Go Back   LotusTalk - The Lotus Cars Community > Community > Garage Majal
Old 07-11-2009, 07:51 AM   #21 (permalink)
lotus69f2's Avatar
One of - in my opinion - the coolest features of the Barn is the system for hanging artwork. The walls are steel, so if a hole is made to hang art it is permanent and I didn't want to mess up the walls permanently for the artwork.
I envisioned cycling artwork through the building so a visitor might find different artwork every time they came (currently all the artwork hanging is what I have framed, but I have another 100+ things to frame so...). I did some looking at various commercial systems that museums use. They have a number of systems that are excellent for home use, but would not fit my application. For two reasons, they are fairly expensive (not an issue if you are doing a single 10 ft wall, but when you are doing 300 ft it makes a difference) and the rails from the prefab system had predrilled holes that were not space properly for the corrugations in the steel lining my wall.
So what I did was buy 8-12ft lengths of stock 1x1/8 in aluminum. Then custum cut them to length. Drilled holes to mount - to do this I had to tape the strips to the wall, make marks, then take it down again and drill because while the panels are uniform, there is some variability in how they overlap so I couldn't just make holes 9 inches apart. Then I used a drill mounted brass brush to finish the surface with random swirls. And attached them to the wall along the large ridges of the liner panles (which are raised 3/4 inches from the base of the panel) They are attached with stainless screws and stainless/neoprene cupped washers.
To hang the art I bought a variety of commercial rods, wires and hooks from AS Hanging Systems. My system mimic AS Hanging Systems Contempo system. Gallery Hanging Systems - Picture Hanging Systems, Security Art Hangers - AS Hanging Systems Home
Here are some really boring detail shots of the rails:
Kyle Kaulback '56 Mark VI '71 Type61mX '71 Type69 '72 Europa TC '74 Elan Plus2S 130/5 '91 M100 Elan '91 Type 106 Esprit X180R LotusSport 110
http://autos.groups.yahoo.com/group/PhillyLotus/
http://www.lotustalk.com/forums/f218...us-barn-75834/
lotus69f2 is offline   Reply With Quote
Old 07-11-2009, 08:07 AM   #22 (permalink)
lotus69f2's Avatar
As I mentioned earlier, the Barn is heated. I chose radiant floor for it's efficiency. One drawback it that it takes a long time to increase the temp in the building, by the same token it takes a long time to cool off. I envisioned leaving the Barn at a cold but above freezing temperatur of 45F, than cranking the heat up to 60F for the time I wanted to do something in there. But it takes about 24 hours and a crap load of heating oil to do it. So I leave the temp at 65F now at all times during the Winter. Temps get higher on Sunny days. I have an 875 gallon capacity for storing oil (tanks can be seen in one of the exterior shots). The one and only year I have heated the building so far I didn't need any more than that and had some leftover. Part of the 875 gal capacity is a 55 gal drum located next to the furnace in the furnace room. The furnace can draw oil directly from the exterior tanks, or I can switch it to the 55 gal drum. When I have waste oil I pour it into the 55 gal drum, then use a pump to top off the drum and dilute it with home heating oil. When dilute it make little difference to the heater, and save me a few bucks in heating oil and the hassle of disposal.
The room for the furnace by the way is a good place to stor my large vacuum, mop bucket etc.
Hot water is supplied to the bathroom with a point of service hot water heater. Thes units draw a massive amount of current when in use, but since they only use the power when in use (water flowing) they don't use anywhere near as much power as a traditional water heater. For a infrequently used area they are fantastic, and take up very little space to boot. They can be purchased according to amount of hot water needed per minute. I chose a flow rate that would allow for a nice hot shower.
Pics of Furnace/55gal drum, manifolds for radiant floor heat, point of service water heater.
Old 07-11-2009, 08:15 AM   #23 (permalink)
lotus69f2's Avatar
Air
I was advised by another garage guy to keep the compressor outside - due to noise, and to plumb pipes into the walls so air outlets where avilable throughout the building. I didn't listen. Not because it was good advice, but because I didn't want the expense of doing so I didn't need the utility.
While I have air tools I rarely use them. For the most part air for me is to fill tires. So I bought an upright compressor with a reasonable capacity and pressure (mine was actually fairly inexpensive since it was a floor model at Sears), then I bought a ratcheting wall mount hose reel with 100 ft of hose Legacy MFG L8310 - Levelwind Retractable Hose Reel for Air with 3/8 in. ID x 100 ft. Hose.
Now I have enough hose to reach anywhere in the barn. I can even drag it all the way to my houses garage.
The only detractor is indeed the noise, but since I don't use all that much air it isn't a major issue.
Old 07-11-2009, 08:19 AM   #24 (permalink)
Back in the Saddle
Moto44's Avatar
Wow!!!
I'm so pleased you have been kind enough to share this with us. Truly an inspiration!
If nobody ever died doing it, how much fun could it be?
Moto44 is online now   Reply With Quote
Old 07-11-2009, 08:22 AM   #25 (permalink)
Denuo Volatilis
...m...'s Avatar
...thanks so much for sharing - your europa is gorgeous!..
Old 07-11-2009, 08:23 AM   #26 (permalink)
lotus69f2's Avatar
Moving car around.
For the most part with the size of the Barn and the number of cars I can either push or drive the cars to position them. But if I get any more cars - and you know I will - positioning them will be an issue. So when I bought my lift I also picked up a set of car dollies. They work quite well, but it takes a fair amount of time to set them up and put them away so I often jus do the drive back and forth a bunch of time to get a car parked.
They are very useful if a car does't run. Or if you want to get cars really close together. Or if you want to position car just right - like the fan pattern I did for the Elans, Elise and Europa for the photos.
One caution is the depth you slide them under the car. Lotus are low. The dollies I bought are set up to for really wide wheels. If you just push them under just about any Lotus you will smack them against the undercarriage. So careful placement just deep enough to capture the tires is in order.
Old 07-11-2009, 08:27 AM   #27 (permalink)
lotus69f2's Avatar
One final note. I needed doorstops for the man doors of the Barn. I have a bit of a breeze through my property and doors left open will suddenly slam shut or blow wide open. Regular wood wedges cut from a 2x4 didn't work because the doors are hung a bit high. So I racked my brain for another solution, and also figured I should stick with Lotus tradition of using one part for more than one purpose. So I bought a couple of wheel chocks at Harbor Freight for about $7 each.
Voila!
Old 07-11-2009, 08:33 AM   #28 (permalink)
KMH
kmhepler's Avatar
Images: 1
Originally Posted by lotus69f2 View Post
I live in an area of PA called PA Dutch Country which is well known for Hex signs that decorate barns. I live just off of a road known as the Hex Highway for the number of hex sign decorated barns that used to be visible from the road. Since my barn's rear view is visible, I decided to continue the tradition. Below are closer views of both of the hex signs.
I grew up in the neighborhood. My grandparents ran gas stations and a restaurant from the 1930's until the 80's within a mile of Kyle's place. No question he accurately captured the essence of the building decorations of the environment around him. The green trim on white buildings was classic in the area, used on houses, outbuildings, and commercial buildings as well.
But not barns! My only quibble would be calling the building a barn does stretch it a bit from the local culture. No respectable farmer in that part of the world would have a barn without two floors both of which should be accessible to driving equipment and living stock into them, i.e. built against a hill, a style called "bank barns" and they would be painted RED. See www.paedrigdesign.com - Pennsylvania German Barn Star Pictures
But, hey, its fantastic, Kyle. Every generation has its own interpretive based on older motifs. You have every reason to be proud. And as you know SSRIs can be effective if the OCD starts interfering with a normal life!
--K
PS Definition of a hobby: Black hole to put money and effort.
kmhepler is offline   Reply With Quote
Old 07-11-2009, 08:34 AM   #29 (permalink)
lotus69f2's Avatar
If anyone has questions, or wants more detail on any of the features covered already or otherwise, just post and I'll do my best to clarify.
If you'd like to see it in person than come to my event:
PALS event - July 18 – Golden Age Air Museum Tour / Brats and Beer at Kyle’s
If you can't make the event, but you are going to be in the area, PM me and if I am available I'll give you the personal tour.
Old 07-11-2009, 09:27 AM   #30 (permalink)
How you doin'?
PatrickShim's Avatar
OH WOW.
PatrickShim is online now   Reply With Quote
Old 07-11-2009, 09:37 AM   #31 (permalink)
ksdaoski's Avatar
sick
ksdaoski is offline   Reply With Quote
Old 07-11-2009, 09:48 AM   #32 (permalink)
My Lotus hates my bike.
PhlypSide's Avatar
Images: 9
*drool* A perfect home for all your Lotus toys (and such a cool collection too ) !
NOTFWD.com (NOT Front Wheel Drive)
Originally Posted by Doodler View Post
......Go backwards. Go back to a time when there were no Manettinos, no ASR, no power steering, no lifeless video game-like shift paddles, no buttery smooth manual gearboxes, no featherweight clutches, no functional air conditioning.....
PhlypSide is offline   Reply With Quote
Old 07-11-2009, 09:49 AM   #33 (permalink)
rnr
daily driver
rnr's Avatar
Fantastic barn and collection.
I'd love to see more pics of the cars and hear more about them. I'm sure you must have had some interesting acquisition stories over the years (and being a Lotus probably the occasional breakdown story as well )
http://www.rahulnair.net/blog
rnr is offline   Reply With Quote
Old 07-11-2009, 10:39 AM   #34 (permalink)
Ex and future Lotus owner
Cardinal's Avatar
Images: 8
That barn has PA written all over it. Nice set-up.
the1sen: why move forward with design when you can recreate a monstrosity from the past?
Cardinal is offline   Reply With Quote
Old 07-11-2009, 10:40 AM   #35 (permalink)
Oh, NOW I get it!
Notorious L.R.G.'s Avatar
Great to see an old line Lotus Ltd member here on EliseTalk...er, LotusTalk. I knew from the first photo that the barn had to be in PA! Glad you were not shy about showing off the collection. Love the X180-R!
Rich
(Originally from CT, in Lotus Ltd since way back in 1994 or so.)
Notorious L.R.G. is offline   Reply With Quote
Old 07-11-2009, 11:40 AM   #36 (permalink)
Double Trouble
Flash G's Avatar
Excellent barn and collection!
Turn your flatscreen TV into a work of art.
Modern Art DVD | Plasma Aquarium DVD | Widescreen Fireplace DVD
11 Esprit??? (Wish List)
07 Exige S - Ardent Red, Stage II Exhaust, LSD, Touring pack
06 Range Rover Sport - Java Black
05 Elise - Ardent Red, Stage II Exhaust, Touring pack
Flash G is offline   Reply With Quote
Old 07-11-2009, 11:44 AM   #37 (permalink)
Dishing out the Scunyun
dickedup's Avatar
True... You ARE a Looky@Me of the First Water amigo!
For a long time I have debated whether I ought to do this or not, and finally decided to go for it.
I've collected Lotus cars for some time now and have accumulated a decent collection of not only cars, but also artwork and ephemera.
My first house had only a 1 car garage and my collection quickly outgrew it, so when I built a house on some acreage I decided to build a Barn just for my Lotus (or more accurately, I bought the acreage to build the Barn - the house was a necessary add on).
I will be the first to admit that I am to an extent "showing off", but I decided to post this thread to Lotus Talk so I could share my experience with making a dedicated Barn for my Lotus with others who might be considering doing the same, and perhaps even help out those who are not able to follow suit, but could use some of my ideas or experiences to improve their own space.
Feel free to ask questions and make comments. I'll do my best to add photos of requested details and answer what and why questions as they come up. Just be patient.
So here goes......
Great start but you require a corner with a over-stuffed couch, two Big-Azz La-Z-Boy chairs, and a fridge full of various beers resting on a well-worn Persian area rug.
You're missing a flat screen too.
Is it just me, or did this trip go downhill since we ran out of Lucky Lager
dickedup is offline   Reply With Quote
Old 07-11-2009, 12:07 PM   #38 (permalink)
Vexige's Avatar
WOW!!! Can't wait to visit your "barn" next week.
Vexige is offline   Reply With Quote
Old 07-11-2009, 12:46 PM   #39 (permalink)
DeanG's Avatar
Looks good... except your Mark IV needs a bit of polishing and the X180R needs some track time!
Hope to see you next weekend.
DeanG is offline   Reply With Quote
Old 07-11-2009, 01:08 PM   #40 (permalink)
Parramint's Avatar
Hi Kyle
I have had the pleasure of visiting a few 'Lotus Barns' in the U.S.....Dave Koski's, Dave Nagler's, Nigel Harrison's. Can't wait to have a guided tour around yours, it look amazing.
I must admit the Chapman Barn does just have the edge, with 25 F1 Lotuses. But then they have had a head start...............
Nice job Sir
Best wishes from Norfolk
Richard
Parramint is offline   Reply With Quote
