broke as a joke
mod updates on my S **56K warning**
I figured id start a thread with mod updates on my car as it progresses.
I will compile mods ive done in a series of pics with included description. feel free to ask, suggest or comment as you please Thanks for looking ![]() purchased 07/07 @ Newport European Lotus with 20 delivered miles
-Coi- '07 AR Exige S+Gotham, Von Hep, corner balanced&tuned SACHS, 6k HID, JVC KD-NX5000, Alpine 4ch. amp, JL stealth box, s111 rear towhook and harness bar, Starshield, TG4 1/4 turn fasteners, SS brake lines, bling bling eng bay, painted calipers, TD 1.2 wheels w/ Toyo R888, Safecraft harnesses, DRL delete, + more to follow Join Lotuscar.ning.com for LA Lotus social events also add me: www.myspace.com/kandyredcoi |
broke as a joke
first few mods (forgot the date)
polished i/c, i/c piping, and valve cover painted gas cap red wheel pinstripe and painted brake calipers and HID (not pictured)
broke as a joke
last month installed, corner balanced and aligned a set of single adj SACHS suspension @ West End alignment in Gardena, CA.
broke as a joke
this month while doing my first DIY oil change and Von Hep exhaust and rear tow hook install @ Danstoy in Santa Fe Springs, CA. we ran into a few concerns
1) the car seems to have an "oil leak" somewhere comming from above the oil filter, at first inspection we thought it was just oil run off from the last oil change, so we wiped everything clean before i set off on my way home. when i got home i found that the rear diffuser seems to have oil all over the rear edge of it(pictured provided below) looking like what could be that same "oil leak" we noticed BEFORE doing the oil change. i guess my concern is has anyone ran into this problem, or does anyone have any idea on what it can be last thing is will this still be covered by warranty? from what we can gather, it seems like its comming from way up on top, maybe the oil from the S/C lines? 2) torque specs seemed to have been loose on the rear driver side suspension pieces cnsiderably more than the other 3 corners any clue on why that would happen? any help or info would be greatly appreciated!
broke as a joke
here are some pics of the new mods to the car this month
Third Eye Open
I would inspect your oil sending unit located directly above the block adapter where you screw your filter into, It is a 1/8 npt port that supplies the ECU signal for your oil pressure. It definately has pressure and can spray if defective or damaged. You should have no oil leaks above that unless it is coming from the valve cover but the front side of your engine should show evidence of that - use a dental mirror and a flashlight to inspect.
Oh yeah, Nice Mods ![]()
Bone Stock
#7 (permalink) |
Lotus Service
your oil leas is going to be your breather gasket. the black pipe attaches to the block just above the oil filter housing and goes up to attach at the valve cover by the vvt sensor on the passenger side. replace the gasket were it attaches to the block with 3 nuts on the bottom and your leak will be gone.
by the way beautiful car...and some great mods. ![]() T.J. |
#8 (permalink) |
broke as a joke
OMG...i really love this forum, you guys are so quick to help, i really do appreciate it!!!!!
and thanx for the comments, i also am purchasing the JLaudio sub box with an amp from another member here cant wait, and of course i will post pics thanx again
#9 (permalink) |
broke as a joke
OK just got back from LV, and just reinstalled my ECU with the GOTHAM tune on it, THANX charlieX, hopefully i can strap it onto a dyno in the next couple weeks
also just got the JL stealth box in the mail, thanx AMLDB7 i will try to get it installed this week
#10 (permalink) |
GGM ENFORCER
gotham
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 GG EXIGE S ** MY CAR ** VIDEO CLIPS! ![]() '08 ACURA TSX 6-speed http://www.makeNYNYagain.com |
#11 (permalink) |
broke as a joke
yo yo yo just finished having my JL stealth box w/ 10w1 sub, and Alpine 4ch Vpower amp installed and tuned at Creative Car Audio in Santa Fe Springs, CA.!!!
here are some pics...IMO one of the "must have mods" for any elise/exige, unless you are a fulltime track junky...you really need one of these -enjoy
#12 (permalink) | |
No Acceptable Substitutes
How did you amp the speakers? Just the backs & stealthbox? Or all five?
2007 AW Lotus Exige S. Opts: Track Pack, Touring Pack, LSD Mods: Multivex mirrors, JLAudio 525/Stealthbox/Focal 130 spkrs, Alpine PDX-5 Amp, Switchable DRL, Sector111 F&R Tow Hook, Fire Ext, HID Kit, Bootie and Carpet Bling, Lotus Trim Shop leather/alcantara interior, Braille Battery, LED Parking/Dome/License Lights, Bane's stealth bulbs, alex's 1/4 turn kit, Stan's shifter mod, jim-c's spkr rings, codymac's 1/4 turn kit, Lotus Cup roof w/fettled clam, Schroth 6pt harness |
#13 (permalink) |
broke as a joke
you know what i beleive all 5...but i will dbl check in the morning...dude the audio sounds 1000x better, with the speakers amped along with some bass, its sweettt!!!
saw your sig, and i forgot to put the TG4 1/4 turn fasteners to my mods LOL thanx
#14 (permalink) |
broke as a joke
my Toyo R888 are in ... gonna pick em up 2moro!!!
woohoo ![]() ![]() ![]() ![]() ![]() ![]() now i need a set of "lighter" weight wheels, some TRF F1's are tempting me ... and maybe ill even custom color them ![]() ![]() ![]()
#15 (permalink) |
Rock Hard Member
![]() how did you do the red stripe on the wheel?... and is that a crack at the center or just an illusion?
Phantom Black 2007 Exige S. All options. Black 01' Mustang Cobra 'Vert ("some" modifications) daily driver |
#16 (permalink) |
broke as a joke
the red pinstripe is a simple pinstripe decal that can be bought at your local auto parts store and applied even when the tires are mounted on the wheel
the illusion u see is a water drip after the car got washed, we had to wash it prior to installing the decal to ensure good adhesion and yes andy all speakers are amped ![]()
#17 (permalink) |
broke as a joke
Here it is with the Team Dynamics 1.2 wheel
16x7 front and 17x8 rear in black with Toyo Tires Proxes R888 195-50-16 front and 225-45-17 rear new suspension tune comming soon
#18 (permalink) |
Car looks awesome Coi. Now you need some CF parts.
Jacob Join Lotuscar.ning.com for LA Lotus social events 05 Exise, 2bular 6 inch exhaust. BWR double adjustable Penske shocks, Hypercoil springs, HIDs, BWR front sway bar, Light weight PC680 battery w/BWR brace, BWR Black badges and wheel centers, Custom SCC paint job, SCC OEM Exige mesh kit and Exige rear clam details, LSD, Lotus sport clutch and light weight fly wheel. Sector front splitter. Stebel horn. Multivex Mirrors. Volk CE28 wheels |
#19 (permalink) |
broke as a joke
thanx bro! waiting to see your "wet" door sills and a front lip as well
#20 (permalink) |
Nice...
![]() No place for the red pinstripe?
