Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > The Salvage Yard
Old 09-02-2009, 08:09 AM   #1 (permalink)
Elise front crash structure
I am looking at buying a damaged elise, It has suffered damage to the front end so is missing a front clam shell, the radiator is missing and the crash structure is damaged. Just wondered if the damage to this structure would stop the fitting of a new clam shell once the radiator and cover is back in place? I dont want a perfect elise, just thought it would be fun on trackdays if i can fit a front clamshell and windscreen.
Thanks in advance for your help.
http://i616.photobucket.com/albums/t...ip/lotus-1.jpg
p4ilip is offline   Reply With Quote
Old 09-05-2009, 09:55 AM   #2 (permalink)
I just repaired an elise with front damage and can tell you that the radiator support unfortunately has some mounting bolts on the front of the crash structure. but if you can mickey mouse something to support the rad. structure to keep it from flopping (around and not tearing apart the clam) its more than doable for a track car. other than the rad. structure flopping around and providing the lower crash structure is ok for the front skid plate to mount to you should have no problem with the clam.
larry1 is offline   Reply With Quote
Old 09-07-2009, 01:46 PM   #3 (permalink)
Back to Basics
E_Swift's Avatar
You should put on a new or clean used crash structure no matter where it is driven.
I see that is not a Federal Elise.
There are sources in the UK for NEW crash structures around 700 EUR if you want to avoid the dealer.
Current:{2006 Volvo V50}{2005 Lotus Elise}{2005 Subaru Impreza 2.5RS}{2004 Subaru Impreza WRX STi}{1988 Lancia Delta Integrale}
Past: {1997 Honda Civic EX}{1994 Infiniti J30}{1992 Volkswagen Passat GL}{1988 BMW M3}{1988 Nissan 300ZX}{1988 Ford Taurus LX}{1971 BMW 2002}
E_Swift is offline   Reply With Quote
