Which R3 Rage restraint should I get?
I need to buy a neck restraint device for track days. I have an Exige S with the Lotus Sport Recaro seat and 6 point (non-Hans compatible) harnesses. From my research, and discussions with other drivers, the R3 seems like a good one to select. I noticed on the Safety Solutions website that they sell two models of the R3 Rage: one model is listed as "in seat" and the other does not have this designation. Which is the right one for my setup?
2007 Carrera S 2007 Exige S 2007 CBR600RR |
Form and Function
I had the R3 rage which came with a foam cushion to complement the back portion - this is a must or else it may hurt your spine...
www.FaceNBody.com 2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C! Spec Racer Ford #237 |
daily driver
The in-seat versions stays in the car and connects to the seatbelts while the regular version is attached to your torso before you get in the car. The in-seat only makes sense if you only plan on using it one car - the regular version is best if you will be switching cars.
http://www.rahulnair.net/blog |
