Go Back   LotusTalk - The Lotus Cars Community > Community > Garage Majal
Old 12-06-2007, 04:10 PM   #1 (permalink)
Wizard of Pugz!
qball's Avatar
Images: 3
Garage wall finishes
My current house has stucco on the inside of the garage... or at least cement board, with a stucco/sand coat finish. Unfortunately, this makes it a bitch to hang banners, neon lights, and such. You have to use anchors and cement screws... no nails, thumb tacks, etc.
The new garage we are building in our new house has drywall specified by the architect, but the new builder is recommending stucco...
So... those of you with BIG garages, what do you have for wall surfaces inside the garage?
Any guidance here?
qball is offline   Reply With Quote
Old 12-06-2007, 04:16 PM   #2 (permalink)
V Not my picture V
RacyTracy's Avatar
Well, I would think you would want fire-resistant drywall between the garage and the house. And I would drywall the whole thing.
RacyTracy is offline   Reply With Quote
Old 12-06-2007, 04:18 PM   #3 (permalink)
Wizard of Pugz!
qball's Avatar
Images: 3
Garage is detached.
Old 12-06-2007, 04:27 PM   #4 (permalink)
V Not my picture V
RacyTracy's Avatar
Well, I would still use drywall for the whole thing.....for the reasons you gave about simplicity in hanging things and ease of repair should you need to cut a hole in it (to access plumbing or electrical or something. Is the moisture-resistant type something you would want to look at since you're in FL?
Old 12-06-2007, 05:07 PM   #5 (permalink)
short angry bloke
codymac's Avatar
Images: 19
IMHO - either drywall, pegboard, slatboard, or... tile.
Old 12-06-2007, 05:28 PM   #6 (permalink)
Derriere Extraordinaire
Z-dculus's Avatar
drywall
2006 KG-Sport Pack, LSD, TC, SS, RAC Monolites, Sector CF Roof, Carbon 3 Element Diffuser, V3 Panel eliminator (p-coated), Odyssey PC680, Boomerang , HIDs, CF Console, Multivex, Lotus Stage II, CF Zoom Rear View, Sector LidBone, Darth Holder (thanks Kestrel!), Sector 4Tress Harness Bar/CRD Mount, couple exige trim pieces- KGB Authenticated
2009 VeeDub Jetta (new kid on the block)
1978 Chevrolet Caprice Classic -(relegated to 'project car' status)
Z-dculus is offline   Reply With Quote
Old 12-06-2007, 05:41 PM   #7 (permalink)
RegGuy's Avatar
Cement board around the base for 2' then greenboard so it weathers the harsher conditions a detached garage will have. Tile the base area for easy cleanup. Run a 4" channel around the edge of the floor with it draining at the garage door. With the tile and cement floor's channel you'll be able to wash the floor and spray it down and everything will wash out the front with no damage to the walls. The upper area will be great for posters, etc. OK, so that's my image of a great garage...
I've never heard of stucco inside.
RegGuy is offline   Reply With Quote
Old 12-06-2007, 06:20 PM   #8 (permalink)
Meow!!
darkSol's Avatar
Slatwall!
From: http://www.kc-store-fixtures.com/slatwall_panels.htm
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs.
Lotus cars aren't made, they're hand built from dreams.
If you must choose between two evils, pick the one you've never tried before.
darkSol is offline   Reply With Quote
Old 12-06-2007, 06:23 PM   #9 (permalink)
A smile a mile.
NMRJock's Avatar
My father-in-law did his entire (large) shop in plywood. The cool thing about that is that you can put a screw or nail anywhere and you know it's going to bite.
Paul Parkanzky
Magnetic Blue with Biscuit Touring, LSS, Starshield
NMRJock is offline   Reply With Quote
Old 12-06-2007, 11:14 PM   #10 (permalink)
Mt. Diablo Hiker
drstvk's Avatar
Mine is basic sheetrock from 6" to the ceiling. concrete floor with concrete up the wall for the first 6". White enamel paint for a clean look.
I like the Slatboard look, but the sheetrock is inexpensive, works well, and you can hang anything on it easily. If the object is heavy, it's no problem to go through the wall to the wood studs.
steve
05 BRP Elise
08 BMW 335i
97 E36 M3 / 01 Dodge Durango
90 300ZX / 85 Toyota Cressida (with velour seats)
and son's red 08 EvoX (The Acura type S met a brutal end)
drstvk is offline   Reply With Quote
Old 12-06-2007, 11:22 PM   #11 (permalink)
Chris Mackey's Avatar
Whatever makes life better when your car falls off the lift :^)
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
ChuforiaGraffix.com SDD Lives On! SweetDaddyDelicious(at)hotmail(dot)com
Chris Mackey is offline   Reply With Quote
Old 07-15-2008, 01:43 PM   #12 (permalink)
Driver Wannabe
Zippy_Slug's Avatar
How well does that weather? Is it particle board? Plastic? Real wood?
Thanks
2008 Infinity G37s - Now for fun..
2004 Nissan Murano - For Utility
GRR.. Purchase on hold for a 2010 CO/KG Lotus Elise w/ Hardtop OR Exige
2000 VW GTI VR6 - SOLD
Zippy_Slug is offline   Reply With Quote
Old 07-15-2008, 08:09 PM   #13 (permalink)
xxxotic's Avatar
I have a concrete block garage and have solved the problem of mounting posters by using industrial strength velco on the wall and back of the frame for the poster.
Also it is easy to powerwash your floor since it wont matter if the stucco on the walls gets water on them.
I have to replace my walls in my bathroom since the shower stall didnt have concrete backer board, but regular drywall instead, which then had tile put over it. The grout around the tile came loose and some water had leaked thru and the drywall rotted out and crumbed. Found this out last night after I noticed I could push on the tiles on the bottom and they just gave way.
In Florida you might be able to get a lower insurance rate if it is made of stucco too.
xxxotic is offline   Reply With Quote
Old 08-06-2008, 08:54 AM   #14 (permalink)
Bob Dz.'s Avatar
I used the storewall system. Great system, a little pricy, but worth it. Tons of accessories. Different colors of walls too. The cabinets hang on the wall so everything is off the floor.
Talk to Charlie at "The Garage Store"
Organize your Garage with StoreWall
Bob Dz. is offline   Reply With Quote
