Live to Drive
Question about Falken Azeni RT-615s
Can you confirm that these size specifications will fit Exige wheels?
205/40R-16 83W XL B 235/40R-17 90W BLK Several of my friends and surely many others have run these tires successfully so I know it can be done even though they are not the stock sizes.
Be an alpha male. Drive a Lotus. |
Hydrocarbons Rule
I think you'll want a 205/45/16, but i'll have to wait until I get home from work to check for sure.
I know I'm running a 215/45 on a 7j rim right now with these tires and the same rear as you posted on a 8j rim, but the 235 will have no problem fitting on the stock 7.5j rim...
2006 Exige; BWR Supercharger, Adj Sway Bar, Ohlins Suspension, BSK Oil Catch Can, Moroso Oil Pan, ORC Clutch, Custom Exhaust, Black Volk Racing CE28N's w/ Toyo R1R's, 2 piece rotors, Pagid Blue Pads, BSK Wet Carbon (Side Skirts, Front Lip Spoiler, Gas Cap Cover, Center Console, Door Panels), Dry Carbon rear Diffuser, Harness Bar, BWR Gauge Mount, OMP Superquadro steering wheel, LETSLA Short Shifter, V2arms, Rear Tow Link Brace, RLS Battery Bracket, BOE Tow Bar, Stickers. Last edited by Dragon : 01-26-2009 at 12:45 AM. |
Live to Drive
Thanks. On DiscountTire's website, only the 205/40 is shown in that width. There is also a 215/45/16. I thought they were each supposed to be 10mm wider than stock.
Hydrocarbons Rule
I believe the 205/40 is considerably smaller in diameter than the stock size. It will fit, but will cause possible issues with the ABS and TC as well as drop the front of the car lower to the ground. I'm using my iPhone ATM and on the move. I can get back with info in a couple hr's unless somebody else can get it for you before i get home...
Hydrocarbons Rule
Home now..
Here's a link to the size chart for the RT615'sFor Reference the Stock Front diameter is 23.6" and the Rear is 24.9" 205/40/16 = 22.5 (1.1" difference) 215/45/16 = 23.6 (Same as stock) I would definitely go with the 215 as 1.1" is a BIG difference in that it will drop the car .55" (14mm's). You will also have a bigger gap between the fender and tire that also won't look very appealing. It is recommended to put the 215's on a 7-8j rim, but they should fit a stock 6.5 ok. I'm not 100% on the stock offset being ok with this tire however so hopefully somebody else will chime in on that. You may also want to look in to running Toyo R1R's... I just picked up a set, but I'm still waiting on my new rims to get here so I can put them on the car.
Live to Drive
Thanks so much Dragon. Now I just need to decide between these and the R888s. I might get these just for now and get the R888s in the summer. These are only $460~ shipped from this vendor!
#7 (permalink) |
Supporting Vendor
![]() Join Date: Nov 2008
Excellent responses Dragon. I just came across this thread today, sorry for the delay. Dragon hit in on the nose though, thank you for responding.
We offer the lowest delivered price on tires and/or wheels guaranteed!. If a competitor has a lower delivered price, please let us know, we won't be beat. Shipping and handling is free to the lower 48 States and Canada. We also offer free mounting and balancing with any wheel and tire combination. If you aren't satisfied for any reason, feel free to send them back to us within 30 days. We also offer the industry's best road hazard program and no, it is not pro-rated. Our certificates for free replacement cover you for the entire life of the tire (down to 3/32nds of tread). If anything goes wrong (aside from vandalism) we will replace the tire for FREE. 1.888.459.4080 EXT.#1865 discounttiredirect.com |
#8 (permalink) |
Live to Drive
I needed tires shipped out IMMEDIATELY and unfortunately, the Falkens would have arrived late, so I ordered some Nitto Neo-Gens... Only cost me $388, but they are not R-comps
Thanks to Peter at Discount Tire He says they handle great!
#9 (permalink) |
Live to Drive
OK...I need help again! It's an emergency!
I read up on the Nitto Neogens I bought and apparently, they are very streetable, all-season tires. I do not want these on my car. The rep told me they are high performance street tires. Anyways, the new rep I spoke to told me he can get the Falken Azeni RT-615s to me in time, but he does not think the fronts (215/45/16) will fit on the 6.5" front wheel without vibration. Many of my friends have run this set-up. I have the sport wheels on a 2006 car. What's the deal here?? Will they fit???
#10 (permalink) |
Hydrocarbons Rule
The sides will bulge a tiny bit, but you shouldn't have any issues with them.
#11 (permalink) |
Mods are good for you
Been running these Falkens on LSS for about a year now, great tire for the money:
215/45-16 225/45-17
2008 Solar S240 Exige 2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt |
#12 (permalink) | |
Live to Drive
Thanks guys. I just placed the order and I'm sending the Nittos back.
That's the exact set-up I ordered.
#13 (permalink) |
Supporting Vendor
Good choice on the change Bavarian, the Neo Gens would be a great everyday tire, I ran them on a Lancer I had for a while and loved them but the RT615's are a much higher level RT performance tire. You will be very happy with the swap.
Thanks for your support! If you post pictures with them on, send me a link.
#14 (permalink) |
How come nobody wants to use Hankook Ventus R-S2 Z212? For the front they come in 205/45-16 and the rear you can use either 225/45-17 or 245/40-17. I think they are even a little cheaper than the Azenis and about the same performance wise. I don't have them for my Lotus but have them on my Bimmer and they are great.
'08 Honda S2000 CR (Rio Yellow Pearl) '07 Lotus Exige S (Aspen White) Touring, Traction, Starshield '04 BMW 330 ci (White) |
#15 (permalink) | ||
Live to Drive
I've never heard of them. I'll check them out once I destroy these Falkens. These are just temporary tires for me. The price is unbeatable for this level of performance. I typically run Toyo R888s.
