Recommended head for Nakasil 10.5:1 - LotusTalk - The Lotus Cars Community
Old 12-01-2012, 11:07 AM   #1 (permalink)
mspenard's Avatar
What is a recommended head for use with BOE's Nakasil 10.5:1 block? Moreover, what are all my options (sector111's head vs Jim's ... ?) and the differences?
mspenard is offline   Reply With Quote
Old 12-01-2012, 01:50 PM   #2 (permalink)
Painful Novice
addertooth's Avatar
Key question, which supercharger or how many pounds of boost turbo?
addertooth is offline   Reply With Quote
Old 12-01-2012, 01:55 PM   #3 (permalink)
tommyc's Avatar
Call phil at boe or jim clayton the will give you all info you need. I believe jim has a beautiful head for sale
Sent from my Autoguide iPhone app
05 elise ardent red sport touring VF1 s/c, pro rad, arquay twin, etc etc etc
05 elise GG sport touring BWR s/c Charliex s/p dent in chassis=total loss
13 BMW 328i conv wifes car
03 GMC Yukon
90 eclipse gsx 420 whp sold
04 civic si sold
tommyc is offline   Reply With Quote
Old 12-01-2012, 02:28 PM   #4 (permalink)
MWR has a nice one that is reasonably priced as well.
Deja Vu is online now   Reply With Quote
Old 12-01-2012, 03:05 PM   #5 (permalink)
mspenard's Avatar
I'm also looking at the REV400. I'm a newbie here, trying to learn as much as I can about what is available and what is good practice. If anyone has anything to add or words of advice I'm all ears. Thanks.
Old 12-01-2012, 03:08 PM   #6 (permalink)
mspenard's Avatar
But what are the differences and pro v cons between Phil's, Jim's, Sector111's and MWR's? And what are the weak points with the stock head?
Old 12-01-2012, 03:53 PM   #7 (permalink)
Painful Novice
addertooth's Avatar
Jim Clayton's heads are highly regarded here. On something like a rev400 kit they might net you another 20hp (assuming other elements of your system are set up right). To get the most of the rev400 you will have to upgrade transmission and clutch. You need to look up engine internals as well. Google "2zz-ge glass engine" to get details on the parts which need beefing up.
Old 12-01-2012, 03:55 PM   #8 (permalink)
elise/europa's Avatar
My personal opinion: stock with good valves like Ferrea and slithly heavier spring (not Ferrea), and don't rev too high the engine, around 8200. Based on my experience, reving high with moderate spring can cause valve break on the retainer clip zone. I think that heavier spring can just be worst because of the added side load. Of course, you can port the head if you think that your rev400 still don't have enought power.
Elise 2006, white, BOE/EFI, 275 whp
elise/europa is offline   Reply With Quote
Old 12-01-2012, 05:34 PM   #9 (permalink)
mspenard's Avatar
Right, the glass-engine reputation of the 2ZZ, that is why I was looking at Phil's Nakasil block. His webpage is unclear to me, however. It states new pistons, but what about the connecting rods and crank???
I also have a Fidanza flywheel and new clutch in mind of course. And from what I've read knife-edging the crank isn't worth the bother because it'll likely require annual bearing maintenance (although I assume that advice is contingent on someone with sufficient experience or not balancing it).
Old 12-01-2012, 05:59 PM   #10 (permalink)
90% go, 10% show...
Apex_in_sno's Avatar
Nothing to worry about with the rods and crank, they're both beefey, no body's bent eather of these that I know of.
VFII, Eliseparts Sequential, Geartronics Paddle shift.
You name it, I've probably got that installed too...
1864lbs, full tank
Otherwise, it's bone stock....
Apex_in_sno is offline   Reply With Quote
Old 12-02-2012, 06:32 AM   #11 (permalink)
In regards of the crank knife edged, they are harder on the main bearing caused by sectional unbalance. For drag, yes; for road race for fun, no; for serious racing where every x.1 seconds count, maybe.
In regards of the clutch, the ACT will be able to take the torque, but when I was using it, I was breaking the pusher plate casing one a year. Now, I am uising a expensive OS Gikken clutch, trouble free and it work great, but with a metalic noise at idle when the clutch is pressed; you can like or not. I am doing track and street without hard start from 0.
  LotusTalk - The Lotus Cars Community > Sponsor Zone > BOE Fabrication
