Go Back   LotusTalk - The Lotus Cars Community > Community > Garage Majal
Old 08-25-2006, 07:24 AM   #1 (permalink)
Buz
Garage opener
I found a great spot for my garage opener clipped inside the tray between the climate controls and the steering column. You can not see it there but there is a problem, it only opens the garage from inside the garage. I think the aluminum surrounding the opener will not let the signal travel forward, only backwards and up. Anyone have a good spot to clip or tape a small opener? I am tired of it rattling in the cup holder. My visors are long gone. No wonder the alarm range is so short.
Buz is offline   Reply With Quote
Old 08-25-2006, 07:44 AM   #2 (permalink)
bfm01's Avatar
I keep mine in a small black zippered (parking meter) change purse. It's in the black plastic cubby at the far left. You can't even see it there which is nice and stealthy. I just press on the purse to open the garage door, no need to remove the clicker. Easy.
Boomerang
bfm01 is offline   Reply With Quote
Old 08-25-2006, 07:46 AM   #3 (permalink)
Car Guy
wrh3's Avatar
I don't know if anyone here is familiar with this but I found it on the Audi/VW forums. Ben Moulding (brittmo@xmission.com) makes the Taidan opener for Genie and Liftmaster brand garage door openers. He modifies the opener to be weather proof for under hood mounting and the trigger is the high beam headlights Pretty neat for cars that don't have homelink, I have it on my other cars and it works great. If you don't have a Genie or Liftmaster (also makes Sears, maybe other openers) you can buy a receiver that ties into your existing opener. I believe the last time I checked these were around $40, you can email Ben for more information. No affiliation, just a happy customer. I have some instructions here:
http://www.billswebspace.com/TaidanGarageDoorOpener.doc
and here is what it looks like:
Bill
'07 BMW M Coupe, '05 Lotus Elise (Traded)
www.billswebspace.com/lotus
www.syntheticfirst.com
wrh3 is offline   Reply With Quote
Old 08-25-2006, 08:58 AM   #4 (permalink)
Laughin' Easy
FlyLo's Avatar
I velcroed my opener between the center tunnel and the passenger seat. Works fine.
FlyLo is offline   Reply With Quote
Old 08-25-2006, 10:11 AM   #5 (permalink)
Mods are good for you
Dave's Avatar
I threw all my OEM remotes in a drawer and bought one of those 3 button key ring programmable jobs...works great, long range, and cheap. Bought it from here.
2008 Solar S240 Exige
2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt
Dave is offline   Reply With Quote
Old 08-25-2006, 10:11 AM   #6 (permalink)
TimMullen's Avatar
Images: 19
My black opener (Sears) is velcroed to the underside of the top of the "cubby" opening on the driver's side. You can't see it from outside the car, but it's handy and opens the garage from the street without a problem.
94 Miata R Package - Black
Old 08-25-2006, 10:29 AM   #7 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
What happened to the whole "wanna be involved in the experience" attitude of the Lotus owner? Get out and open your dang garage door yourself!
xtn
Old 08-25-2006, 10:34 AM   #8 (permalink)
Donbecker's Avatar
Mine clips onto the sunvisor just fine.
Donbecker is offline   Reply With Quote
Old 08-25-2006, 10:39 AM   #9 (permalink)
an0nym0u5's Avatar
Mine clips onto the wanna-be cupholders.
an0nym0u5 is offline   Reply With Quote
Old 08-25-2006, 11:09 AM   #10 (permalink)
I installed a piece of that anti-slip rubber mat they sell for tool drawers in the tray and everything pretty much stays put unless I'm REALLY hitting the twisties. Sorry, no pix, my car is 3,000 miles away at the moment.
'05 Elise, Nightfall/Touring (1TON 1G)
'94 BMW 325iS
'67 Austin Healey 3000
Spudboy is offline   Reply With Quote
Old 08-25-2006, 04:06 PM   #11 (permalink)
... _ . ..._ .
nvrblu's Avatar
I keep mine clipped between the steering column and climate controls. It works great. I usually click the control when I'm about 300 feet away and it works every time.
nvrblu is offline   Reply With Quote
Old 08-26-2006, 10:45 AM   #12 (permalink)
Slag's Avatar
Nice, just bought one. Thanks
2005 Elise Green/Tan, Arqray Double Tip and Arqray Sport Cat, ITG Intake
Slag is offline   Reply With Quote
Old 08-26-2006, 08:26 PM   #13 (permalink)
DoctorJ's Avatar
Several years ago I bought a simple flush black push button and some wire at Radio Shack and connected it to my controller. I then drilled a hole in one of the unused button panels on my Z3s and then in the cigarette "snuffer" on my Z4. Then just stuffed the controller up under the console out of the way. When I sold the Z4 and bought the Elise, I took the assembly out and drilled a hole in the left cubby panel up underneath about in line with the light switches. Installed the button and stuffed the controller in the space behind the light switch panel. Tied a string to the controller so if it falls down out of reach I can still pull it out if I have to. Now I have a flush black push button up out of the way in the bottom of the left side light switch panel. Works fine from 100' or more down the drive. No controller to rattle around the cockpit and get lost or stolen. Easy to reach. Clean install. Here is a picture (the box on the left is the controller for my bluetooth hands-free). Sorry for the blurry pic.
05 Laser Blue, biscuit interior, Sport Package, Touring Package, Starshield, LS/TC, Hard top, driving lights, hi/lo HID lights, heated seats, brushed aluminum stalks, micro mirror, LIDbone, Alpine IVA-D100 head unit, NVE-872A Nav, Focal Polyglass speakers, 8" sub, Alpine PDX-series amps
DoctorJ is offline   Reply With Quote
Old 08-26-2006, 09:30 PM   #14 (permalink)
I keep my opener stored handily on, or very near to my couch. When I get near the house I call my wife and she then gets up and pushes the button to open the garage door. It's worked perfectly well for over a year and only requires a quarterly preventive maintenance gift of Prada shoes.
DeathTrap is offline   Reply With Quote
Old 08-27-2006, 11:43 AM   #15 (permalink)
Club a baby seal today!
hatchy's Avatar
Bahahaaha!
hatchy is offline   Reply With Quote
Old 08-27-2006, 03:47 PM   #16 (permalink)
teekster's Avatar
I second the suggestion for velcroing to the underside of the left cubby. When I had it on the bottom of the cubby, it didn't work. Works great on the underside and it's stealth.
2005 Lotus Elise
2008 Land Rover RR
2008 Jaguar XJ Vanden Plas
teekster is offline   Reply With Quote
