#121 (permalink) | |
Elise Daily Driver
Scott SY / LSS / Touring / Hardtop |
#122 (permalink) | |
Starlight Black - Biscuit / Turbo XS Intake / QS / RAC Monolites - SOLD |
#123 (permalink) | |
User, Registered
#125 (permalink) | |
#126 (permalink) | |
took me nearly a year to be able to catch it on the snap back. scary stuff even in a big parking lot! one thing i never did was panic and that saved my mr2 sooooo many times |
#127 (permalink) | |
I have been assuming my (over)corrections were too much. Just trying to see if others have had the same experience and what they did and/or if my setup encouraged this behavior. Either way, it will not keep me from the track. It the best classroom there is.
#128 (permalink) |
I'll admit haven't pushed the Elise all that hard. Did one throttle off oversteer, touch of opposite "lock" and back on throttle and it was like nothing happen. Was use to pushing the MR2 Turbo hard the '91-92 (had a '91), the rear would toe out under load, unload them and they would toe back in that plus the nature of a mid-engine car, would take 3-4 tail wags to settle in. So was surprised by how easy the Elise was to catch.
KLM- I'd guess since this is happening on the higher speed stuff for you, it's more a matter throwing the back end out with a lot more momentum, which makes it harder to catch... a good sign to take entry a hair slower. |
#129 (permalink) |
Full GRP Jacket
Throttle/Lift incuded sliding and recovery, and sliding in general.
As of the last few months, I've been ever increasingly enamored with breaking rear traction in the Exige. Ive been experimenting with different inputs, and taking mental notes of events that, in practice, are way different than I what expected, in theory.
All of the following situations are on clean, wet roads, with wear bar rears, NA Exige. no LSD. TC off(and performed on a closed course). unless otherwise noted. This is what I call a controlled slide, in that what happens, in practice, is what I expected to happen, in theory: Approaching a turn, in gear, turn in, and apply throttle. The rear breaks loose. Counter steer. Spinning rears. Minuscule amount of lift(<1mm. Adding throttle, or maintaining throttle, I found, just spin the tires), and immediate(the lift and reapply is one motion of up-down asap) reapply of throttle brings everything back in order quickly. I found that sometimes during mid slide, lifting(TINY amount of lift. 1mm max) stopped the increase of slide angle(spinning rears), and reapplication of throttle straightened it out smoothly. It depends on the amount of throttle used during initial breaking of traction. The lift helps tires grab. Now I'm not sure, since I didn't try, but I think if I didn't lift in the instances where I did, I would have spun right around. Besides slight throttle input variations(noted in parenthesis above), this is a constant, controlled, repeatable event. This is what I usually try, and successfully, attempt. Unexpected events: 1. Mid turn, rear breaks loose, total lift. Counter steer. Throttle. Car straightens out. No additional slide angle. 2.As noted in the "controlled" paragraph, following proper theory(apply more throttle) didn't work in some instances. Before, I always thought that in a slide, one must not lift. But after these events, I can only come to a conclusion that a throttle induced slide requires different actions compared to a throttle-lift included slides. And lifting once over steer has occured doesn't Anyway, I think that covers it. Thoughts? Additions? Disclaimer: Anything you do in your car is not my problem.
My line is never wrong, it just doesn't always correspond with the asphalt. Above the clouds, the sun is always shining. Last edited by mrluky : 02-07-2008 at 01:46 PM. |
#130 (permalink) | |
2005 Lotus Elise, "the orange car": hard top, touring, starshield, orange/black Lotus Sport seats, 6-point Schroth belts, 4Tress Harness Bar, SJ Racing 15x7/16x8 track wheels (plus stock wheels for the road), RTD Brace, HIDs, Safety Solutions R3 Head & Neck Restraint System 2006 BMW M3 Competition Package, "the blue car": stock |
#132 (permalink) |
Ah, I see now... What I read was "clean, wet roads"... and I don't equate "road" with "track" (which explains why the magazine is called Road AND Track). And because autocross is never held on a road, to me it sounded like you were driving on public roads.
Regardless, even if you were on a road that was somehow closed off to the public, it's still a road. And most of the roads I've driven are many times more unkind to spinning cars than race tracks. (you can hit trees, rocks, walls, etc in what we call "accident tangents.")
#133 (permalink) |
At a track day late last year- throttle lift oversteer saved my bacon (T3 Sears Point). Drove in the rain/ wet course in the morning for the first time. Was feeling out of sync on a dry course in the afternoon. Had a instructor jump in. He quickly pin pointed that there were a few turns, I was doing a early apex and pinching off the exit. So I come up to this turn (uphill approach, downhill exit). I pull a early apex, however this time I have the speed and throttle for a late apex. I'm coming up to the edge of the track and that outside wall is looking damn close. If I did a full fledge lift and tried to hit the brakes, I'd spin and be carried into the wall. If I let it go off, with the wet grass I may not avoid kissing the wall. I did a quick lift. By doing so I gave up traction on the rear tires, with that extra weight on them it allow the rear to swing around- getting me to turn in. Back on throttle and on my merry way.
So I'd agree knowing how to use throttle lift can be a good tool to have. But you better be pretty darn aware of how the car reacts to it. Higher speed turns your on a very tight rope. In my case it was more of a mid-speed. Have been driving mid-engines for a few year and already done a few lifts on the Elise and found it pretty benign. It was more of a reflex action. |
#134 (permalink) | |
MY car weighs 3166lbs
Not that I think this point needs any more emphasizing to the guys on here, but I learned this lesson the hard way. I knew had learned from reading and general common sense that one should NEVER break in a fast turn. I knew I wasn't supposed to brake in that 65 mph turn, but I panicked, and I did. End result was that I ended up with a body restyling free of charge, courtesy of Mother Nature and physics. It gave my car that neat "guard rail" enhanced look. Classic. It was actually an easy lesson to learn, but just would've preferred to learn it a different way. Oh well, at least I got it out of my system before I got my Elise! ![]() Good write-up, thanks!
"Any car which holds together for more than a race is too heavy" - Colin Chapman ![]() ![]() -07 Chevy HHR -08 Kawasaki Concours 14 -09 Buell XB12Scg - GOT IT FOR HALF PRICE! Looking for a Lotus! |
#135 (permalink) |
untitled
We (MR2 guys on another forum) were just talking about the physics of midengined cars and someone posted a link to this excellent topic, which I remember reading before. I just thought it could use a BUMP for all the Lotus owners who may not have seen it.
It is all about "Other". |
#136 (permalink) | |
MR-S Owner
