#221 (permalink) | |
Oh and it sure looks it. ![]()
00' S1 Exige (7.14lbs/hp) ![]() 94' S4 Esprit 07' Ram Quad cab 3500 hauler |
#222 (permalink) | |
I have 4-Wheel OCD
#223 (permalink) | |
#224 (permalink) |
1335 h4x0r
Thanks for the pictures and the explanations over at newcelica.org.
What is the response time of your system? It looks like you have a huge volume of air to bring up to pressure: most of the armoire, those long pipes in the back, and the bench itself. Maybe 100-150 cubic feet? Do the pressure and the flow stabilize in seconds? Minutes? Is it stable or does it oscillate? And where are the pressure sensors? In the big box or under the bench or ...?
I have it! (5/6/2006) 2005 CO, LSS, Touring, hard top. |
#225 (permalink) | |
The pressure sensors are in the little rectangular box thats on the wall under the power plug. The sensors feeds don't really move any air - they are dead headed into the sensors - they just register changes in pressure. The big motor box is deceiving in that it looks hige but its very segmented inside of there and its all irrelevant to the testing process - those big straight PVC tubes on the back and the test bench itself are where the magic happens - that giant box is literally just a selectable air pump. |
#228 (permalink) | |
'05 Storm Titanium / Red Touring / Hardtop / Stage 1 / Exige Wheels / Ohlins / RTD Brace / Traqmate Last edited by Bruce : 05-01-2007 at 04:49 AM. |
#229 (permalink) |
Excuse the hijack.
Where's the cnc porting like NASCAR. I thought the porting on a Toyota head has been done a million times. Someone must have the porting all worked out. hijack over |
#230 (permalink) | |
#231 (permalink) | |
On the Toyota side there has been ONE recorded 2ZZ P&P head done by someone that actually owned a flowbench (Joe Alaniz) and they did not report the results. There have been a handful that were done without the use of a flowbench to measure results and none of those have so much as before and after dynos. |
#232 (permalink) | |
Elise Fanatic
Pete 05 Lotus Elise | 06 Porsche Boxster S | 97 Porsche Turbo |
#233 (permalink) |
McLareghini Bugatterrari
YEAH!
I'd rather have somebody like Boosted, who obviously cares about his work, is willing to go the extra mile to get everything done RIGHT, and who answers concerns in a forthright, detailed, polite, and in laymans terms, than I would somebody who doesn't do all those things. If I was getting work done on a 1984 Reliant K then I wouldn't care about it. But if I was having my Lotus operated on, I would want the right guy. xtn
#234 (permalink) | |
2.0-6262
#235 (permalink) |
Matrix XRS 2zz-ge
please
05 Toyota Matrix XRS Indigo Ink Pearl 2zz-ge Progress Rear Sway Bar TRD STB PBR Groundwires MagnaFlow Cat Back Exhaust Tein SS coilovers TWM Short Shifter Injen CAI C-one perfromance Fr. Rr. Bar C-one Underpanel |
#236 (permalink) |
2.0-6262
been workin so no time to get to the machine shop, if i have time i will either call or get down there by the end of the week, getting there in person is probably the only way i'll get them to dig up the info so it could be the end of the week.
i know of someone else who might have some info on this, i'll try and get in touch w/him today. |
#237 (permalink) | |
I'd also like to see what numbers you have for localized velocity in the ports if you have that data. |
#238 (permalink) |
2.0-6262
i'll get whatever data i can from either of the guys and let you know.
i havent followed most of this thread, but how much did it cost and time take to build the flow bench...if its got more use in the future, esepcially for money making purposes im sure it was worth it, but if just for a single project or 2 it would have been easier to just use one at a shop no ? |
#239 (permalink) |
It cost a lot and has taken a long time. (its been in development since last August in fits and starts) We built this one because I got tired of renting the one I have been using across town and littlerocket has use for one too. That, and designing and executing this project is enjoyable in and of itself. I've learned a ton about flow benches and flow measurement and monitoring. I've known how to use one for quite some time, but now I know how and why they work. Hell, I'm still learning.
And yes, we intend to continue to use it for heads for the 2ZZ and other engines, and I also want to start playing with intake manifold design, and other things. Last edited by Boosted2.0 : 05-16-2007 at 11:03 PM. |
#240 (permalink) | |
Future 2ZZ-GZE member...
All hail Boosted 2.0! ![]()
