Go Back   LotusTalk - The Lotus Cars Community > Motorsports > Safety
Old 06-27-2009, 04:47 PM   #1 (permalink)
accessguru's Avatar
Need advice for Racing Harness
I recently bought an Exige S that has the racing harness bar already installed. What's the best, simple solution to add a racing harness to my stock Exige seats? Should I just get some harness's that wrap around the bar and hte seat? Thanks.
Lawrence
07 Krypton Green Exige S
05 BMW K1200S
06 KLR 650
accessguru is offline   Reply With Quote
Old 06-27-2009, 04:54 PM   #2 (permalink)
perfututum futūtor
RoadDad's Avatar
Why do you want the harnesses?
Me... I don't need to.
Bite me." -Randy
Old 06-27-2009, 04:58 PM   #3 (permalink)
accessguru's Avatar
Just for some weekend autocrosses. Also, since I have the bar, I might as well get some use out of it.
Lawrence
05 BMW K1200S
06 KLR 650
Old 06-27-2009, 05:07 PM   #4 (permalink)
vv My Awesome Wife vv
chotto's Avatar
If you're just doing autocrosses, you should get the CG Lock, CG-Lock - Blackwatch Racing
Harness are good, but a lot of set-up is required for them to work correctly. They can also be a pain if you drive it on the street (my wife always complains when she gets in mine since I put in harnesses). I wouldn't go with harnesses unless your tracking it a lot. Fishguy will jump in here and tell you more.
2005 SY-BWR Supercharger, Challenger Grill, AreaP single tip exhaust, Ohlin Double Adjustables, RTDbrace, Custom Kirkey 58 Series seats, Schroth 6 pt. harnesses, Multivex mirrors, Odyssey PC625 battery, Micromirror, HID's, V2arms, Sparco removeable steering wheel, 15"/16" Rota's with RA-1's, Pagid RS 4-2 pads, Cup airbox, Saikou Michi catch cans
chotto is offline   Reply With Quote
Old 06-27-2009, 05:10 PM   #5 (permalink)
accessguru's Avatar
That may be a good way to keep my wife from driving my car I'm not really up to speed on the different configurations. I wasn't sure if there was a "bolt on" solution with the stock bar. Thanks for the quick reply.
Lawrence
05 BMW K1200S
06 KLR 650
Old 06-28-2009, 04:22 AM   #6 (permalink)
luxige
luxige's Avatar
Schroth provides a wealth of information on harness installation here:
Installation- and Operating Instructions
luxige is offline   Reply With Quote
Old 06-28-2009, 05:56 AM   #7 (permalink)
accessguru's Avatar
That's a big help, thanks.
Lawrence
05 BMW K1200S
06 KLR 650
Old 06-28-2009, 05:58 AM   #8 (permalink)
V Not my picture V
RacyTracy's Avatar
Images: 1
You could mount a ChaseCam on it, that way you're getting some use out of it.
Tracy
2009 Lotus Exige S260
2008 Toyota FJ Cruiser
LOG 29 photos
RacyTracy is online now   Reply With Quote
Old 06-28-2009, 06:05 AM   #9 (permalink)
accessguru's Avatar
Another good idea. The 4 point harness' that I've seen look like that have mount brackets for the shoulder straps. Could I simply remove them, wrap them around the bar and secure them with the slot bracket, or are they typically sewn to the bracket?
Lawrence
05 BMW K1200S
06 KLR 650
Old 06-28-2009, 05:01 PM   #10 (permalink)
usually.
FWIW I use a 6pt in my car and although a harness was a royal pain in the butt at first for street use (50% track 50% street) after I worked out some litte 'techniques' that make it more user friendly its actually only a little bit more troublesome now compared to 3pt and I do feel a lot safer/secure in the car.
These 'techniques' include always loosening the harness straps before attaching them, leaving the tightening of the shoulder straps untill Ive pulled out my driveway or paid at the parking barrier as at these times I need more upper body movement.
Im so used to the 6pt now that its a non issue really for street use. You could always mount both a 4 or 6pt and keep your 3pt installed. This was how I had my last Exige set up - which worked fine.
Drmike is offline   Reply With Quote
Old 06-29-2009, 04:17 PM   #11 (permalink)
kaz
JabStrongFierce
kaz's Avatar
accessguru-
just do the simple route of installing a harness setup (4 or 6 point) and using them only during the autoX's. It's the safest routine so that you use the stock belts + airbag on the street, and have the harnesses for when you need more support. It's easy to have both systems on the car at the same time. Sector111 has hardware to do just this and many people have their 4 point ASM installed this way.
2006 Elise : JFG | Nitrons | 2bular 8" Single | Reverie diffuser and misc. carbon bits | Tripoint Engineering W/A Intercooler | Ronin supercharger | DRS EFI and tuning
kaz is offline   Reply With Quote
Old 06-29-2009, 05:50 PM   #12 (permalink)
lancer360's Avatar
I you are doing autocross only and not going to the track, I would do the Sector 111 4 point ASM harness install in tandem with the stock seat belts. If you think you might go to the track then look at doing a 6 point harness. Do lots and lots of research on Lotus talk regarding harness installs. There are many ways to do it, some good, some down right scary.
'05 Lotus Elise Saffron Yellow, Touring, Sport, Stainless Brake Lines, Moroso Oil Pan, RTD Brace
KBS Mark 7 Formula 500 with a heart transplant in progress '09 600cc GSX-R Due to hit the track in August '09
lancer360 is offline   Reply With Quote
Old 06-29-2009, 08:34 PM   #13 (permalink)
are you saying a harness and airbag on the street is less safe than a 3pt and an airbag on the street? or did i missunderstand. if so can someone explain why?
Old 06-29-2009, 09:51 PM   #14 (permalink)
No, it's only an N/A
RichS's Avatar
Seatbelts are designed to work with airbags, a harness is not.
Que fishguy (who is looking at this thread as I type...).
Useful links to vendors removed at Nadeem's request.
"Nice avatar by the way, I doubt Colin Chapman would have followed the herd as I have seen many here do. --Nadeem"
RichS is offline   Reply With Quote
Old 06-30-2009, 12:40 AM   #15 (permalink)
anglophile in exile
Aedo's Avatar
Images: 88
I have also asked this question and the only answer so far received is that the 3pt plus airbag is tested and engineered to a high degree by Lotus. The engineering integrates the belt stretch (3pt will allow your head/torso to come further forward than 4pt) with the airbag to reduce overall stresses in the body.
The 4pt ASM has not been tested with the same rigour - which is not to say it is not safer. Also the 4pt is considered less safe by the "you can't let people think for themselves" crowd who argue that it won't always be fitted correctly and an ill fitted 4pt is less safe that a 3pt which is "automatically" fitted to perfection (OK - you can see my slant on this ). If you always do up your harness correctly (and there is no excuse not to do so) I believe it is safer than the factory 3pt
Aedo is online now   Reply With Quote
Old 06-30-2009, 01:01 AM   #16 (permalink)
kaz
JabStrongFierce
kaz's Avatar
I think the main point of the debate is on the isolated neck injury where hyper extensions can cause permanent damage or death. The idea being, the tighter your body is secured to the car, the more likely your head will continue moving till it decelerates, and in theory (and in reality like in race accidents) this can kill you as your spinal chord separates from the base of the head.
Hence, the entire HNR industry of Hans et al were created to solve this issue. There is no HNR for the street where you can wear one without also wearing a helmet; so most will say the stock system, which allows your body and head to move together more in unison is safer than using harnesses without a helmet and HNR system.
That being said, it's just up to you personally on what you find to be acceptable risks and what you do in your car normally.
Old 06-30-2009, 08:16 AM   #17 (permalink)
Cthulhu's Avatar
+1
The air bags and collapsing steering column are designed to decrease accident impulse and serve no purpose if you're strapped to the seat back. These features only apply to a front impact though, and you may be crashing backwards (and a million other subsequent directions) if you lose it in an Exige.
Whiplash REALLY sucks. There's no such thing as being too safe and going with HANS + a harness when it comes to auto-x or track driving. You could still use the OEM belts for street use.
You could always wear the harness on the street and wear a nike headband stretched over the back of the headrest (be sure to write "NOMEX, SFI, FIA" on it first)!
FYI: if you ever do an instructed driving course in your Exige, any extra safety measures installed on your side must also be installed on the instructor side (at least if you do Skip Barber).
PS: is it illegal to dress up like the stig, in a full firesuit and helmet, if you're driving on the street? Because if it isn't, it would look hillarious.
2009 135i - Montego blue/Coral red.
2007 Lotus Exige S (deceased) - Storm Titanium.
RIP SCCVC11127HL80723
May the roar of your supercharger forever shatter the serenity of the heavens <3
Cthulhu is offline   Reply With Quote
Old 06-30-2009, 08:31 AM   #18 (permalink)
ΒÄŅNED
apk919's Avatar
Images: 20
+2
I always use the 3-pt on the street. I usually just fold the shoulder harness behind the seat... but it's actually very easy to thread them back through the holes in the seat back, in which case they're not even visible. The lap belts can be run along the outsides of the seat rail, again out of the way.
Originally Posted by Cthulhu View Post
+1
I doubt it... it's kind of just wearing the same thing you'd wear riding a motorcycle; if you have an Arial Atom, you really should wear a full face helmet. The problem with using a HANS on the street is that it severely limits your side to side head movement, even with the sliding tether. Not good for checking traffic at stop signs, etc.
Old 06-30-2009, 08:45 AM   #19 (permalink)
Cthulhu's Avatar
Originally Posted by apk919 View Post
+2
Yeah... but it doesn't matter if you hit someone, you've got HANS and a harness
Old 07-01-2009, 04:53 AM   #20 (permalink)
true - but that doesnt automatically mean anything.
this statement (as a reason) is no different than saying
lotus cars are not designed to work with people wearing odd size socks.
