#21 (permalink) | |
Elise Fanatic
Pete 05 Lotus Elise | 06 Porsche Boxster S | 97 Porsche Turbo |
#23 (permalink) |
Find an ECU solution first!
It seems that only Tripoint has a true ECU solution. If you do go FF i would definitely recommend using their ECU solution. Otherwise the ECU will adapt and the piggyback solutions are really only temporary. I know a few FF unichip guys will jump on me, but I have yet to see any proof that the unichip can keep up with the 05 ECU.
#24 (permalink) | |
2009 XP National Champion
![]() Join Date: Oct 2003
#25 (permalink) | |
'05 Storm Titanium / Red Touring / Hardtop / Stage 1 / Exige Wheels / Ohlins / RTD Brace / Traqmate |
#26 (permalink) | |
Waiting for next Lotus...
#27 (permalink) | |
http://209.59.172.12/forums/showthread.php?t=20532 I do believe this one has the built motor, but this is probably a good idea with any type of forced induction with the 2ZZ and regular tracking. Stephen |
#28 (permalink) | |
His Impatientness
www.agentsofentropy.com |
#29 (permalink) | |
I'm Lovin' It!
#30 (permalink) |
Rollin' On Gold!
K20A Swap can be done with a few K20A swap kits out there. K20A motors can be made to 250HP easily (or should i say 230WHPish) with Hondata, and some minor headwork.
__________________ 2006 Lotus Elise AW |
#32 (permalink) | |
#33 (permalink) | |
Elise Royalty
This is a 340R ![]() This is not
#34 (permalink) | |
#35 (permalink) |
Exactly. The lotus is a gutless wonder down low. The power increases as RPM increases. My point is that the turbo is on full boost at 3000rpm, which one will NEVER see at the track if the car is driven properly. I am not suggesting there is no difference with an NA or SC car, but rather in the intended application it is really not an issue.
#36 (permalink) | |
Elise #76
I'm pretty certain that my NA Elise will take my Audi S4 V8 off the line and for the first 50 feet or so. ![]()
Owner of '05 Elise S/T- touring- LSS-Stage 2 '07 Audi RS4 4.2L V-8 420 HP - 6 Sp..(sold) '07 Toyota Prius |
#37 (permalink) |
The rotary sounds good, very light. I will bet someone fits a 3.6 liter narrow angle VWAG V-6 before too long. 280hp and torque bone stock. The original VR6 was designed to fit in a 4 cylinder engine bay. Until then I think Boosted 2.0 is on to something with the Celica GTS instrument cluster. Doesn't that solve the biggest ecu obstacle for the 2zz?
#38 (permalink) |
Elise Fanatic
Regarding not liking turbos: What I have experienced is that throttle finesse is hard with a turbo because lag happens anytime time you are off the throttle.
Most people focus on the lag from startup until the turbo spools up. This doesn't bother so much, because as others have pointed out, our cammy motor is actually worse than any turbo I've driven in its power curve, although it does not bother me because at the track I've come to be quite good at keeping it in the second cam. What I care about is the throttle response in say mid turn when you sometime breathe off the throttle and then back on after the car rotates. My 993 Turbo is okay in this regard, but the turbos do spool up and I have to watch out for oversteer when that happens. This doesn't happen with an NA motor, nor with a supercharged motor. So, the only way I'd buy a turbo track car is if I could test drive it on a track; I bet the number of people offering to let me drive the FF car has just seriously diminished ![]() So far, it seems the K20 motor transplant comes the closest to my requirements. With a Tri-Point supercharge in a close second place (well, probably a tie if you consider the pain in the but factor of do an engine transplant vs. a supercharger/intercooler installation).
#39 (permalink) |
I agree on the turbo issue, you need instant throttle and it is not there, I had this issue with my 93 tt rx-7, good power when your in the boost, but on and off, and I hate guessing mid-corner. Just curious, this power is needed to stop gettin pasted by *@#$$ in v-8s who can not drive too well but have 400hp. I have this issue, they can't hang in the turns but on power straights pass me and it eats at me to no end. Looks like tripoint and a intercooler on you roof will solve the problem.
#40 (permalink) | |
I sent Hondata an email about their "box" for the cluster.. they wouldn't budge on producing a universal one but simply replied "give us a call when you have a honda engine".. they think their "box" will sell more for honda engine conversions than universal applications for any aftermarket ecu.. ![]() |
