Old 01-16-2007, 06:56 PM   #141 (permalink)
untitled
Beanie's Avatar
shameless plug
You know if you have a Power FC and Datalogit in your car, all you have to do to get this:
is mount a Tablet PC somewhere. It might work with an UMPC (the only reason I think it might not is the resolution should be 800 by 600 or better).
Ignore the onscreen keyboard at the bottom. I had to bring that up to do a print screen. It is a Windows program that has auto tuning, gauges, support for the digital interface of an LC-1 wideband, accurate speedometer, colored graphs, color-coded maps of fuel, ignition timing, and VVT-i, capability to view the maps in 3D, edit as you drive (change maps, change rev limit, change VVTL-i low and high RPMs, view and edit all kinds of other things), auto tune as you drive, launch control (2-step rev limit), data logging and replay (at different speeds), alarms for user-defined conditions (like injector duty > 90%... 10 others can be defined at the same time), automatic calculation of from-speed-to-speed times (like 0-60), a lateral G meter (shown, which also replays by the way, you need a $65 USB accelerometer for it to work), logging of GPS position/speed/heading (you need a USB GPS antenna for that), and a bunch of things I've surely forgotten. It is called Copilot and can be downloaded from here:
LATEST VERSION: http://www.mr-s.org/copilot/Copilot_1_2_1_Package.zip
USER'S GUIDE: http://www.mr-s.org/copilot/Copilot.doc
It is free, but we do accept donations.
It is all about "Other".
Beanie is offline   Reply With Quote
Old 02-03-2007, 10:32 AM   #142 (permalink)
untitled
Beanie's Avatar
I just got done adding another tab with some more gauges.
The bitmaps for the gauges can be changed to anything with the proper scaling. Just edit the BMP in the directory the program runs from. Example:
The data comes from the Power FC via a Datalogit (Power FC to PC interface). It would be really nice to see my software working in an Elise.
Any updates on your project?
Old 02-03-2007, 11:17 AM   #143 (permalink)
LittleRocket's Avatar
The pfc is wired in and double checked. I have to make the patch cable to the pfc and the stock ecu and fire it off tonight!!!!!
Built 2zz powered, 6 speed-lsd mr2 spyder
LittleRocket is offline   Reply With Quote
Old 02-03-2007, 11:45 AM   #144 (permalink)
Bruce's Avatar
On Pete's car?
'05 Storm Titanium / Red Touring / Hardtop / Stage 1 / Exige Wheels / Ohlins / RTD Brace / Traqmate
Bruce is offline   Reply With Quote
Old 02-03-2007, 12:51 PM   #145 (permalink)
the answer to the $15,000 power upgrade
Don has the answer with the Bemani set up--spectacular performance--elegant execution and TORQUE--with NO ecu issues.
evoate is offline   Reply With Quote
Old 02-03-2007, 08:44 PM   #146 (permalink)
choi0706's Avatar
pete wants to stay N/A
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 02-03-2007, 10:02 PM   #147 (permalink)
Elise Fanatic
sleepless's Avatar
Yes, the Bemani is a nice setup and it was indeed the "other" choice; I knew Don was bringing Bemani to the US before I chose Littlerocket's N/A route. If I hadn't preferred an N/A solution, it would have been Bemani for sure.
Pete
05 Lotus Elise | 06 Porsche Boxster S | 97 Porsche Turbo
sleepless is offline   Reply With Quote
Old 02-03-2007, 10:06 PM   #148 (permalink)
Elise Fanatic
sleepless's Avatar
A few pics from LittleRocket's Operating Room:
Pete
Old 02-03-2007, 10:08 PM   #149 (permalink)
choi0706's Avatar
nice~! I'm going to take a peek again sometime next week..
Rally Ready
Old 02-04-2007, 12:24 AM   #150 (permalink)
Matrix XRS 2zz-ge
kortik's Avatar
nice N/A is the way to go IMO
well I am kind of N/A fan
can someone point me to Bemani set up is it a S/C or turbo?
05 Toyota Matrix XRS Indigo Ink Pearl 2zz-ge
Progress Rear Sway Bar
TRD STB
PBR Groundwires
MagnaFlow Cat Back Exhaust
Tein SS coilovers
TWM Short Shifter
Injen CAI
C-one perfromance Fr. Rr. Bar
C-one Underpanel
kortik is offline   Reply With Quote
Old 02-04-2007, 04:38 AM   #151 (permalink)
choi0706's Avatar
s/c...
Rally Ready
Old 02-04-2007, 06:12 AM   #152 (permalink)
untitled
Beanie's Avatar
Man, I wish I was there. When you get tired of the wiring, just remember that, LittleRocket.
Just thinking about LR's house makes me want a margarita.
Old 02-04-2007, 07:06 AM   #153 (permalink)
Bruce's Avatar
I like that wire color coding and your fancy connector probes
Old 02-04-2007, 09:31 PM   #154 (permalink)
Apogee in another life
Donelise's Avatar
Images: 2
Thanks
I'm only posting on this thread to say thank's for the comments and Little rocket is a pro.... your in good hands. All the best with your project...... now if you ever want to blue print a Ferrari motor let me know.
Cheers, Don.
Donelise is offline   Reply With Quote
Old 02-10-2007, 12:28 PM   #155 (permalink)
PFC is up and running.
Old 02-10-2007, 06:31 PM   #156 (permalink)
My other car's a mtn bike
R'elise Me's Avatar
Dyno chart! Is there a breakin period before you can dyno?
Sometimes you have to go in circles to move forward.
05 Elise NA 1750 lbs w/ full cage, fuel cell, aero, 173 whp - Colin would be proud.
2008 LR3 HSE
2005 Mini S Convertible
If I'd thought that one day ALL my cars would be British, I'd have laughed at myself!
R'elise Me is offline   Reply With Quote
Old 02-11-2007, 12:03 AM   #157 (permalink)
Elise Fanatic
sleepless's Avatar
The new motor needs to be built and installed before there is dyno. The PFC is running the current, stock motor.
Pete
Old 02-12-2007, 09:36 AM   #158 (permalink)
untitled
Beanie's Avatar
Congratulations, LittleRocket.
Old 02-12-2007, 09:42 AM   #159 (permalink)
Bruce's Avatar
It would be interesting to see what he could do with the stock motor and PFC.
Old 02-12-2007, 10:26 AM   #160 (permalink)
This is an mr2 spyder with a 2zz swap done recently. Before is a bad exhaust and no tuning. After is a good exhaust and about 20 pulls. All the 2zzs are basically the same.
