my biggest surprise.
I've got a Lotus Seven replica in my garage. It's huge fun, of course, a different sort of beast than the V8 Miatas. Ideally, I'd have one of each. I'm working on it...
Keith Tanner is offline   Reply With Quote
Old 10-16-2009, 10:20 AM   #29 (permalink)
Welcome Keith!
Old 10-16-2009, 10:33 AM   #30 (permalink)
MightyMike's Avatar
Images: 9
Great info Keith - thanks!
06 ST Elise
02 SLK32 AMG
Old 10-20-2009, 07:46 AM   #31 (permalink)
kverges's Avatar
Don't get me wrong, car sounds great! I run Turbo Miata race cars and love the extra power. It is just part of the biggest attraction of the Miata is low cost and if price is no object, then I am sorry, but the Miata is out of the picture - I look to Lotus, Radical, etc.
I wonder if the LS3 cars can truly run at race pace for extended periods of time without cooling and brake issues. Even with ony 250 whp in a turbo car we have to make signiificant modifications to get the car to run reliably at race pace and add an extra 100 hp or so and I really wonder if the car can run cool and fade-free on the brakes.
As you might guess, I have a Z06 and on track the car will see over 240 coolant and over 300 oil temps and that is with pretty seriously thought out oil and water (and gearbox) cooling. I just have to doubt you can get the miata platfrom to run cool without major surgery and modifications.
I'll be happy to torture test one to see!
kverges is online now   Reply With Quote
Old 10-20-2009, 08:18 AM   #32 (permalink)
Our local track is a tough one for cooling. It takes about 7 laps for a stock LS1 Corvette driven relatively slowly to start to get hot. Our shop V8 car, fitted with a modified LS1, can easily handle the same at a faster pace. The GM engines are much more efficient at cooling than the stock Miata one is - there's some pretty interesting information out there about the work done to remove steam pockets in the heads, for example. So it's fair to say that you'd have to do the same things to a Miata that you had to do to the Z06 to keep it cool.
Brakes, yes. That's a legitimate concern as the load on the brakes goes up with the square of the speed. There are some good options out there and we've been able to stop 350 hp racers in the past, but you're certainly going to need something more than good pads and fluid.
I wouldn't call a V8 Miata a "cost no object" car. If you get a turnkey, they're cheaper than new Corvettes with the same drivetrain. If you build it yourself, it's quite a bit less. Unlike a Radical, you can drive it on the street!
In fact, kverges, I have a pretty good idea of what's in that turbo Miata race car of yours, and it's not all that far off what it would cost to have a V8 version made
Old 10-21-2009, 06:42 AM   #33 (permalink)
kverges's Avatar
Actually I bet I can beat your prices. I have 2 Miata FMII turbo RACE cars for $20K each, turnkey (except for seat). That includes hardtop, Hydra EMS, upgraded hardware (sorry, but the FMII hardware will not stay tight in race conditions), full weld-in SCCA legal roll cage, new Koni coil-overs, specially ducted hood and fascia, specially ducted brakes, new clutch, Torsen posi, oil cooler, big Koyo radiator, and fresh paint as needed on the donor cars.
Doubt you can do a turnkey LS car for that or even a DIY might be tough.
These cars have everything we have learned as the only endurance racing team that races turbo Miatas as far as I know. Ist overall in the NASA Texas 4 hour race in 2008, !st in class and 3rd OA in the 8 hour in 2009.
We and FM need to do Thunderhill
Old 10-21-2009, 04:22 PM   #34 (permalink)
fireball25f500's Avatar
Not mine, found on Craigslist
LS1 Miata Track Toy
2005 Elise, Magnetic Blue Metallic, Sport Package, Touring Package
1991 SCCA Spec Miata, 2008 Waterford Hills ITA Champion
http://www.geocities.com/bcbackwoods
fireball25f500 is offline   Reply With Quote
