#61 (permalink) | |
![]() Babak Club111 Central Plains Coordinator '05 Elise - Touring, HT, StarShield '99 Ducati 996 Bip '05 Freelander SE |
#62 (permalink) |
MR2 Mk1a
You can catch an oversteer situation perfectly with left foot braking.
edit: proof: http://www.graham-walsh.com/carlimits/carlimits.wmv Last edited by Barney Jr : 01-05-2005 at 03:36 PM. |
#63 (permalink) | |
#64 (permalink) |
I would recommend that the " both feet in" option is to spin the car quickly to a stop before it hits anything.
If you really want to catch a sliding tail. "catch" being less appropriate than anticipate to correct, you might find it easier if you come off the brakes or gently lift the throttle depending on when you find oversteer, coupled with or without opposite lock.
Dr. Edgar SHIH " The crooked shalt be made straight......" The Bible http://elise.pinkcore.com/forum |
#65 (permalink) | |
Again, this is after you have lost it.
#66 (permalink) | |
The surface also has little or no camber personality, so I believe that even for an average driver like myself (with the ABS fuse in my FED Elise pulled) that stunt would be possible in that scenario. I believe Walsh is also a pro driver in a controlled theatre, meaning that he had foreknowledge of the situation(he created it), which is different than me getting caught out at speed on a track or contaminated public road surface. On a US road course of asphalt/tarmac and camber built in at higher speeds a different approach would be necessary. With a mid engine rear drive car there are two ways to lose the rear. first is too much load on the rear tires at the peak of the slip angle, and second is not enough load on the rear tires(or superior front grip) at some point of the rear tires' slip angles. Best drivers know which problem it is and exactly what and how much correction is required without losing too much time. In a front driver you add a little corrective lock and use the throttle to pull out of the unbalance, which may or may not be a no-no in the Elise. m Last edited by thegit : 01-06-2005 at 04:35 AM. |
#68 (permalink) | |
Driver comfort is needed for confidence. Quite a few of the top tier WRC pilots will drive one handed in certain situations for almost a stage. m |
#70 (permalink) |
Nowt wrong with his hand placement for that manoeuver.
Oh I see! He had his hands at 3 and 9 instead of 9 and 3 In certain areas of the US 10 and 2 hand placement is taught over the 9/3 method. personally, I prefer a "necker Knob at 5'o'clock m |
#72 (permalink) | |
Necker knobs used to be common back in "the old days" - especially before power steering. It's a knob that's clamped to the steering wheel. To turn the wheel, you grab the necker knob with one hand, and crank the wheel as you would using a crank handle (the knob rotates on it's shaft). It was handy so that you could drive down the road, steering with your arm around your girl friend (necking)... ![]()
#73 (permalink) |
If it's about the thumbs Barney, It is usually recommended NOT to have the thumbs located in such a way that the spokes of the steering wheel catch them, break them, and help your orthopedic surgeon buy another lexus.
I have sprained mine in the past during my autox days. m |
#74 (permalink) |
MR2 Mk1a
lol, cheers Tim for the explanation
![]() about the thumbs, I always have my thumbs in the same way as Walshy has. Can't see the risk of breaking being that high unless you're really doing some destruction derby? It sure as hell steers nicer IMO ![]() |
#75 (permalink) |
I recall an autocross incident in my MR2. Grippy tires on concrete. Got into a small bit of trouble... and the car violently reacted.
It jerked the wheel out of my hands causing a strain in my wrist that hurt for a long time. Raised welts and black/blue marks from my harness straps also. Had to explain those when I got home. ![]()
#76 (permalink) |
MR2 Mk1a
phew, good thing I never crash or make mistakes then
(famous last words...)Will try to remember to keep the 'thumbs up' . Will take some training though as gripping it with your thumb is the most natural and easy way to hold a steering wheel ![]() Last edited by Barney Jr : 01-07-2005 at 04:00 PM. |
#77 (permalink) |
I have some really bad habits when racing..much worse than thumbs.
![]() Like letting go of the wheel. ![]()
