Old 05-18-2007, 11:04 AM   #241 (permalink)
2.0-6262
dustylax's Avatar
sounds good. i called the one shop today, unfortunately he has done plenty of them in the past and was recently robbed including his papers and computers and doesnt have the numbers anymore, he went on to tell me if he had them he wouldnt want me to just use those numbers alone since everyone flows differently and everyone likes to change their numbers etc so using something else like making a venturi to get a base that you can compare with would be the better route than using any numbers he might have or numbers from anyone else...he wasnt trying to just not give numbers, he rattled off the toyota motors he had new numbers on but not the 2zz. i'll try and get some from the place i use either today or tomorrow if i can.
dustylax is offline   Reply With Quote
Old 05-22-2007, 09:10 PM   #242 (permalink)
LittleRocket's Avatar
The flowbench is no longer a project! It is a functional tool. We flowed a head tonight. What a relief. I have underestimated timelines on projects before but wow does this one take the cake!
Built 2zz powered, 6 speed-lsd mr2 spyder
LittleRocket is offline   Reply With Quote
Old 05-22-2007, 09:28 PM   #243 (permalink)
Boosted2.0's Avatar
Check it out:
Nuff said
Boosted2.0 is offline   Reply With Quote
Old 05-22-2007, 10:36 PM   #244 (permalink)
Matrix XRS 2zz-ge
kortik's Avatar
wow.
what will the numbers be you think after the P&P job? or hoping to get.
hope exhuast side is matches the intake. Intake looks so much better flowing that exhaust its awesome
05 Toyota Matrix XRS Indigo Ink Pearl 2zz-ge
Progress Rear Sway Bar
TRD STB
PBR Groundwires
MagnaFlow Cat Back Exhaust
Tein SS coilovers
TWM Short Shifter
Injen CAI
C-one perfromance Fr. Rr. Bar
C-one Underpanel
kortik is offline   Reply With Quote
Old 05-22-2007, 10:58 PM   #245 (permalink)
Boosted2.0's Avatar
Nope - exhaust has smaller ports and valves - its supposed to flow less at the same pressure - when the exhaust valves open the cylinder pressures are WAAAAAY higher than atmospheric pressure which is why those valves don't need to be as big as intakes.
As for the numbers after P&P - it depends. I have to run the math on CFM versus displacement and RPM. If it doesn't need much more CFM we will concentrate on cleanup and velocity.
Old 05-22-2007, 11:06 PM   #246 (permalink)
Matrix XRS 2zz-ge
kortik's Avatar
I see.
Thanks man
Cannot wait for June 6 LOL
TRD STB
PBR Groundwires
Tein SS coilovers
TWM Short Shifter
Injen CAI
C-one Underpanel
Old 05-23-2007, 05:45 AM   #247 (permalink)
Future 2ZZ-GZE member...
GTsRasta's Avatar
Cool stuff! Now if you were to have a timetable, when would everything be put together and ready for the dyno? haha
Originally Posted by scottyb View Post
Maybe you should put a disclaimer in your sig saying that you don't have a Lotus nor have tried any of the products you are constantly posting about.
03 Celica GT-S, 6 Speed Manual, Carbon Blue
Performance Mods: AEM Cold Air Intake, TWM Short Shifter
GTsRasta is offline   Reply With Quote
Old 05-23-2007, 11:24 AM   #248 (permalink)
I have 4-Wheel OCD
raygr's Avatar
Yes, I know Sleepless is missing his car! Track season is ticking away....
Ray in Washington State - 06 Elise, 07 Exige S
www.mentalmotoring.com
raygr is offline   Reply With Quote
Old 05-23-2007, 06:42 PM   #249 (permalink)
GTsRasta's Avatar
When he recieves the most powerful NA 2zz in the world...I bet he'll be happy with all the time and money invested :chuckles: . Unless somebody does an all out NA drag 2zz vehicle, this will go down in the record books for the most work done on the 2zz.
Old 05-23-2007, 08:35 PM   #250 (permalink)
Boosted2.0's Avatar
ASAP
Old 05-23-2007, 09:51 PM   #251 (permalink)
choi0706's Avatar
yay! congrats on the flowbench.. I'll have to take a peek at it completed..
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 05-23-2007, 10:49 PM   #252 (permalink)
Elise Fanatic
sleepless's Avatar
I only wish you guys were nearby so I could go see this contraption work!
Pete
05 Lotus Elise | 06 Porsche Boxster S | 97 Porsche Turbo
sleepless is offline   Reply With Quote
Old 05-23-2007, 11:19 PM   #253 (permalink)
I have 4-Wheel OCD
raygr's Avatar
What's with the avatar change? Are you subconsciously wanting a turbo now?
Old 05-24-2007, 12:28 PM   #254 (permalink)
Elise Fanatic
sleepless's Avatar
That's one of the compressor wheels from my 993 Turbo; I've used that on other forums; consistency
Pete
Old 05-24-2007, 06:42 PM   #255 (permalink)
Boosted2.0's Avatar
I didn't know you have a 993. You have good taste in cars.
We'll take a video of the flowbench at some point so you all can hear what it sounds like.
If you ever wind up in Houston I'll be happy to show you how it works.
Old 05-26-2007, 05:22 PM   #256 (permalink)
Elise Fanatic
sleepless's Avatar
It is the reason for my "patience"
If we hit our 250HP target with this project then the Elise will have almost the same power to weight ratio of around 7.5lbs per HP The Turbo is 7.3lbs per HP. If you guys can get over 260HP, then the Elise will match or beat it
So, get working
Pete
Old 06-02-2007, 10:24 PM   #257 (permalink)
Exhaust airflow passed 200 cfm without sacrificing air speed today. More exhaust side work tomorrow. This flowbench is a pretty incredible tool.
Old 06-23-2007, 11:52 PM   #258 (permalink)
The intake port is rocking now. I picked up over 20 cfm and increased air speed dramitcally. Well over 400 fps in the short turn.
Old 06-24-2007, 06:57 PM   #259 (permalink)
Elise Fanatic
sleepless's Avatar
What things remain to be done (other than the obvious reassembly and tuning)?
Pete
Old 06-25-2007, 04:26 PM   #260 (permalink)
Port your head.
Have several valve seats cut and flow test them then have your head cut to the best seat.
Have the top end coated.
Port the intake manifold.
Fit the throttle body
Assembly, install, break in and dyno tune.
Reassemble the rest of the car.
I don't rember if I told you but the lsd is installed already too.
