#41 (permalink) | |
Waiting for next Lotus...
#42 (permalink) | |
2009 XP National Champion
![]() Join Date: Oct 2003
#43 (permalink) |
i have the forced fed 275 turbo and if you haven`t driven one you should.
it is exceptional and very fast. I would not want to go faster on the street. it is a perfect match for the lotus elise. it turns a dog into a race horse. Best of luck. ABelise |
#45 (permalink) | |
Elise #76
Owner of '05 Elise S/T- touring- LSS-Stage 2 '07 Audi RS4 4.2L V-8 420 HP - 6 Sp..(sold) '07 Toyota Prius |
#46 (permalink) | |
Elise Fanatic
Pete 05 Lotus Elise | 06 Porsche Boxster S | 97 Porsche Turbo |
#47 (permalink) |
I agree the "let by zones" at PR can be difficult unless the driver you've been nibbling at through 3a/3b truly lets up. I applaud your challenge and budget as it as least puts it within my realm. Do you know your car's output with your current mods? (I realize it is relative given the weight loss program you put it on)
karl |
#48 (permalink) | |
Lotus Wannabe
2000 MR2 Spyder(s) |
#49 (permalink) | |
User, Registered
Francis 2006 Chrome Orange Elise: LSD/TC, Nitron SAs with 425/650 springs, BWR 7/8" Front Bar, Eliseparts bumpsteer kit, VF Stage 2, 2bular Header + Sport Cat + 8x24 GT3 Muffler, ECU Tune by Jermaine, Smaay's fuel rail, ACT XT clutch, Saikou Michi dual catch can, Moroso pan, Manly's mount inserts & FF Engine Damper 2000 Black Integra Type R: - 213,000 miles...running again! Last edited by fpitas : 09-08-2006 at 06:34 AM. |
#50 (permalink) | |
#51 (permalink) | |
Elise Fanatic
#53 (permalink) | |
Lulu ROX!
$43k + $15 = $58k There's a USED Z06 on the forum for $75k. I think you're missing another $15k or so.
My daily driver is an orange plastic toaster |
#54 (permalink) |
I think 250 is doable. 230 is cake with the hard parts out there now. With a lightened crank and internal thermal coatings I think 250whp is doable.
The main unknown component at this point is the engine management. I think I have a handle on that one. Let's say I am 95% confident I can make the PFC work in the elise. I say that because I have been able to mesh a 2zz celica pfc into an '03 spyder 1zz/smt car. The car has a 2zz swap. To make it go I had to keep the 1zz ecu to run the throttle body and the smt computer to run the gearbox and run the engine with the 2zz PFC. Basiclly the 1zz ecu still works the can bus, gauges, a/c, emissions, dbw t/b, SMT computer interface, and everything else it is supposed to with the exception of the engine. The same thing I need to do with the elise. The car is driving around with a few smt quirks that we will attempt to tackle but zero issues with the engine side of the equation. FWIW I think rexroth has an interface for the smt computer but that is another chapter. The main motivation for me undertaking that project is to determine if I could or could not mesh the pfc with another ecu and make it go. The rest of the power is out there IMHO. I may not hit 250 whp for 15k but I can get extremely close.... We will have to increase the displacment with a stroker and an over bore. Count on, port work throttle body over bore, custom header and exhaust, cams, electric water pump, alternator pulley, flywheel, clutch, lightened crank, internal thermal coatings, valves and springs, and 12:1 compression. You may be obdII compliant but it really depends on the cams and the stock ecu's ability to adapt. That may be in your favor from what i understand about the elsie ecu. The beauty of the pfc is I can make it plug and play. So the stock ecu may very well run the engine without an immediate cel....
Built 2zz powered, 6 speed-lsd mr2 spyder |
#58 (permalink) |
More track time please.
But you suggested he sell it and add 15k to get a ZO6. He would be very challenged to sell his elise for over 40k. It is possible but no way he'd get over 45K. But I'd never whip out logic on you Steve. he he.
#60 (permalink) |
Elise Fanatic
Regarding selling my Elise: It has lots of goodies on it, but it is also a stripped track car. So basically, the resale on it would suck. This is why I'm interested in upgrading it vs. say going for an Exige S (which is an option that I'm will to go with, but it will cost me over $30K easily). And, I'm not interested in a Z06.
Regarding my $15K choices: There are 3 supercharger kits out there to choose from and all are at or below $15K. There is 1 turbo kit which also would work, except I don't want a turbo. Then there is LittleRocket's NA proposal. And of course, there is the upgrade to an Exige S which blows my budget two-fold. But with the FF header and 2bular muffler off my Elise I should be close to 240HP (crank) and with a minor supercharger pulley swap, I'd guess it could run closer to 260HP with the stock ECU. Now, I sit and scratch my head, and boy does my head hurt!
